source for epson 3700 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By rekbones
  • 1 Post By yakapo
post #1 of 5 Old 11-25-2018, 08:34 PM - Thread Starter
donald winstead's Avatar
Liked: 0
just ordered this projector was curious will I be able to use my xbox one s for source with this or will I need something else as a source sorry for a newbie question
donald winstead is offline
post #2 of 5 Old 11-25-2018, 08:46 PM
rekbones's Avatar
Quoted: 1057 Post(s)
Liked: 547
Yes, you may want something for the audio like an AVR. I don't know if the 3700 even has speakers and if it does they will be rather poor.
donald winstead likes this.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 5 Old 11-25-2018, 09:13 PM - Thread Starter
Liked: 0
thanks and yes the 3700 does have 2 10watt speakers but was going to use a temp sound bar 5.1
post #4 of 5 Old 11-26-2018, 03:47 PM
yakapo's Avatar
Quoted: 49 Post(s)
Does your sound bar have hdmi inputs? If so, just connect your Xbox to the “source” input and projector to the “display” input.
yakapo is offline
post #5 of 5 Old 11-26-2018, 06:01 PM - Thread Starter
Liked: 0
yes using the LG SK9 thanks for infor
