BenQ HT3550 True 4K Home Cinema Projector Review - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 272Likes
post #541 of 565 Old 01-08-2020, 08:44 PM
Quoted: 82 Post(s)
Liked: 58
Originally Posted by jimjimmyjones85 View Post
Does anyone have any calibration settings they are willing to share for a completely light-controlled room?
I am about to set mine up and would love to have a good starting point.
Thank you.
D. Cinema mode for non-HDR is already factory calibrated. Just ensure Brilliant Color is turned OFF and most find 4K pixel enhancer best around 6
For HDR, make sure wide color gamut is ON and Brilliant Color is OFF.
You don’t need to play around with color hues and gammas etc on this projector. Just ensure you use D Cinema for non-hdr and the four main settings are always correct:
Wide color gamut: ON
Brilliant Color: OFF
4K pixel enhancer: set to taste, likely 6-8
Sharpness: set to taste, likely halfway or lower
Oh and Dynamic Iris to taste: likely HIGH in a light controlled room
noob00224 and maglo125 like this.
Fastrabbit19 is offline
post #542 of 565 Old 01-08-2020, 08:49 PM
Roy G Biv's Avatar
Quoted: 39 Post(s)
Originally Posted by noob00224 View Post
Treatment would improve black level.
Dark paints or fabrics. Around 5' around the screen, ceiling included.
Ideal example:
https://www.facebook.com/projectiond...2721894385217/
Was is that?
Roy G Biv is offline
post #543 of 565 Old 01-08-2020, 09:05 PM
Quoted: 1735 Post(s)
Liked: 515
Originally Posted by Roy G Biv View Post
Was is that?
What do you mean?
noob00224 is online now
post #544 of 565 Old 01-08-2020, 10:48 PM
Roy G Biv's Avatar
Quoted: 39 Post(s)
What do you mean?
The conjoined wall-ceiling blackout fabric that pulls out?
post #545 of 565 Old 01-08-2020, 11:02 PM
Liked: 515
It's a velvet curtain, was just an example on how eliminating reflections would help with black level.
You don't have do it that way.
Just some dark paint and some curtains on the side. A dark rug on the floor. The HT3550 would also benefit from this.
Here is a discussion of someone trying to treat their room with paint/fabrics:
https://www.avsforum.com/forum/15-ge...vs-velvet.html
post #546 of 565 Old 01-18-2020, 12:27 PM
Liked: 0
Power on
Okay, I switched from the HT1075 to the HT3550. My HT1075 came on whenever I powered on my receiver, but the HT3550 does not. I just upgraded to the latest firmware but still doesn't do it. Any ideas?
Carl Banman is offline
post #547 of 565 Old 01-18-2020, 09:57 PM
Quoted: 82 Post(s)
Liked: 58
There is a 12v trigger but I’ve never used it; there is a menu setting to enable it if that’s what you are using.
I just turn it on with the BenQ remote each day but I use Alexa for everything else in the theater (lights and receiver) so if there is a way to Alexa power this projector by using receiver or another device, that’d be cool.
post #548 of 565 Old 03-04-2020, 04:22 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Should I be worried about buying a used BenQ HT3550? Any issues with these projectors?
Sent from my GM1917 using Tapatalk
bori is offline
post #549 of 565 Old 03-04-2020, 06:39 AM
dbpaddler's Avatar
Quoted: 192 Post(s)
Liked: 127
Harmony Remote/Hub. Could always get the basic one for $60 give or take and use your existing remotes to do things while you're using the system and just use Alexa to turn on and off. Just never turn things on or off without using Alexa or the harmony remote or you'll throw it off the next time.
Sent from my SM-N975U1 using Tapatalk
dbpaddler is online now
post #550 of 565 Old 03-04-2020, 10:34 AM - Thread Starter
sage11x's Avatar
Quoted: 3053 Post(s)
Liked: 3168
There were quite a few QC issues at launch but many of those issues have been ironed out with fwupdates. Are you buying used or refurbished?
