Suggestions for an attachment lens for Optoma HD142X to get shorter throw - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-16-2019, 07:24 PM - Thread Starter
Liked: 7
I have a small room and would like a bigger picture. Is there any lens I can add to shorten the throw distance? I have zero experience doing this. I've been looking at this, recommended by a YouTuber for another projector, but I am wondering if it would fit. https://www.amazon.com/gp/product/B0...B98W97QPMCQDDQ
I measured the projector lens area and it is exactly 60 mm.
Any suggestions?
Haisook is offline
post #2 of 3 Old 02-16-2019, 07:30 PM
AV_Integrated's Avatar
Quoted: 1551 Post(s)
Liked: 1145
Any inexpensive attachment lens is likely to add some distortion to your image. If you have the 143x already, then I suppose you are stuck with what it is. If you are just looking for a inexpensive projector that is short throw and a cheap way to convert, then I wouldn't go that route, but would get a short throw projector instead.
Some people also make/buy a inexpensive mirror and bounce the image off the mirror to the screen. This increases your throw distance in a smaller room.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 3 Old 02-17-2019, 07:46 AM
bud16415's Avatar
Quoted: 1988 Post(s)
Liked: 1005
Here is what I did and it worked great for 3+ years until I upgraded to a shorter throw projector.
https://www.avsforum.com/forum/110-d...tiny-room.html
Bud
bud16415 is offline
Optoma , optoma hd142x
