Xiaomi MIJIA Laser Projector 4K version with 4K resolution launched. - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 383Likes
post #601 of 1471 Old 05-29-2019, 05:48 AM
Quoted: 43 Post(s)
Originally Posted by Nihar P View Post
Ah.. Me too gonna do the same.. My small kid just won't let me watch it if I keep the PJ down, within his hand's reach.
Which ceiling mount/stand did you go for?
Am looking for one that can swivel left-right, up-down & forward-backwards (planning to view on smaller 120" during day giving higher brightness & move backwards to view 150" at night).
Throw distance will be :
Sent from my vivo 1805 using Tapatalk
Thanks for sharing bro..
Mjzsakae is offline
post #602 of 1471 Old 05-29-2019, 06:26 AM
Quoted: 43 Post(s)
Just sold my first gen and ordered the 4K one.. So happy.. Can't wait man..
Mjzsakae is offline
post #603 of 1471 Old 05-29-2019, 07:41 AM
Quoted: 51 Post(s)
Liked: 5
I ordered the 4k model from China and it will be here today. I am in the US. Can I just plug it straight into the wall with the $2 adapter they sent with it?
TexasDJ is offline
post #604 of 1471 Old 05-29-2019, 08:13 AM
Liked: 0
Originally Posted by Brajesh View Post
Posted by the YouTube reviewer whose video is linked above...
Seriously considering ordering this PJ.
Thank you. It's very helpful.
quail duk is offline
post #605 of 1471 Old 05-29-2019, 08:15 AM
Liked: 0
I believe there are two versions out there. One of them works with 110V and will be sent with a plug adapter for U.S user. I got one that came with a U.S plug adapter and it runs on 110V just fine.
post #606 of 1471 Old 05-29-2019, 08:35 AM
Liked: 0
Originally Posted by deadrick View Post
Can I know if all of you uses the keystone adjustment to fit in your screen?
Just got my xiaomi 4k projector, no screen yet, spotted a small blur spot at the top left corner, can be seen if I reset the keystone adjustment.
Anyone has the same problem?
But after i adjust the keystone, i can reduce the screen so the blur at the top left will not be seen.
I will be getting the screen soon, so just checking if any keystone adjustment needed with a screen? Or you purely adjust the position of the projector to fit perfectly within the screen?
Follow the steps below to get the best possible squared image if you place it on a stand or an adjustable ceiling mount:
1. Play around by adjusting the PJ's rubber feet to get the rectangle as squared as you can.
2. Use "fine" adjustment for fine tuning the rectangle.
3. Use "Electric focus" mode (the newest firmware switches it back to Chinese but it's at the same location) to adjust the two upper corners if they're blur by using left and right buttons.
-Done
post #607 of 1471 Old 05-29-2019, 10:29 AM
Quoted: 51 Post(s)
Liked: 5
Mine just came in the mail but didnt come with the plug adapter. Was your adapter shipped separately? Its nowhere in the box.
TexasDJ is offline
post #608 of 1471 Old 05-29-2019, 09:42 PM
Liked: 0
Them you must have the 220V version.
post #609 of 1471 Old 05-29-2019, 09:44 PM
Liked: 0
Mine came with 110V adapter plug in the box.
post #610 of 1471 Old 05-29-2019, 09:54 PM
Liked: 0
If they send you the adapter plug then it should be the 110V version. You'd better buy a mickey power cord coz their adapter is very flimsy and loose. I use a mickey power cord from an old printer and it works great.
post #611 of 1471 Old 05-30-2019, 01:14 AM
Quoted: 24 Post(s)
Liked: 0
Originally Posted by JRock3x8 View Post
Are AT screens a no go with these PJs?
My room has perfect light control
Alr screen is for viewing with lights on, or a it of sunlight.
If you have perfect light control, even white wall is great and doesn't even make a difference except the uneven wall surface.
I honestly can't tell any difference with alr screen and on white wall if I view it in complete darkness.
deadrick is offline
post #612 of 1471 Old 05-30-2019, 02:36 AM
JRock3x8's Avatar
Quoted: 1841 Post(s)
Liked: 596
so what about a 0.7 spandex screen?
To date I've been using a 1070 and a UHD50 which supposedly output 1100-ish effective lumens.
JRock3x8 is online now
post #613 of 1471 Old 05-30-2019, 03:37 AM
phara's Avatar
Hello everybody,
I have received this great 4K projector yesterday, could you please tell me how I can change the menus in English? Is there an .apk file?
