Xiaomi MIJIA Laser Projector 4K version with 4K resolution launched. - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 342Likes
post #631 of 1247 Old 06-01-2019, 03:46 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
Originally Posted by jeff9n View Post
Nice screen set up. Do you have to pay duty fee for the purchase? I am concern that any purchase from China today will get hit with additional tariff/duty fee. From my understanding, the tariff begins on 6/1.
For the tariff it is a hit or a miss now that Trump has changed the cost of importing from China.
What I like about Bang good is that they have an option to remove their logo from the order. So it is less likely it will be inspected at the border and taxed.
My previous projector was ordered before the import changes so I paid nothing.
Reciever: DENON AVR-X7200WA using 7.2.4 with two center speakers (one behind the screen and one below it).
Amplifier: Emotiva XPA-5 Gen1
Projector: Xiaomi UST Laser Projector 4k (2019 edition).
My current setup: https://imgur.com/gallery/RnRc98a
oni222 is offline
post #632 of 1247 Old 06-01-2019, 03:49 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
Originally Posted by TexasDJ View Post
Having trouble finding a 150" CLR fixed screen. Anyone know of any? I found a bunch of ALR but biggest I can find thats advertised as CLR is 120". Any help would be greatly appreciated!
If it helps this is the screen I am using that is 150" on my Xiaomi UST Laser projector (first gen white).
https://www. amazon .com/gp/product/B00RY9N4QW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It works very well and out of all the samples I got from multiple vendors it actually had the best colors/blacks.
I am not saying this is the best screen it is just the best for my setup.
https://imgur.com/gallery/RnRc98a (my setup).
oni222 is offline
post #633 of 1247 Old 06-01-2019, 07:32 PM
Liked: 3
If you dont mind, which other samples have you had? Is this one even better than the PET Crystal screens that the XY screen guys are selling?
Needed a 150 inch screen as well...
Sent from my vivo 1805 using Tapatalk
Nihar P is offline
post #634 of 1247 Old 06-01-2019, 09:23 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
I got all the samples that Elite, XY and one more I forget the name right now.
I do not believe the PET was available at the time because I did this last year.
Honestly unless you have a ton of light in your room it wont really matter what you pick but I do recommend you buy some samples.
What worked best for me does not mean it will for you. Also I had my family also chime in on what looked best for them because there where samples I liked but they did not and vice versa.
So it really changes from person to person IMHO.
Samples are cheap I paid on average $5.99 per 3 samples and since you will end up using this for a very long time it wont hurt to try them.
Nihar P likes this.
oni222 is offline
post #635 of 1247 Old 06-02-2019, 09:52 PM
Quoted: 40 Post(s)
菲涅尔硬屏
https://m.tb.cn/h.eVeYSnO?sm=96e363
Has anyone tried this type of screen from Taobao.. I can't find a translation for this screen type.. Looks good though.. It's a hard surface, not fabric and I noticed the screen reflects light to the ceiling when used with UST Projector..
Mjzsakae is online now
post #636 of 1247 Old 06-03-2019, 05:21 AM
Raúl Rico's Avatar
Liked: 1
Originally Posted by pwnpwnpwn View Post
You got it all installed now? I wonder if the projector starts, when you turn on your appletv?
Yes! Everything was already installed. Finally, I got a new 4K HDMI switch and connect every player (Apple TV 4K, DVR receiver, Nintendo Switch and Fire stick) through it.
Returning to your question, when Apple TV starts, it wakes up also the projector. This is something that doesn't happen with other devices (DVR receiver or Nintendo). After that, you won't have any problem to control the projector, even shutting it down. I'm using a Harmony hub and remote, but you also can use an HTTP/web app remote control for any MIUI tv device (MiReCo app at GitHub).
The only one thing you cannot do with a 3rd remote or webapp is waking up the projector.
Raúl Rico is offline
post #637 of 1247 Old 06-03-2019, 05:38 AM
Raúl Rico's Avatar
Liked: 1
Originally Posted by niveknow View Post
Two questions:
1) For those using this with a TV box i.e Shield: Does the machine allow you to boot to a single HDMI? I have the original white Xiaomi that always boots to the built-in AndroidTV and does not allow you to book to a Shield behind an HDMI. When using a Harmony remote, I can't set up a boot up sequence and still have to use the original remote to select HDMI 3.
Thank you!
