Xiaomi MIJIA Laser Projector 4K version with 4K resolution launched. - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 338Likes
post #421 of 1238 Old 05-04-2019, 11:50 PM
big_k's Avatar
Originally Posted by TexasDJ View Post
Originally Posted by big_k View Post
voltage converter won't be enough if the unit doesn't accept the higher frequency. And frequency converters are cost prohibitive.
So what is the solution? Do I need to hire an electrician to wire in as 220 outlet in my living room? How are others in the US powering their unit?
I would wait for other members to respond... I'd assume it's same for 60hz but I wouldn't spend this much money without a 100%. This isn't amazon where you just return things easily. I just moved from US to Europe, so I have to pay attention to 50 vs 60hz and voltage on all of my electronics as well as my new purchases.
big_k is offline
post #422 of 1238 Old 05-05-2019, 11:22 AM
Ricoflashback's Avatar
Quoted: 1775 Post(s)
Liked: 1247
RE: "There's less image enhancement (processing) when the projector is being fed a 4k signal. Which is why you should always send a 4k signal, even when watching 1080p content." (Dependent on source, of course.)
Doesn't this also depend on the "upscaling" ability of your TV or Projector - as well? And - the quality of the 4K content versus 1080P content? At least for my Sony 900F LCD - - a streaming 1080P image often looks better (sharper, more pristine, better colors, brighter) than 4K, 4K/HDR or Dolby Vision content (especially with Amazon Prime).
I understand if you have a 4K UHD disc - - that certainly makes sense to feed your display the most information possible. But how about streaming? Also - - is there any difference in compression with 1080P content versus 4K or 4K/HDR content? Same algorithm? And, by the way, how is the upscaling or pixel shifting to 4K look like on the Xiaomi Mijia proector?
Home Theater Setup
SONY 75X900F & 49X900E, BenQ W1080ST, Denon X5200 & Emotiva XPA-3
AudioSource 100VS, OPPO 103 & Samsung K8500, 9.1.4 Setup - Speakers - Studio 60's,
V.2 (FL/FR), CC-690 (C), V.5, ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub,
Cornered Audio (FH/RH), Definitive Technology (Front Wides)
Ricoflashback is offline
post #423 of 1238 Old 05-05-2019, 09:33 PM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
HDTVTest unboxing and menu walkthrough. Hopefully his full review comes soon.
bix26 is offline
post #424 of 1238 Old 05-05-2019, 10:25 PM
NJChris's Avatar
Quoted: 35 Post(s)
Liked: 37
Just speaking from my Wemax One, I used a step up converter Lx-500c. Says it does 50/60hz.
Xiaomi Wemax One Projector
NJChris is offline
post #425 of 1238 Old 05-06-2019, 03:09 AM
Quoted: 56 Post(s)
Liked: 9
https://m.youtube.com/watch?v=Kw7m0cvfZac
Thats brilliant news, really looking forward to his review.
drdoom2k is offline
post #426 of 1238 Old 05-06-2019, 06:14 AM
Raúl Rico's Avatar
Liked: 1
Hi there guys,
I received this Xiaomi 4k projector and a PET Crystal screen some days ago, and now I'm looking for a good 4k video player device (mainly 4k movies in NAS and also Netflix/Prime streaming). I have read a lot about my two principal candidates, Shield and AppleTV 4k, and probably I will go for an atv mainly because we are in the apple environment.
What I would like to ask you guys is if someone here has a similar setup or someone is aware of some cons or tech problems about using this projector with an apple tv 4k.
Thanks in advance.
Raúl Rico is offline
post #427 of 1238 Old 05-06-2019, 08:11 AM
JRock3x8's Avatar
Quoted: 1720 Post(s)
Liked: 531
I like my shield a lot. I hear good things about ATV as well.
JRock3x8 is online now
post #428 of 1238 Old 05-06-2019, 08:35 AM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
The VLC app is excellent on the Apple TV, when streaming content from my NAS the scrubbing was super smooth, and VLC can play any codec under the sun. I ended up returning it after I purchased a PS4 Pro. Although the PS4 is much worse when it comes to streaming off my NAS.
bix26 is offline
post #429 of 1238 Old 05-06-2019, 09:10 AM
Quoted: 25 Post(s)
The Mijia 4K has arrived!