Since I also own the 1080p version I will make a comparison with the new one on a 100 "ALR screen. :-)
Many thanks for your help!
greetings
AB
phara is online now
post #614 of 1471 Old 05-30-2019, 07:38 AM
Nathan Webel's Avatar
Quoted: 18 Post(s)
Liked: 26
Originally Posted by phara View Post
Hello everybody,
There may be an apk, but changing to English menus appears to be a simple process from watching this unboxing video (1:42-5:00):
Nathan Webel is offline
post #615 of 1471 Old 05-30-2019, 01:07 PM
Liked: 1
Hello everybody,
greetings
AB
I think its the 3rd or 4th option down in the settings, select English, which is clearly marked.
[email protected] is offline
post #616 of 1471 Old 05-30-2019, 02:45 PM
Liked: 0
coil whine?
Originally Posted by Curl92 View Post
hey people,
I received my 4k video projector today. The picture is great! The projector is already relatively loud, the fan can be heard permanently.
Unfortunately, a high-frequency beeping can be heard. Is this normal or do you have it?
I received mine yesterday and It also has the high frequency beeping, coil whine or whatever it is called. I hopped I would get one without this problem... I will try to get used to it since I don't want to wait to get a replacement which could take another month or more to come.
Anyway, globally I am satisfied with it. Coming from an old HD ready UST (screeneo) I can only be glad!
To compare shortly with my old one:
  • Noise: With the Xiaomi it can reach 40dB if we are right next to it or around 34dB at ~2m. My screeneo does around 30dB and no coil whine!
  • Look: Xiaomi is heavier and less higher but the screeneo has physical buttons and the remote is more complete. This may be a big problem if we loose or break the remote to wake it up from a screensaver or the security screen if something/someone pass in front of the source for example.
  • Picture: undoubtedly the xiaomi has better colors and you can adjust the RGB. The screeneo doesn't have this feature but instead has many pre-select display mode although the red color remain too flashy.
  • 3D: I tried with a 3D bluray and it was a very nice experience with no name DLP glasses. The colors and brightness were way better and no discomfort at all.
  • Input lag: I don't know exactly how many milliseconds but with a game on PS4 Pro it didn't bother me at all. Not far from the screeneo which I read somewhere has a good input lag for an UST projector.
The "not all" translated english menu is enough to use it.
I don't own a 4k android tv box to try it at its fullest yet.
I am projecting on a 90" screen for UST (no place for a bigger one) and I would have been happy if it has a 8 or 12 points keystone to adjust it more. But I am fine as it is
By the way, it is bright enough to use during the day. I tried this afternoon without the curtain of a window which is right in front of the screen.
Without the coil whine it would have been perfect! But maybe many of the owner don't have this problem?
Bibon is offline
post #617 of 1471 Old 05-30-2019, 03:40 PM
klas's Avatar
Quoted: 208 Post(s)
Liked: 69
That static noise (someone who took it apart said it was color wheel) is the same as in previous 1080p model. I am not bothered any more by it but was hoping they addressed it in a newer version
klas is online now
post #618 of 1471 Old 05-31-2019, 10:57 AM
oni222's Avatar
Quoted: 237 Post(s)
Liked: 101
IT IS OFFICIAL!
I ordered this projector to replace the 1080p Xiaomi (white version).
I was waiting to see the VAVA and LG models but since VAVA snootched the pooch with key features and LG wants three times the price of this projector (I paid $2078 including shipping etc).
Now I need to figure out what to do with my current Xiaomi UST projector once this arrives...
PS: Here is my setup https://imgur.com/gallery/RnRc98a
zora likes this.
Reciever: DENON AVR-X7200WA using 7.2.4 with two center speakers (one behind the screen and one below it).
Amplifier: Emotiva XPA-5 Gen1
Projector: Xiaomi UST Laser Projector 4k (2019 edition).
My current setup: https://imgur.com/gallery/RnRc98a
oni222 is offline
post #619 of 1471 Old 05-31-2019, 12:17 PM
oni222's Avatar
Quoted: 237 Post(s)
Liked: 101
Can't wait for his review. He's one of the more trustable and reliable reviewer for products.
I used to think that too until he ripped me off.
For my Xiaomi 1080p I used his referral code from gear best because he promised his calibration settings.
After I received my unit he claimed ignorance and said he did not see my order....
