BenQ W5700 / HT5550 4K 100% DCI-P3 Projector Announcement and Owner’s Thread - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 655Likes
post #1321 of 1358 Old 03-06-2020, 04:20 PM
zambine's Avatar
Quoted: 219 Post(s)
Liked: 234
Originally Posted by Bachelor View Post
For basic setup, use the cinema preset for all regular non hdr content. For hdr, i like the wcg on and hdr brightness at -2. For your screen size you may like hdr brightness higher. That is a setting you can play with.
Let us know your initial thoughts once you get your hands on it.
Brilliant color on or off?
Sent from my SM-G975U1 using Tapatalk
Akil3x likes this.
zambine is offline
post #1322 of 1358 Old 03-06-2020, 04:50 PM
Bachelor's Avatar
Quoted: 158 Post(s)
Liked: 147
I turn it off personally. But feel free to play with it and do what works for you.
Bachelor is online now
post #1323 of 1358 Old 03-07-2020, 11:21 AM
zambine's Avatar
Quoted: 219 Post(s)
Liked: 234
Originally Posted by diablo900t View Post
Current version is 1.0.1. If you have low/middle/high options for the Dynamic Iris, you're good.
I think anything manufactured June or later is fully updated.
Sent from my SM-N975U using Tapatalk
Originally Posted by Pehu View Post
I think you can actually have the low/middle/high options even if you do not fully have the latest version of the firmware (the firmware update with the low/middle/high options can be done through USB update, which doesn't update the version to 1.0.1 from 1.0.0...). If you have the 1.0.1. firmware, you're good though.
Good news! My refurb unit has the 1.0.1 firmware on it. The noise from the DI is very quiet and it is barely noticeable even with the sound on mute.
I am also auditioning a HT3550 right now and not surprisingly the HT5550 looks to be better in just about every category. And the fan on it is so much quieter than the HT3550!
zambine is offline
post #1324 of 1358 Old 03-08-2020, 09:23 PM
zambine's Avatar
Quoted: 219 Post(s)
Liked: 234
Has anyone had a stuck mirror and know an easy way to fix it? I just noticed a stuck black pixel in almost the center of the screen.
I'm wondering if BenQ will replace it for me with only one stuck pixel.
zambine is offline
post #1325 of 1358 Old 03-09-2020, 04:03 AM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
That happened to my launch unit, they replaced it, no questions asked.
zambine likes this.
diablo900t is online now
post #1326 of 1358 Old 03-09-2020, 04:54 PM
Liked: 0
Just got the HT5550 delivered. Set it up on a table to check firmware before mounting it and about 2-3 mins after starting it the red temp light blinks and the projector shuts off. Guessing im going to be calling benq tomorrow. Bummer being without a projector and having to take another day off work.
Cinemiya is offline
post #1327 of 1358 Old 03-09-2020, 06:55 PM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
That sucks...definitely get them to send you a new one overnight. I'm sure they will.
post #1328 of 1358 Old 03-10-2020, 08:16 AM
Liked: 0
I got off the phone with BenQ support and they wanted to repair it, I was under the impression DOA items got replaced. Plus she told me about 2 weeks which is crazy.
Cinemiya is offline
post #1329 of 1358 Old 03-10-2020, 09:00 AM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
Call back and speak with another rep. Did you buy it from them directly?
post #1330 of 1358 Old 03-10-2020, 09:24 AM
AnnapolisSony's Avatar
Quoted: 154 Post(s)
Liked: 214
@Cinemiya , I am close to purchasing this PJ and posts like these are not helping the cause! Did you buy direct from BenQ or through a dealer?
AnnapolisSony is offline
post #1331 of 1358 Old 03-10-2020, 09:29 AM
Liked: 0
From an authorized distributor.
I got it through projector people and it was dropped shipped from BenQ. The dealer ended up solving the issue but it was frustrating dealing with BenQ low level support. I think the dealer went through their rep to fix it.