And it’s amazing, supercrisp, great colors, actually it seems like it’s brighter than the Wemax one pro (7000 advertised lumens) I had before, latency seems to be the same (100ms)
I only really miss the 8 point keystone, had to cheat a little bit and it’s overscanning at the bottom a bit. Seems like 16:9 is not a universal size in China.. (XY alr screen)
hobbs47, drdoom2k and Johnny nz like this.
Sonny2160p is offline
post #430 of 1238 Old 05-06-2019, 09:21 AM
Liked: 1247
***Looks great! Easy setup? What type of screen and size are you using?
Home Theater Setup
post #431 of 1238 Old 05-06-2019, 09:28 AM
Quoted: 25 Post(s)
Yeah setup was pretty easy, aside from lining up the image perfectly on the screen without the 8 point keystone took some time, especially with such a thin bezel.
Screen is from XY, the lenticular ALR version 120”
post #432 of 1238 Old 05-06-2019, 11:36 AM
Quoted: 56 Post(s)
Liked: 9
Looks awesome, well done. Might copy your TV stand style for our new living room, haha. By the way, there is no 'game' mode or similar on the Xiaomi 4k? 100ms is a bit of a non-starter for multiplayer FPS games, really, might need to outsource these to a gaming laptop or something.
drdoom2k is offline
post #433 of 1238 Old 05-06-2019, 12:16 PM
usc1995's Avatar
Quoted: 376 Post(s)
Liked: 246
Originally Posted by Raúl Rico View Post
Hi there guys,
Thanks in advance.
How important is Dolby Atmos/DTSX to you? The ATV4k is a tremendous streamer from all of the major services (Netflix, Amazon Prime, Vudu, Hulu) as well as the providing access to the huge library of 4K HDR content in iTunes. You get access to the Atmos content in Netflix which the Shield does not have. Unfortunately, the ATV4K will not bitstream your local files so you cannot decode the Atmos and DTSX soundtracks you may have on your local movies. It will internally decode everything to PCM removing the metadata required for Atmos playback. The Shield will bitstream your local files giving you Atmos and DTSX if the files are encoded that way. I use the ATV4K for all of my streaming and a Zidoo X8 (android box like the Shield) for my local files.
usc1995 is online now
post #434 of 1238 Old 05-06-2019, 12:48 PM
Quoted: 25 Post(s)
Just an update:
The mijia 4k does have the black “light” shining around the projected image, giving a square of dimmed light around my screen, a pity..
On the other hand:
Resolution and colors are on point!
Brajesh, hobbs47 and oni222 like this.
post #435 of 1238 Old 05-06-2019, 04:40 PM
Liked: 5
Just an update:
I have noticed this as well, the black light are highly noticeable when during dark scenes which is a bit annoying.
teejay4k is online now
post #436 of 1238 Old 05-06-2019, 06:37 PM
Quoted: 22 Post(s)
Liked: 0
Can't wait for his review. He's one of the more trustable and reliable reviewer for products.
deadrick is offline
post #437 of 1238 Old 05-06-2019, 06:43 PM
Quoted: 22 Post(s)
Liked: 0
Just an update:
On the other hand:
The color is so crisp.
Can you show more photos of the black/back light that bleed out? Is it under the screen? Or all around the screen?
How bad is it? I can't tolerate light bleeding..
deadrick is offline
post #438 of 1238 Old 05-06-2019, 11:17 PM
Raúl Rico's Avatar
Liked: 1
Thanks for the suggestions. As far as I know, play atmos or DTSX local files shouldn't be a problem because I always can use the xiaomi 4k projector. And also because my audio system is a Sonos 5.1 (playbar, sub and 2xplay1) that doesn't accept Atmos and DTS
Finally I got a secondhand 4k apple tv for a great price, and I disconnected my previous setup (appletv hd, kodi in raspberry pi, fire stick and Nintendo Switch, all of them connected to a HDMI switch with a toslink/spdif output. This switch was connected to my previous plasma TV (now xiaomi projector) via HDMI, and to my Sonos system through spdif. This switch allowed me to avoid passthrough problems with my old pana tv)
I supposed I could remove the HDMI switch and use the toslink output of the Xiaomi 4k projector to connect the sonos system. Error. Whenever I play a video (4k or HD) or use streaming apps with the 4k apple tv, I have a huge audio delay in sonos. But when I use the proyector as player, everything works great. Obviously I bought the appletv because xiaomi miui tv software doesn't include any streaming app.