You only have to ways to turn it on:
1. Using the original projector's remote
2. Through CEC "ON" command via HDMI
I have a Harmony hub activity that includes an Apple TV 4K connected to projector's HDMI input3 through an HDMI switch and it always turns on the projector. Ideally, Harmony activity turns everything on and, for sure, it works perfectly, but you must know that the Harmony projector's ON command isn't working, and projector only wakes up due to apple tv.
post #638 of 1247 Old 06-03-2019, 05:49 AM
Raúl Rico's Avatar
Liked: 1
Hi all,
Regarding HDR technology, do you know what is the HDR compatibility of this projector? HDR10? HDR10+? Dolby Vision? I would test it if I knew how to do it...
Thanks in advance.
post #639 of 1247 Old 06-03-2019, 06:13 AM
Movie78's Avatar
Quoted: 946 Post(s)
Liked: 294
Originally Posted by Raúl Rico View Post
Hi all,
Thanks in advance.
I think only HDR10.
Sent from my SM-G975U using Tapatalk
Movie78 is offline
post #640 of 1247 Old 06-03-2019, 07:11 AM
Brajesh's Avatar
Quoted: 563 Post(s)
Liked: 287
Also HLG I think (hope), found in 4K HDR videos on YouTube (like this source). Don't know if the Android media player inside this PJ supports it. It needs to support VP9 v2 codec. For example, nVidia Shield TV doesn't support YouTube HDR, but Fire TV 4K stick does (using Smart YouTube TV app).
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #641 of 1247 Old 06-03-2019, 09:34 AM
niveknow's Avatar
Quoted: 24 Post(s)
Thank you! And will it turn off through CEC as well? In otherwords... does it properly work with a Harmony hub. I hate multiple remotes laying around. =)
niveknow is offline
post #642 of 1247 Old 06-03-2019, 06:36 PM
MowTin's Avatar
Quoted: 32 Post(s)
How does this compare to the BenQ 4K projectors in terms of image quality?
Can I use this with my silver ticket white 133" screen?
MowTin is offline
post #643 of 1247 Old 06-03-2019, 11:35 PM
Raúl Rico's Avatar
Liked: 1
Not sure through CEC, but projector's Turn Off command with Harmony app works perfectly
According to MiReCo page on GitHub, the turn-on command is the only one that cannot be replicated right now. No one knows what it's the BT or IP command that wakes the projector up.
post #644 of 1247 Old 06-03-2019, 11:38 PM
Raúl Rico's Avatar
Liked: 1
I would say the best option would be a special UST screen, like XYScreen's PET Crystal. For sure you can use any other one, but you will lose a lot of image quality.
post #645 of 1247 Old 06-04-2019, 07:23 AM
Quoted: 40 Post(s)
The guy bought it..
100" ALR PET Crystal Screen
post #646 of 1247 Old 06-04-2019, 10:04 AM
hobbs47's Avatar
Quoted: 456 Post(s)
Liked: 488
Originally Posted by Mjzsakae View Post
https://youtu.be/T3FQjCyNtdw
The guy bought it.. 😂
100" ALR PET Crystal Screen 👍🏻
Looks good. I'm actually kind of curious as to the black level performance of this projector/screen combo in the dark. With some light I could absolutely live with what I've seen, but what should I expect in a semi light controlled room?
oni222 likes this.
Benq HT3550/LG OLED65B6P /Panny UB820 4k Bluray/Apple TV 4k
Nvidia Shield/HDFury AVRkey/Samsung HW-K950 Soundbar
hobbs47 is offline
post #647 of 1247 Old 06-04-2019, 10:17 AM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
If it helps in my setup I either have zero light or some light depending on my mood. I use blackout curtains so I barely get any light. I do not use an ALR screen and my Xiaomi has less brightness than this model.
Still I had to turn down some of the brightness during night time viewing but during the day with my windows/curtain open it is not a pleasurable experience.
oni222 is offline
post #648 of 1247 Old 06-04-2019, 10:25 AM
hobbs47's Avatar
Quoted: 456 Post(s)
Liked: 488
So black levels are pretty good at night? I have black out curtains in my living room as well, but light walls. I don't expect Oled blacks obviously.
hobbs47 is offline
post #649 of 1247 Old 06-04-2019, 11:52 AM
Liked: 0
I'm like 90% ready to go on this thing. It solves most of the problems I have with a projector set up vs TV, is ahead of the game, and is cheaper. The Chinese UI doesn't matter because it'll be plugged into an ATV/bluray. Has anyone who bought this had a *poor experience with it?
