Xiaomi MIJIA Laser Projector 4K version with 4K resolution launched. - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 342Likes
post #511 of 1247 Old 05-16-2019, 12:58 AM
Liked: 5
Originally Posted by bix26 View Post
DON’T DO IT! Here’s why, that screen along with any traditional ALR or “Ambient Light Rejecting” screen will REJECT light coming from all four sides of the screen. This includes the bottom where your UST projector is placed. UST projectors must be used with either a traditional non ALR screen or a “Lenticular” ALR screen. A lenticular screen works because it’s surface contains angled grooves in combination with a reflective coating that rejects light from all angles except underneath. Here is a diagram that makes it easier to understand.
Good thing I have yet to order this screen projector, otherwise I will be scratching my head, trying not to buy an import product to avoid long delays and import tax, so i will have to stick a projector screen in Aus, I guess the attached photo will do for UST projector and might stick with just 100 inch (AEON CLR) from elite screen. Thanks for the info.
Name:	CLR screen.JPG
teejay4k is offline
post #512 of 1247 Old 05-16-2019, 03:07 AM
Quoted: 24 Post(s)
Liked: 9
I'm hovering over the buy button for the 2019 Xaoimi Mijia as it has dropped back down in price. Give it to me straight, am i best of waiting of shall i pull the trigger now ?
danwel is offline
post #513 of 1247 Old 05-16-2019, 03:20 AM
Quoted: 16 Post(s)
1)Elite Screens CLR, have read that the material is robust, performs well but the frames construction is just ok, and uses Velcro to keep the material tensioned.
2)XY Screens PET Crystal, performs well, the frames construction is sturdy but have read that the material seems thin and delicate.
3)ViewSonic BCP, rebranded DNP Screens (a commercial A/V whole seller). Construction is sturdy, performance is good and the material is stronger than the XY Screens.
I found 2 UST screens from DNP : dnp Supernova STS and dnp Supernova STW. Are they the ones to get here ? If I want 120" I guess I have to go for the STW, but it is not "Pre-assembled" - What does it mean ?
Yovel is offline
post #514 of 1247 Old 05-16-2019, 07:37 AM
Quoted: 22 Post(s)
Liked: 0
Can I know if all of you uses the keystone adjustment to fit in your screen?
Just got my xiaomi 4k projector, no screen yet, spotted a small blur spot at the top left corner, can be seen if I reset the keystone adjustment.
Anyone has the same problem?
But after i adjust the keystone, i can reduce the screen so the blur at the top left will not be seen.
I will be getting the screen soon, so just checking if any keystone adjustment needed with a screen? Or you purely adjust the position of the projector to fit perfectly within the screen?
deadrick is offline
post #515 of 1247 Old 05-16-2019, 07:49 AM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
I would personally wait for some more options to come out this summer or preorder VAVA since it's rebadged 2019 Xiaomi and it's all English, unless you prefer Chinese
Xiaomi Mija Mi Laser UST 1080P (International), Sharp 4k 65", LG 4k 43", Nvidia Shield
klas is offline
post #516 of 1247 Old 05-16-2019, 08:00 AM
10basetom's Avatar
Quoted: 22 Post(s)
Does the Vava also take 120V?
Sent from my 2PZC5 using Tapatalk
10basetom is offline
post #517 of 1247 Old 05-16-2019, 08:07 AM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
100-220V
https://fccid.io/2AFDGVA-LT002/User-...serMan-4174426
10basetom likes this.
klas is offline
post #518 of 1247 Old 05-16-2019, 08:26 AM
Liked: 1
the great thing about the MJJGTYDS01FM - true 4K version is the price. All others are gonna be £2500+.
Someone posted it was down again to an amazing price. Mines on pre-order and therefore should be delivered within a few weeks!!
Deadrick - How good is the picture in daylight? Cheers!!
[email protected] is offline
post #519 of 1247 Old 05-16-2019, 08:39 AM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
Yeah, price is good and how quickly it dropped. I still would like some warranty, 110V and non Chinese OS hence ok to wait a bit
klas is offline
post #520 of 1247 Old 05-16-2019, 09:10 AM
10basetom's Avatar
Quoted: 22 Post(s)
I'm still happy with my Epson 3020, so I will probably wait for this to come to Walmart with 120V support, or maybe get the Vava.
post #521 of 1247 Old 05-16-2019, 09:57 AM
Liked: 1
majority of the Chinese OS can be changed to English via the existing menu or you can install an APK to do it. Agree with the gamble of a warranty.
post #522 of 1247 Old 05-16-2019, 12:23 PM
mon00064's Avatar
There's is a screen on AlliExpress by Kingprints that says it's for ultra short throw projectors. Anybody know if these are any good? Price in the 600 range is tempting
mon00064 is offline
post #523 of 1247 Old 05-16-2019, 02:28 PM
Quoted: 24 Post(s)
Liked: 9
Hmmm, still undecided at the moment. Being in the UK the warranty is going to be an issue even if i get from China or even the US. There doesn't seem to be anything available in the UK that i could even buy and would come with some sort of warranty.