Cinemiya is offline
post #1332 of 1358 Old 03-10-2020, 11:16 AM
Quoted: 154 Post(s)
Liked: 214
Good to hear. That's exactly who I was planning on buying from, Projector People. I bought my EPSON 5030 from them back in 2013 and I've bought three other PJs for my office. Great company to deal with IMO.
post #1333 of 1358 Old 03-14-2020, 05:01 AM
weerawath's Avatar
Angry Benq dead pixel warranty
Dear all benq w5700/ht5550 user, firstly please apologize my poor english.
I bought w5700 in thailand back in december last year. it is my second projector (upgrade from w1070). during initial use I saw a bright pixel at the right edge of the screen which did not bother me too much since it is outside of frame. so I let it be not much concern.
But after two months during mid February, I started experiencing anormaly behavior like attach link to youtube video below. The w5700 frequently freez in a middle of nowhere on occation events. sometime quite often like every few minutes while another time hours.
I extensively ran many test to find the source of problem by change 2 players (PC and apple tv), 3 hdmi cable, 2 avr hdmi inputs, 2 avr hdmi outputs, 2 benq w5700 hdmi inputs and finally connect the player directly to the benq. Finally my conclusion was benq w5700 hdmi 1 input cause the problem. I always turn off every equiptments before plug and unplug everythings.
Then the dark pixel suddenly appear in a middle of the screen like this.
I contact the store I bought w5700 from they took it back and inform me today that benq thailand are going to fix it within two weeks.
fix it not replacing it, I don't happy with this but don't know how the replacement policy on those bad pixels on projector. and one more trouble on hdmi 1.
I thing the bad pixels warranty policy should be the same across the globe.
how does benq react to defect like this in another countries? anybody having experience like this? please let me know.
ID:	2697460   Click image for larger version
ID:	2697462   Click image for larger version
weerawath is offline
post #1334 of 1358 Old 03-17-2020, 07:23 PM
weerawath's Avatar
Finally after direct contact benq thailand ,not via the store I bought from, they will change the new unit.
Thank ypu Benq thailand.
maglo125 likes this.
post #1335 of 1358 Old 03-25-2020, 05:28 PM
Quoted: 24 Post(s)
I'm thinking about purchasing an HT5550 pretty soon. Some of the issues mentioned on this thread have me worried that I might have to RMA at some point.
I just spoke to to BenQ on the phone and they are telling me that I must purchase from an authorized dealer or I will not receive be able to receive any warranty support. This is apparently their company line despite there being absolutely no language in their warranty fine print stating this.
Can anyone that purchased from an non-authorized dealer and had to RMA confirm or deny this statement from BenQ?
Just curious; why do you want to buy from a non-authorized dealer instead of BenQ directly? Other projector brands all have their own “de-authorized reseller” list because there are companies (or individuals) not able to follow rules like putting a used projector in a new package and reselling to people like you in all marketplaces like eBay or amazon or Walmart. If you were able to talk to someone at BenQ, try tell them your concern why those “non-authorized dealers” are better to see how they can help you. Also my understanding and experience is the manufacturer warranty will be only void on the purchases from “de-authorized resellers/dealers”, not “non-authorized ones”. Check BenQ website and search “deauthorized” to see if the dealer you are planning to buy from us on their list. Good luck!
Jeffrey Chiafu Hsieh is offline
post #1336 of 1358 Old 03-25-2020, 06:48 PM
Mike Butny's Avatar
Quoted: 1204 Post(s)
Liked: 2866
HT5550 vs HT8050. Has anyone compared these two projectors?
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is online now
post #1337 of 1358 Old 03-25-2020, 08:54 PM
Liked: 0
So does BenQ have their de-authorized reseller list on their website? Just curious!
maglo is offline
post #1338 of 1358 Old 03-25-2020, 10:57 PM
Quoted: 24 Post(s)
I googled it and found this: https://www.benq.com/en-us/support/d...sheet-001.html
I went to BenQ site and found this: https://www.benq.com/en-us/support/r...on.html%5b/url
maglo125 and maglo like this.
post #1339 of 1358 Old 03-26-2020, 03:57 PM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
I haven't seen anything. I'd be curious to see how it stacks up against the NX7/RS2000 too, even though I know they are in 2 different price ranges.