Kyle Gallagher is offline
post #650 of 1247 Old 06-04-2019, 11:54 AM
Nathan Webel's Avatar
Quoted: 18 Post(s)
Liked: 26
That screen made a huge difference!
Nathan Webel is offline
post #651 of 1247 Old 06-04-2019, 03:49 PM
AV_Integrated's Avatar
Quoted: 1561 Post(s)
Liked: 1152
Yes, SilverTicket screens work find with UST projectors.
Do NOT let people who talk about using ALR UST screens convince you otherwise. If you have a decent room with good light control, then spending money on an ALR UST screen is actually a waste of your money.
A really good home theater space actually calls for a white screen, not an ALR screen at all times.
Brajesh, sparky7 and oni222 like this.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #652 of 1247 Old 06-04-2019, 04:22 PM
JRock3x8's Avatar
Quoted: 1722 Post(s)
Liked: 533
Really like your videos. Very well done.
JRock3x8 is offline
post #653 of 1247 Old 06-04-2019, 04:28 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
I have two OLED TV's and their blacks are unparalleled. If LG made a 150" I would buy it in a heart beat.
This projector is no OLED but it is better than any QLED/LCD/LED I have ever owned.
brandon916 likes this.
oni222 is offline
post #654 of 1247 Old 06-04-2019, 04:33 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
I have the first gen version of this projector that is severely inferior to this projector (worse colors, less brightness and 1080p) and I love it.
I have ordered this projector and it should arrive on the 26th. It is SO HARD waiting for it lol since this is my birthday present for myself...
PS: I ordered my first projector from ******** and their support sucks but the item arrived just fine. They are never the cheapest but at least they wont rip you off.
This time I ordered from banggood and they are severely cheaper than everybody else. With shipping I spent $2074.91 and if you need details look at this thread where I posted the coupon I used etc: https://www.avsforum.com/forum/122-g...l#post58128658
oni222 is offline
post #655 of 1247 Old 06-04-2019, 05:31 PM
Liked: 0
Thanks for the reply, and that's good news. That link is also the best price I've seen on it. I'm in the states, didn't someone mention a 110v version being available somewhere or just get an adaptor and not even worry about it?
post #656 of 1247 Old 06-04-2019, 07:34 PM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
I live in Tennessee and I use this for power: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
PS: If anybody lives in TN and wants to see the projector then PM me.
oni222 is offline
post #657 of 1247 Old 06-05-2019, 07:42 AM
Herb's Avatar
Quoted: 64 Post(s)
Couple of questions
1. How far below the screen does the unit sit? Does this vertical distance change when changing the horizontal distance?
2. I have a Silver Ticket in a completely dark 9.5' x 14' room. I've been considering upgrading from the BenQ 1070 to the 3550... Would the Xiaomi be a better choice / picture? One thing that would be nice is not having the fan noise directly overhead.
Herb is offline
post #658 of 1247 Old 06-05-2019, 11:10 AM
Liked: 0
Thx for the answer. Does it also shut down, when you shut down your aptv4k? Did you have to install that english version, or was it already there? And have you considered buying an AVR which have a 4k hdmi switch built in, like the AVR-X2500H Surround receiver? How do you get sound out?
pwnpwnpwn is offline
post #659 of 1247 Old 06-05-2019, 11:19 AM
Liked: 0
Does anyone know when there's comming an international version? Every where I see this Chinese Version...?
post #660 of 1247 Old 06-05-2019, 11:20 AM
oni222's Avatar
Quoted: 236 Post(s)
Liked: 101
Originally Posted by Herb View Post
Couple of questions
1. I know there is a page from the manual that states distances depending on size etc. Honestly the information regarding height for the 150" that I use feel wrong but I never actually measured it. This is how I use my first gen Xiaomi and this newer model should work the same (I will verify once mine arrives in 4 weeks).
2.a) In a completely dark room a silver ticket screen wont be an issue. Where you would have issues is if you had a screen that rejects light from the the side/below/above. Mainly because your projector will project the image/light from the bottom of the screen and you don't want that to be rejected.
b) After using a laser projector I refuse to go back to a normal one. No having to deal with heat up/cool down periods and replacing lamps is huge and I personally will never go back to that. As for the colors I never owned the BenQ 3550 so I cannot answer that question.
oni222 is offline
