Xiaomi MIJIA Laser Projector 4K version with 4K resolution launched. - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 381Likes
post #1441 of 1465 Old 09-05-2019, 06:14 AM
monakh's Avatar
Quoted: 170 Post(s)
Liked: 45
Ahh.. Can't program a routine and assign it to a button, eh?
Sent from my GM1917 using Tapatalk
monakh is offline
post #1442 of 1465 Old 09-05-2019, 06:42 AM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
When I go to the FireTV remote through Harmony there is no power button, so I am not sure what the process they use to power the device off is.
BenPlace is offline
post #1443 of 1465 Old 09-05-2019, 03:37 PM
Quoted: 31 Post(s)
Liked: 9
Originally Posted by BenPlace View Post
I still see it when my projector shuts off for a brief moment. I use my harmony remote and it does power once and then it goes through the 20 second countdown, displays the chinese screen for a split second and shuts off.
Yeah sorry forgot about that, when you shutdown it is seen in the background for a split second
danwel is offline
post #1444 of 1465 Old 09-05-2019, 03:39 PM
Quoted: 31 Post(s)
Liked: 9
Originally Posted by Knolly View Post
I totally missed that post, sorry!
That's great news though. I did some digging into rooting as well and sounds like it's all quite do-able. The interface was the main thing holding me back from one of these so I should be good to go.
Yeah i looked at rooting it too but in all honesty i don't have any need for it as i use apple tv 4k and Xbox one S and the only thing i need to do is change the HDMI depending what i am wanting to use so that is the only time i see the chineese interface and like another user said when shutting down you see it for a split second in the background. So for me there is no real benefit in rooting it as i have all the options with apple tv i need
danwel is offline
post #1445 of 1465 Old 09-06-2019, 02:09 PM
Quoted: 51 Post(s)
Liked: 5
Originally Posted by danwel View Post
That's what we have been discussing in the last few posts. If you set it in the settings to load to HMDI 1 for example the only thing you will see is the Mi loading screen then the next thing you see is in my case the Xbox green loading screen. The only time i see any chineese is if i need to go into the setting menu.
You can root it to achieve the same outcome but if you use apple tv / fire stick or Xbox etc once its set up to load to a specific HDMI you would have no idea that you have a chineese product. Its the easiest solution unless you feel comfortable with rooting the projector.
Have been wanting to do this too thanks
TexasDJ is offline
post #1446 of 1465 Old 09-07-2019, 08:38 AM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
If you root can you have it show info like what your current resolution is and if HDR is on or off?
BenPlace is offline
post #1447 of 1465 Old 09-09-2019, 07:53 PM
Liked: 5
Did receive my Telon pet crystal screen for 490$+ shipping.
See this tread for those wish to have more detail.
Xyscreen comparison review
https://r.tapatalk.com/shareLink?sha...4&share_type=t
Envoyé de mon iPhone en utilisant Tapatalk
Garfield9988 is offline
post #1448 of 1465 Old 09-10-2019, 02:47 PM
Liked: 0
VAVA Projector OS on Xiaomi MIJIA
Has there been any effort to use VAVA software on Xiaomi projector?
hatpick is offline
post #1449 of 1465 Old 09-10-2019, 02:51 PM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
Why would you need to do this?
BenPlace is offline
post #1450 of 1465 Old 09-10-2019, 02:58 PM
Liked: 0
It's easier to navigate and use because it has all the apps and it's in English.
hatpick is offline
post #1451 of 1465 Old 09-10-2019, 08:03 PM
monakh's Avatar
Quoted: 170 Post(s)
Liked: 45
The VAVA still doesn't have the Google play store. The hardware is slightly different though I am sure the code could be modified to accommodate the changes. But there is no value-add at all to changing anything. I just changed the menu to English and everything works fine.
If you want to take it further, there is a huge thread over at XDA where the dev has created a single click app to root the Mijia (though he only shares that if you make a small donation). Otherwise you can root the regular way which isn't that much harder.
monakh is offline
post #1452 of 1465 Old 09-11-2019, 06:13 AM
Liked: 0
I suffer from the same problem.
And in the past, it was just that problem, but now there is a problem with the display even after starting up.
Uploaded a video of a problem with this product.
Youtube
https://youtu.be/GbWT945bltw
D.Okamoto is offline
post #1453 of 1465 Old 09-11-2019, 06:56 AM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
Youtube
What is your source?