So now I probably would have to buy a new 4k hdmi switch... 😔
pwnpwnpwn likes this.
post #439 of 1238 Old 05-07-2019, 01:29 AM
Liked: 4
Looks GREAT! Think I may go for the same screen, if I order this pj. Have you had a chance to try out 3D? Just want to know if the 3D quality is good and how much dimmer is it. My main reason to order this is the my Optoma, while good in 2D, is not bright enough through the 3D glasses. Naturally 4k is a bonus.
MDB70 is offline
post #440 of 1238 Old 05-07-2019, 11:09 PM
schumy's Avatar
Quoted: 85 Post(s)
Just an update:
I have reported the same problem on my Xgimi 4K Lune in that forum, later I read that it is a common issue on all projector using that TI chip. It is certainly a bit annoying but I can get used to it as the projected image is slightly larger than my field of vision anyway hence the light border is not "in the way" unless I turn my eyes to look for it.
schumy is offline
post #441 of 1238 Old 05-07-2019, 11:11 PM
Quoted: 25 Post(s)
Yeah, or I was thing of maybe adding a few leds behind the screen with a soft color to mask it..
post #442 of 1238 Old 05-07-2019, 11:22 PM
schumy's Avatar
Quoted: 85 Post(s)
The light border also makes the 8 point key stone adjustment useless because the adjusted (reduced) image would make the light border larger.
schumy is offline
post #443 of 1238 Old 05-07-2019, 11:45 PM
da_103's Avatar
Quoted: 16 Post(s)
Curious as to the aspect ratio of the 120' screen, ended up getting the XY 100' but the picture doesn't fill up the whole screen like in some of your pictures.
da_103 is offline
post #444 of 1238 Old 05-07-2019, 11:48 PM
Quoted: 25 Post(s)
Same here with the 120”, it’s not wide enough..
I cheated this by overscanning at the bottom
Or the image coming out of the Mijia 4K is not perfect 16:9 is also possible
post #445 of 1238 Old 05-08-2019, 01:08 AM
Liked: 4
Sounds like it's a 16:10 vs 16:9. Quite a common issue.
MDB70 is offline
post #446 of 1238 Old 05-08-2019, 07:49 AM
10basetom's Avatar
Quoted: 22 Post(s)
According to their stated resolution (3840 x 2160) it's 16:9.
Sent from my 2PZC5 using Tapatalk
10basetom is offline
post #447 of 1238 Old 05-08-2019, 11:57 AM
Liked: 0
i assume that this is hdcp 2.2 compliant since users that have received their mijia 4k didnt complain any compatibility issues
if the ratio are off can someone get the proper measurement?
i suppose its not a big issue, as you can overscan it if the screen frame are thick enough
clyevo is offline
post #448 of 1238 Old 05-08-2019, 03:09 PM
Quoted: 12 Post(s)
Liked: 2
Just an update:
On the other hand:
Hi there! Would love to know if there is noticeable lag when playing video games on the projector? I was looking at the VAVA 4k UST and have seen reviews showing lag when gaming, so was wondering about this one as well. Also, would you happen to know if I'd be able to plug this up in the US with a converter?
Thank you!
DrunkMonk is offline
post #449 of 1238 Old 05-08-2019, 03:48 PM
bix26's Avatar
Quoted: 659 Post(s)
Liked: 341
Digital cinemas use 4096x2160 and its technically not 16:9 it’s 1.9:1 while most televisions and projectors are 3840x2160 and are 16:9. Most UHD BluRays simply convert the resolution and keep the original aspect ratio. I have the same issue on my 1080p projector.
Now if the menus are not filling the screen correctly there is certainly a design flaw thats been overlooked.
bix26 is offline
post #450 of 1238 Old 05-08-2019, 08:18 PM
Quoted: 22 Post(s)
Liked: 0
Anyone has compare this with current newer 4k projector?
Still in dilemma for this xiaomi ust or long throw projector from benq, Epson, optoma.
deadrick is offline