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #551 of 565 Old 03-04-2020, 10:35 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Used. Anything I need to look out for? What is the latest firmware?
bori is offline
post #552 of 565 Old 03-04-2020, 12:49 PM - Thread Starter
sage11x's Avatar
Liked: 3168
1.0.5. FYI the firmware is user upgradeable.
Known issues early on (that were not fixable via firmware and required a visit to BenQ for service) a ‘half screen’ issue where the color filter seemingly fails to fully engage and so each half of the image looks slightly different. There was also an improvement to the dynamic iris to make it less noticeable in operation— early models were prone to a high degree of pumping/flickering. While all dynamic iris solutions will result in some pumping, BenQ has all but sorted this out and new modes have much better iris implementation.
bori likes this.
sage11x is offline
post #553 of 565 Old 03-05-2020, 04:10 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
I have blueriggers 50FT HDMI cables that I bought years ago for my 3D w1070 projector. Do I have to replace those cables to support 4K? Or will they work just fine?
bori is offline
post #554 of 565 Old 03-05-2020, 05:25 AM
Liked: 1
Best would be to just try it first. Generally, for 4K, at 60 frames per second, with HDR, you should get 18 Gbit/s "Premium High Speed HDMI Cable".
However, you can lower the required bandwidth by not using HDR, or lower resolution or fps.
When I got HT3550, for a few days I was using just some regular 32ft cable just fine, by lowering the fps to 30 on menus and 24 on movies.. Then I got fancy 18 Gbit/s 65ft optical cable for ceiling mounting the PJ. You can newer go wrong with those, bu they are a bit pricier.
PepaZdepa is offline
post #555 of 565 Old 03-05-2020, 05:53 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Is there some video test i do to see if the cables are not working? That can provide me the bitrate at which the video is running at?
bori is offline
post #556 of 565 Old 03-05-2020, 06:59 AM
Liked: 1
Just connect it to PC and try different combinations of resolution/fps/hdr. If you get no image at all or dropouts, lower some of those three.
Note that it depends on each link in PC -> AVR -> PJ. Some may have better/worse/sensitive hardware in their HDMI ports and [email protected] may work on one TV but not on the other. (If you do not have the PJ yet)
post #557 of 565 Old 03-05-2020, 07:05 AM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Yes I do have the PJ and will set up today.
bori is offline
post #558 of 565 Old 03-05-2020, 07:06 AM
Liked: 1
re-reading that, I didn't really answered your question.
When you get working combination, you can quesstimate the required bandwidth for example from tables here
https://en.wikipedia.org/wiki/HDMI#R...standard_video
post #559 of 565 Old 03-05-2020, 12:21 PM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
What are the best picture settings? Anyone posted the best setting for this projector. I know it varies from room to room. But would like somewhere to start.
bori is offline
post #560 of 565 Old 03-05-2020, 02:16 PM
dbpaddler's Avatar
Quoted: 192 Post(s)
Liked: 127
Check out the owners thread. Seems to he some consensus on basic settings.
post #561 of 565 Old 03-05-2020, 02:39 PM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
I thought this was the owners thread?
bori is offline
post #562 of 565 Old 03-05-2020, 04:20 PM
bori's Avatar
Quoted: 277 Post(s)
Liked: 145
Nevermind found it. Thanks
bori is offline
post #563 of 565 Old 05-19-2020, 08:41 AM
Liked: 1
I recently received my HT3550, and the other day I noticed little red 'pixels' in the bottom centre of the image (very bottom). I was pondering a return, but now they are gone (or have turned white and therefore harder to see)
Has anyone ever encountered this before?
Craig Marshall is offline
post #564 of 565 Old 05-19-2020, 07:38 PM
jimchao's Avatar
Quoted: 55 Post(s)
Liked: 49
Please try my HDR setting calibrate by i1por2 in my light control room.
This setting only applys when HDR is actived.
HT3550 HDR SETTING
Thank you.
maglo125 likes this.
BDP:Sony UBP-X800 LCR:M&K MPS2510 Surround:M&K MPS1625×4 SUB:Rythmik FV15HP HT Prepro:Lexicon MC12B EQ/Anthem MRX510 Power Amp:Lexicon RX7
Stereo:Music server HTPC i5 Jriver Preamp:Bremester 897+MBL 1511F DAC USB Power Amp:Monarchy Audio SE-100 Pure Class A mono mono PJ: HT3550, Acoustical 135” gain 1.2 ** HDR Setting of HT3550** Measurement of HT5550
jimchao is offline
post #565 of 565 Old 05-23-2020, 12:49 PM
Liked: 0
Hi ,
Please help me choosing Sony Hw45es and BENQ HT3550. I am really confused because I found both with similar price and warranty. 1050 USD . Hw45es is 1080p and ht3550 is 4k. But i heard sony at 1080p is better than most 4k.
Sent from my GM1910 using Tapatalk
sagarsamtani is offline
benq ht3550 , benq ht3550 not turning on , broken projector , projector troubleshooting