Todd G. likes this.
post #1340 of 1358 Old 03-27-2020, 05:19 PM
Liked: 3
Funny thing is everyone seems to think the Epson TW 9400 has superior PQ just because of the better blacks, I auditioned both and bought the BenQ W5700 as it had a sharper and smoother more film like picture, I could see screendoor and digital looking image due to the lower pixel shifting of the enhanced 4k technology of the Epson.
True the motorized lense control is superior but I don't have a 2:35 screen and once my PJ is setup I never touch the focusing or zoom anymore.
Sent from my SM-G965F using Tapatalk
diablo900t and AnnapolisSony like this.
Stephen_Ang is offline
post #1341 of 1358 Old 03-27-2020, 05:58 PM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
I haven't compared it to the newer Epsons but my old Epson 2045 used to have the dirty screen effect really badly on panning shots. Same for my Samsung KS8500, I really couldn't stand it.
I know people crap on the black levels of DLP, but the motion clarity is so much better than LCD tech.
post #1342 of 1358 Old 03-28-2020, 02:39 AM
Quoted: 1367 Post(s)
Liked: 398
Preference is subjective.
It's difficult to get projectors properly set up in the right room, with the right personnel, etc.
How big was the screen and from what distance were you viewing it?
noob00224 is online now
post #1343 of 1358 Old 03-28-2020, 03:21 AM
Liked: 3
You can see one member's Scott review of the TW 9400 vs the BenQ 5700 on YouTube, he showed the difference in resolution and the LCD enhanced 4k definitely inferior and the shootout pics masked side by side he actually said the picture quality BTW the two were awash.
post #1344 of 1358 Old 03-28-2020, 08:49 AM
PannyMan87's Avatar
Hello,
I am considering this projector and am trying to find some pictures that show the performance with a few overhead can lights turned on.
PannyMan87 is offline
post #1345 of 1358 Old 03-28-2020, 09:33 AM
Liked: 1
Originally Posted by PannyMan87 View Post
Hello,
I do not think that the HT5550/W5700 is a good choice for a lit room. Choose a brighter projector for that purpose.
Pehu is offline
post #1346 of 1358 Old 03-28-2020, 10:29 AM
diablo900t's Avatar
Quoted: 101 Post(s)
Liked: 63
Hello,
It's designed for a light controlled room. It just doesn't have the lumen output to contend with ambient or artificial light.
You might want to look at the TK800 or an LCD projector.
post #1347 of 1358 Old 03-28-2020, 12:00 PM
jcr159's Avatar
Quoted: 234 Post(s)
Liked: 124
Ummm... the screen is really the only important part when you are in a partially lit room.... bright or not, a uni gain screen will be very washed out...
Have a question and want it answered in podcast format?
[email protected]
http://www.avrant.com/
https://www.youtube.com/c/avrant
jcr159 is offline
post #1348 of 1358 Old 03-28-2020, 12:35 PM
michaelscott73's Avatar
Quoted: 16 Post(s)
Hello,
. You could probably get away with the can lights on in the back of a basement.....like 12 feet or more away from the screen. Anything closer and it’s not going to work. I have Back lights on in a basement 14 feet away in this picture. It’s watchable.
michaelscott73 is offline
post #1349 of 1358 Old 03-28-2020, 10:35 PM
Liked: 398
If you pause and analyze each picture then you'll find more issues then there actually are. It's not easy to make judgements on pictures/video on the internet.
In real life content the higher contrast of the Epson would have and advantage. It's also significantly brighter. But it's the user's preference that ultimately counts.
You still haven't mentioned the size of the screen and room environment where both projectors were auditioned.
Hello,
What is the source and intensity of the ambient light? How far away are the lights from the screen?
post #1350 of 1358 Old 03-28-2020, 10:51 PM
ac388's Avatar
Quoted: 204 Post(s)
Liked: 52
Wonder if anyone here using W5700 with the new HDfury Vertex2 for Dolby Vision ? If yes, would like to share the settings on Vertex2 as well as on the BenQ.
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
