BenQ HT3550 True 4K Home Cinema Projector Review - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 263Likes
post #511 of 525 Old 08-08-2019, 06:09 PM
skylarlove1999's Avatar
Quoted: 347 Post(s)
Liked: 278
Originally Posted by mapleoak View Post
Moving out of Optoma 50 UHD (Thanks Amazon for honoring warranty) and Jumping into BenQ 3550...what say you?
I say you chose wisely. I imagine you're going to be very happy with your new projector.
Sent from my SM-G965U using Tapatalk
ng4ever and mapleoak like this.
skylarlove1999 is online now
post #512 of 525 Old 08-08-2019, 06:28 PM
Quoted: 14 Post(s)
Liked: 2
Thanks! I luv Optoma 4k (not so much 1080 p) but when you are addicted to 4k/UHD and that port stops working within weeks in two separate units...what choice I have?
mapleoak is offline
post #513 of 525 Old 08-08-2019, 06:30 PM
Quoted: 36 Post(s)
Liked: 9
After several days of playing with the new 3550 it no longer illuminates. It’s been taking longer to start up each day often 5-10 minutes but now nothing. The green light indicating normal operation is on but the bulb itself isn’t. I can probably open the bulb compartment to possibly tighten the bulb but that might violate the “in new condition” stipulation for Amazon returns.
Deleted some negative observations about the 3550 since I obviously received a defective unit.
HTCrazy2 is offline
post #514 of 525 Old 08-08-2019, 08:11 PM - Thread Starter
sage11x's Avatar
Quoted: 2690 Post(s)
Liked: 2658
Originally Posted by smurfee View Post
I was so excited for the 2550 when it was announced that I bought it the day it came out, and now I feel as though the it has all but faded away. Should I be kicking myself for not waiting for the 3550?
What skylar said.
The thing about tech is it’s constantly leapfrogging the prior generation hardware. So, yeah, the HT3550 is a big improvement over the HT2550 but so too will the next projector that is introduced after the HT3550.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #515 of 525 Old 08-09-2019, 08:06 AM
tibimakai's Avatar
Quoted: 155 Post(s)
Liked: 48
If the bulb wouldn't be installed properly, I'm pretty sure an error would pop up(LED light error).
I would return it.
Living Room: Samsung UN65JS8500, Onkyo TX-NR656, Klipsch R-28F, Klipsch RC-62II, Klipsch R-14S, Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290, Onkyo TX-RZ610, Onkyo & Fluance speakers
Garage: Benq HT2050A, Elite Screens 125" motorized screen, Klipsch RP-160M, Klipsch RP-150M, Klipsch RP-450C , 2 x Klipsch CDT-3800 II for Atmos, Klipsch RW10
tibimakai is offline
post #516 of 525 Old 08-09-2019, 08:19 AM
Quoted: 36 Post(s)
Liked: 9
I would return it.
Exactly what I was thinking. It's boxed and headed to Amazon today. Ugh. Now I'll probably just hold out for the Optoma P1 to hit the streets along with a few initial reviews.
HTCrazy2 is offline
post #517 of 525 Old 08-09-2019, 08:35 AM - Thread Starter
sage11x's Avatar
Liked: 2658
If you’re in the return window I might just swap it out. If not I’d contact BenQ— it has a 3 year warranty.
Edit: just saw your post above. Sorry for the confusion.
ng4ever likes this.
sage11x is offline
post #518 of 525 Old 08-13-2019, 12:56 PM - Thread Starter
sage11x's Avatar
Liked: 2658
Hey folks, a quick heads up to anyone who is in the market for one of BenQ’s projectors:
As many of you know there will be a 10% tariff imposed on projectors starting 9/1/2019. My contact at BenQ has assured me they are working hard to make sure they minimize the impact these tariffs will have on their customers but that we should expect a price increase sometime in the next 30-90 days.
If you’re on the fence about jumping in this might be a good time to get off that fence.
sparky7 and ng4ever like this.
sage11x is offline
post #519 of 525 Old 08-14-2019, 05:11 PM
Liked: 1
HT3550 Ceiling Mount Help
Good Evening,
Today I just received my HT3550 and the following ceiling mount (I can't post links or pictures because I just joined): VIVO Universal Adjustable White Ceiling Projector | Projection Mount Extending Arms Mounting Bracket (MOUNT-VP01W)
Unfortunately the mount does not fit the projector. Can anyone link me to a mount they are using / that works for the HT3550? I would also love to see pictures of your ceiling mounted HT3550.
Thank you!
ng4ever likes this.
vtcrom is offline
post #520 of 525 Old 08-14-2019, 05:15 PM
Quoted: 619 Post(s)
Liked: 325
Originally Posted by vtcrom View Post
Good Evening,
Thank you!
In what way doesn't it fit? I used a nearly identical mount with my W1070.
ng4ever likes this.
DunMunro is online now
post #521 of 525 Old 08-14-2019, 05:24 PM
Liked: 1
The bracket wouldn't fit on the hole nearest to the lens on the left side. There is a raised section in the chassis and I can't articulate the arm in the right direction for it to fit.
vtcrom is offline
post #522 of 525 Old 08-14-2019, 06:44 PM
Quoted: 619 Post(s)
Liked: 325
This video at 6:08/11:14 shows a similar mount and it shows the use of spacers between the arms and the mounting hole:
I recall having to do some mental gymnastics, but I suspect that your mount will work if you take a 2nd look. You may have to detach and re-position the arms.
Hmmm...IIRC, I actually had to drill another hole in one the arms to allow that arm to attached to the mount, to get it to fit one of my projectors.
post #523 of 525 Old 08-14-2019, 08:56 PM
Quoted: 14 Post(s)
Liked: 2
Finally BenQ is up and running with X6500H. Happy but cautious.
Question: Power Indicator is magenta/orange after turning off Nothing in Temp /Lamp (as expected), however the On/Off switch stays Green , is it normal?
mapleoak is offline
post #524 of 525 Old 08-14-2019, 08:57 PM
Quoted: 14 Post(s)
Liked: 2
This worked , but has to be extended a lot compared to Optoma
VIVO Universal Extending White Ceiling Projector Mount | Height Adjustable Projection (MOUNT-VP02W)
mapleoak is offline
post #525 of 525 Old 08-15-2019, 09:00 AM - Thread Starter
sage11x's Avatar
Liked: 2658
I ran into a similar issue. The raised section is kind of a pain in the butt. A quick trip to the hard ware store for some longer screws and washers/spacers was the solution for me.
sage11x is offline
benq ht3550 , benq ht3550 not turning on , broken projector , projector troubleshooting