Long story short do not use his referral codes ever!
oni222 is offline
post #620 of 1471 Old 05-31-2019, 12:33 PM
oni222's Avatar
Quoted: 237 Post(s)
Liked: 101
Originally Posted by danimanfx View Post
At this point I`d buy the nVidia Shield if I`d knew is going to work. I have tested 1m, 2m, 3m, 5m cables so far and nothing worked. All those cable don`t have any issues with my monitor, Wacom Cintiq and TV. I have addressed Xiaomi.. but I don`t hold any hopes.
Did anybody tried this with a good laptop/pc? Did you guys managed to get [email protected]?
I have the previous gen Xiaomi UST projector that had fake 4k (downscaled to 1080p).
It works perfectly on my alienware 17R4 laptop using a nvidia 1080m. It also works without issues with my apple tv 4k running [email protected]
Same for my Ps4 pro and Xbox one X all running through my Denon Receiver.
I have the new projector from this thread on order so I can verify if the new projector works the same.
Honestly I think you wont want to hear this but it sounds to me that you need higher quality cables. Not all cables are created equal and if it helps I use HDMI over Fiber optic cable and it works without any issues.
oni222 is offline
post #621 of 1471 Old 05-31-2019, 01:24 PM
Liked: 0
Looking at this projectors manual it supports from 80" to 150" in screen size. As an UST (or any projector) newbie, could someone confirm whether this will work in a smaller screen size i.e my wall can handle only up to 65"? If it's possible, does it have an affect the picture quality when going lower then 80"?
10123290 is offline
post #622 of 1471 Old 05-31-2019, 01:26 PM
Movie78's Avatar
Quoted: 976 Post(s)
Liked: 297
If don't mind me asking why will buy a projector for 65" screen size
Sent from my SM-G975U using Tapatalk
Movie78 is offline
post #623 of 1471 Old 05-31-2019, 01:34 PM
Brajesh's Avatar
Quoted: 568 Post(s)
Liked: 296
Right, for 65", I'd get a LG OLED, unless you need 3D (no more 3D support after 2016 models).
oni222 likes this.
Hi-deft Media Keen Videosaurus
Brajesh is online now
post #624 of 1471 Old 05-31-2019, 01:37 PM
Liked: 0
Absolutely. Even if it's currently my limit, I might have the possibility to use a bigger wall size later on and in that case wouldn't need to buy a new device for that purpose. Until then, I'm pondering on if this or any other UST projector would work well when using a smaller wall size.
10123290 is offline
post #625 of 1471 Old 05-31-2019, 10:38 PM
Quoted: 51 Post(s)
Liked: 5
I’m cool with the image on my white wall but every time I watch a movie my eyes burn afterwards. Any chance this projector is reflecting harmful UV rays off white wall? Similar as to why you shouldn’t look at the dot on the wall from a high powered laser (which this machine technically has but is diffused - class4 highest laser rating that exists).
TexasDJ is offline
post #626 of 1471 Old 06-01-2019, 06:51 AM
oni222's Avatar
Quoted: 237 Post(s)
Liked: 101
I have been using the previous gen version for a good 5000-6000 hours reflecting on a 150" screen and I have not had any fatigue.
Hopefully that helps.
oni222 is offline
post #627 of 1471 Old 06-01-2019, 09:25 AM
Quoted: 51 Post(s)
Liked: 5
Having trouble finding a 150" CLR fixed screen. Anyone know of any? I found a bunch of ALR but biggest I can find thats advertised as CLR is 120". Any help would be greatly appreciated!
TexasDJ is offline
post #628 of 1471 Old 06-01-2019, 10:00 AM
bix26's Avatar
Quoted: 683 Post(s)
Liked: 366
I don’t think anybody makes one over 120”. The material has a lenticular surface that would make it extremely expensive. Screen Innovations might, but I’m guessing you’d be looking at a nearly five digit price tag. If you want a screen that size your best bet would be controlling light very well and using a traditional white, slim bezel screen.
bix26 is offline
post #629 of 1471 Old 06-01-2019, 12:25 PM
jeff9n's Avatar
Originally Posted by oni222 View Post
IT IS OFFICIAL!
Nice screen set up. Do you have to pay duty fee for the purchase? I am concern that any purchase from China today will get hit with additional tariff/duty fee. From my understanding, the tariff begins on 6/1.
jeff9n is offline
post #630 of 1471 Old 06-01-2019, 03:18 PM
Quoted: 51 Post(s)
Liked: 5
My purchase did and arrived before 6/1. Think its random.
TexasDJ is offline