BenPlace is offline
post #1454 of 1465 Old 09-11-2019, 06:57 AM
monakh's Avatar
Quoted: 170 Post(s)
Liked: 45
These lines have become a real issue.
Do you have the lines in the MI Menu (with all the Chinese apps)?
monakh is offline
post #1455 of 1465 Old 09-11-2019, 07:10 AM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
I must have gotten lucky because I have had no lines or issues with my projector.
BenPlace is offline
post #1456 of 1465 Old 09-11-2019, 09:44 AM
Jadon Veldman's Avatar
Hey Guys,
I'm looking at picking up one of these newer Chinese UST 4k projectors and i'm curious if anyone has found hardware layouts of the internal board?
I have a feeling that they are using a standard 80mm fan and would love to verify before purchasing to fix the bad fan noise. The plan if possible is to swap it with a Noctua quiet fan.
Jadon Veldman is offline
post #1457 of 1465 Old 09-11-2019, 10:05 AM
BenPlace's Avatar
Quoted: 86 Post(s)
Liked: 29
Originally Posted by Jadon Veldman View Post
Hey Guys,
This might help...
BenPlace is offline
post #1458 of 1465 Old 09-11-2019, 12:13 PM
Well theres goes that... multiple people in the comments mentioning that the noise is coming from the colour wheel inside vs the fans. They are however 80mm fans so it wouldn't hurt, but wouldn't fix the problem entirely.
Thanks for the link though!
post #1459 of 1465 Old 09-11-2019, 08:43 PM
Quoted: 31 Post(s)
Liked: 9
I am sure i read that some have had issues once they changed the fan. And yes it is the colour wheel but once it is off an running with a movie or tv show you tend to zone out to the noise of it in my opinion
danwel is offline
post #1460 of 1465 Old 09-11-2019, 10:10 PM
bix26's Avatar
Quoted: 683 Post(s)
Liked: 366
I don’t mind fan noise, it’s coil whine that bothers me. I had a DVDO wireless hdmi transmitter/receiver and it drove me crazy. It was probably less than 10db but it was such a high frequency. It was like a human dog whistle. Vincent at HDTVTest complained about coil whine on the Wemax. Maybe it’s the same issuue you guys are having?
bix26 is offline
post #1461 of 1465 Old 09-12-2019, 02:00 AM
Quoted: 61 Post(s)
I am with you on this one - this is a deal breaker.
drdoom2k is offline
post #1462 of 1465 Old 09-12-2019, 02:38 AM
Liked: 0
Xiaomi mi Laser projectors BUG!
The source is HDMI.
This issue is source independent.
Because the same problem occurs on the home screen.
In the early days, I had the same symptoms.
  | # 1395 tihsamikah
  | I've started to experence an issue where the projector will turn on,
  | but no logo is displayed.
Currently, symptoms are getting worse.
These are the symptoms I have :
 ・The logo is not displayed during startup
 ・The screen does not appear after startup
 ・Colors are strange after startup [Youtube: youtu.be/sAzJ3R78A9o]
 ・The screen display is broken after startup [Youtube: youtu.be/GbWT945bltw]
Currently, Those who have a problem that the logo is not displayed will follow the same path as me in the future.
post #1463 of 1465 Old 09-12-2019, 07:45 AM
Quoted: 18 Post(s)
Liked: 2
Just wondering, does anyone know if 8-point keystone correction is something that can be added via software or does it depend on the hardware?
Robert Yoo is offline
post #1464 of 1465 Old 09-12-2019, 11:47 AM
monakh's Avatar
Quoted: 170 Post(s)
Liked: 45
I am sure it can be done by software.
monakh is offline
post #1465 of 1465 Old Yesterday, 04:09 AM
Raúl Rico's Avatar
Liked: 1
The source is HDMI.
  | # 1395 tihsamikah
Originally Posted by Raúl Rico View Post
My Xiaomi 4k projector problems are still the same than some weeks before. No image after start, but it appears 2min later. Sometimes I have also color problems, but they disspear after some time too. I think it's something related with temperature, because if I restart the projector when it's working properly, it starts normally without any problem.
Maybe you are lucky if you can send your projector back to Xiaomi technical assistance service. Here in EU, its quite difficult to get this thing repaired.
Raúl Rico is offline