Also looked at the menu situation and for the most part it can be put into English so not a huge issue in that respect and the Vava looks good but still a bit off yet and as you say is still the Xoami underneath anyway
drdoom2k likes this.
danwel is offline
post #524 of 1247 Old 05-16-2019, 03:15 PM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
There is one other difference i think, power button. If you loose remote you can use any android one but not to power it up. In my 1080p I can unplug and plug back in the power cable. Sometimes i also wish it had that button to power off. Vava at least thought of adding it.
danwel likes this.
klas is offline
post #525 of 1247 Old 05-16-2019, 03:18 PM
Quoted: 24 Post(s)
Liked: 9
Bit of a minefield trying to decide, i'm just itching to buy one lol. I have no great need for one but once i get something in my head it is difficult to slow it down a bit
drdoom2k and dbotamous like this.
danwel is offline
post #526 of 1247 Old 05-16-2019, 03:30 PM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
I get, i have 1st gen for now so not in a huge rush to jump on 4k, personally I am itching for Oculus quest to come out in a few days. Definitely looking forward to try watching 3d movies among other things in VR.
klas is offline
post #527 of 1247 Old 05-16-2019, 03:44 PM
Quoted: 24 Post(s)
Liked: 9
I currently have 65 inch tv and this will be my first projector and really really want to get one bought but also want to make sure i am getting one that suits me. I think the Xiaomi 2019 model does BUT having never bought anything of that value as an import item it is a bit of a gamble.
There aren't really any other options in the UK in all honesty so stuck as to what to actually do
danwel is offline
post #528 of 1247 Old 05-19-2019, 03:27 AM
Liked: 1
Deadrick - Did you use a normal 3 pin kettle lead or did you have to buy a plug converter?
post #529 of 1247 Old 05-19-2019, 05:36 AM
Quoted: 14 Post(s)
Liked: 7
There is one other option out at the moment, and that's the Dell S718QL which is can be picked up open box from ebay for a reasonable price (more than the Xiaomi, but even open box will likely have a warranty, buy from China and you are on your own)
However if its a significant purchase for you then I would wait for the Viewsonic X1000-4k, Optoma P1 and LG HU85LA to land later this year. I know it's frustrating waiting but when these are all out we will know what to properly expect from this years crop of 4k UST projectors.
Also - don't forget your ALR screen, especially if you want to watch in a room with daylight.
Mega_Maniac is offline
post #530 of 1247 Old 05-19-2019, 07:53 AM
schumy's Avatar
Quoted: 85 Post(s)
How about the Xgimi Lune 4K? I am using it now which is quite ok.
schumy is offline
post #531 of 1247 Old 05-19-2019, 02:33 PM
Quoted: 24 Post(s)
Liked: 9
Yeah you are absolutely right and it is definitely the right thing to do. Just difficult as i really really want on pretty much now but waiting is the smart thing to do as like you say there will bet more options out later in the year and i can decide then. I'd hate to get one now and then wish i'd bought something else in a few months.
danwel is offline
post #532 of 1247 Old 05-19-2019, 08:01 PM
Movie78's Avatar
Quoted: 946 Post(s)
Liked: 294
I waiting for Walmart to carry it..
Walmart already has the previous model so it won't be too long,fingers crossed
Sent from my SM-G975U using Tapatalk
Movie78 is offline
post #533 of 1247 Old 05-19-2019, 08:08 PM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
You will be waiting for a while if that ever happens... VAVA might be our best bet.
oni222 likes this.
klas is offline
post #534 of 1247 Old 05-19-2019, 08:09 PM
10basetom's Avatar
Quoted: 22 Post(s)
If 3D is important to you, then keep in mind the Walmart model lacked the 3D functionality.
post #535 of 1247 Old 05-20-2019, 05:00 AM
Quoted: 252 Post(s)
Liked: 85
It seems like Xiaomi is releasing another one. Its called peak meter laser 4K cinema 1700 ansi, cinema, well that's how it was translated
https://mp.weixin.qq.com/s?__biz=MjM...jg&wx_header=1
XGimi CC, XGimi Z6, UKCSIS, Vmai M200 Pico
Xbox One S, LG SH4
wheelee is offline
post #536 of 1247 Old 05-20-2019, 05:55 AM
Quoted: 56 Post(s)
Liked: 9
Very interesting, the more the merrier. From your link and based on google translate seems as if the 'Cinema' version will come with its own screen? 'The theater version is equipped with a light-resistant screen equipped with a 6mm ultra-thin optical plate, an 8-layer functional optical film, a Fresnel optical structure, ≥58% ambient light shielding rate, and a ten-fold contrast ratio compared to a white wall.'
drdoom2k is offline
post #537 of 1247 Old 05-20-2019, 06:02 AM
Quoted: 40 Post(s)
Anyone able to share if the YouTube app on Xiaomi 4K UST 2019 model is able to play videos in 4k(2160p)?
I am currently using the first gen and am disappointed with the video quality for YouTube @ 1080p.. 😑
Is it also possible to force Nvidia shield to output 4k YouTube onto the first gen projector? I noticed the quality difference when I play a 2160p file from USB even though the projector is 1080p.. It's amazingly sharp..
Mjzsakae is offline
post #538 of 1247 Old 05-20-2019, 06:25 AM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
Need to double check but as I recall it was streaming 4k but viewport was 1080p in built in player and nvidia shield. Is your version Chinese?
klas is offline
post #539 of 1247 Old 05-20-2019, 06:26 AM
klas's Avatar
Quoted: 167 Post(s)
Liked: 60
Design looks like LG. Hopefully they don't forget to add power button.
klas is offline
post #540 of 1247 Old 05-20-2019, 06:55 AM
Quoted: 40 Post(s)
Yes. Flashed to English.
Mjzsakae is offline
