THE Epson 5050UB/6050UB Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 1280Likes
post #1981 of 4367 Old 06-20-2019, 04:58 PM
sddawson's Avatar
Quoted: 286 Post(s)
Liked: 49
Originally Posted by Kelvin1000 View Post
It’s strange because I still can’t do frame interpolation and e-shift simultaneously...
I think I got to the bottom of this. It only works with both on for 24Hz content. Fine for movies, but would have been nice for it to work with 50/60Hz for sports broadcasts. Probably a lack of puff in the processor...
sddawson is offline
post #1982 of 4367 Old 06-20-2019, 06:59 PM
Ladeback's Avatar
Quoted: 1401 Post(s)
Liked: 519
Send a message via MSN to Ladeback
Originally Posted by skylarlove1999 View Post
My Samsung S9 phone on the Verizon network updated to Advanced messaging last night and now it doesn't really play nicely it appears with AVS forum. So I am now using Tapatalk and I believe those posts were correctly I'm writing with it right now
Sent from my SM-G965U using Tapatalk
It's also easier to post photos on Taptalk.
Sent from my SM-N960U using Tapatalk
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #1983 of 4367 Old 06-20-2019, 07:05 PM
skylarlove1999's Avatar
Quoted: 1031 Post(s)
Liked: 718
That is true but I can't figure out how to copy and paste the URL for anything LOL I am not tech savvy when it comes to my phone.
skylarlove1999 is offline
post #1984 of 4367 Old 06-20-2019, 07:08 PM
Liked: 718
Turn Match Dynamic Range or Match Frame Rate on or off
Go to Settings > Video and Audio > Match Content, then choose from the following:
Match Dynamic Range: Turn on to have Apple TV 4K match its output to the original dynamic range of content that you’re watching.
Match Frame Rate: Turn on to have Apple TV 4K or Apple TV HD match its refresh rate to the original frame rate of content. This applies to content that's mastered at different frame rates, for example 24fps film-based content or other international content.2
If you turn on either of these settings, Apple TV will attempt to automatically determine which dynamic ranges or frame rates your television supports.
post #1985 of 4367 Old 06-20-2019, 08:28 PM
sddawson's Avatar
Quoted: 286 Post(s)
Liked: 49
I think you might be responding to the wrong post. I was talking about the circumstances under which you can have 4K enhancement and frame interpolation turned on on the projector at the same time.
sddawson is offline
post #1986 of 4367 Old 06-20-2019, 09:22 PM
Liked: 0
EPSON 5050UB Apple TV 4K Issue
Hey guys, having an issue with getting 4k to work on my apple tv with my epson 5050ub. I've connected it all up using HDMI 2.0as via port 1. However, in settings for apple TV it only goes up to 1080p 60Hz, and not 4k. Was wondering if i could get any help with this.
Cheers
Ishmam Murshed is offline
post #1987 of 4367 Old 06-20-2019, 09:48 PM
Liked: 0
Hey all, having trouble with 4k on my apple tv 4k with the 5050ub. In the settings for apple tv, there isnt a 4k option, the best option is 1080p. Is this intentional due to the 1080p native res, or should there be an option in the settings for 4k.
post #1988 of 4367 Old 06-20-2019, 10:14 PM
Quoted: 29 Post(s)
Depends what you have it plugged into. I have to set my AV7704 HDMI to extended before it will pass through correctly. EDID on the 5050 etc. Apple TV has to see it offering 4K...
Marantz AV7704 Oppo UDP 205 B&K 200.7 S2 Marantz MM7055 M&K S-150THX 7.2.4 w/350 &100 subs Furman IT-REF 15I XBOX-OneX Apple 4K TV Sony PS4 Samsung 4K 65" Epson 5050UB Apple HomePod (4) Harmony Elite Amazon Alexa Xfinity X1 4K Audioquest wire A-Z (there is a difference) Spectracal CalMAN Home Enthusiast X-rite i1 Photo Pro 2
misterg51 is offline
post #1989 of 4367 Old 06-21-2019, 01:06 AM
Liked: 0
How did you turn the amp to extended, I have a SR6013 from marantz, im sure that this is also sufficient enough.
post #1990 of 4367 Old 06-21-2019, 04:10 AM
Luminated67's Avatar
Quoted: 724 Post(s)
Liked: 399
It will be the same as my Denon was, basically go to the menu on the amp, select VIDEO and then select 4K SIGNAL FORMAT, in there you will see the setting to switch between standard and extended.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
post #1991 of 4367 Old 06-21-2019, 06:02 AM
Liked: 0
I changed it to enhanced, and changed the EDID on the 5050 to enhanced aswell, but still no 4k option on apple tv. Any other amp settings, I had an installer do this setup, and im rather new to this stuff. Any help is appreciated, thanks .
post #1992 of 4367 Old 06-21-2019, 06:04 AM
Liked: 718
post #1993 of 4367 Old 06-21-2019, 06:21 AM
Liked: 0
Ive put both those settings on, changed both EDID on my amp+ projector to expanded, put my amp on play-through for the projector. Anything else i can try??
ID:	2582678   Click image for larger version
post #1994 of 4367 Old 06-21-2019, 06:44 AM
Liked: 718
When you connected the A4KTV directly to the projector does the A4KTV display 4K 60HZ HDR? Have you tried running your setup with different cables? Are you using Fiber optic or copper HDMI cables? Have you tried the same exact setup using a 4K television in the chain in place of your projector? Honestly A4KTV historically has these issues. They made some updates to the latest model that were supposed to have addressed these shortcomings. Sorry I know it is incredibly frustrating. Try turning the match frame rate off. Is there a way to force 4k at 60hz?
post #1995 of 4367 Old 06-21-2019, 07:11 AM
Liked: 0
Yeah, its kinda of annoying. I might try switch from apple tv to another streaming device. I'll have another chat to my installer. Thanks again for the help.
post #1996 of 4367 Old 06-21-2019, 07:50 AM
zenoran's Avatar
Quoted: 21 Post(s)
Do you have anything plugged in monitor 2?
zenoran is offline
post #1997 of 4367 Old 06-21-2019, 07:53 AM
Liked: 718
I have the Epson 6050 with a Denon 6500 and a Roku Ultra and I don't have any problems
post #1998 of 4367 Old 06-21-2019, 07:54 AM
Liked: 718
I have the Epson 6050 paired with a Denon 6500 receiver and a Roku Ultra player and I have no issues
post #1999 of 4367 Old 06-21-2019, 08:30 AM
LIPLASMA's Avatar
Quoted: 26 Post(s)
Blu ray Player
I was looking to buy a new 4k player to go along with my 6050UB and wanted to see if any of you have used the Panasonic DP-UB820 with the projector? if so did you see a noticeable difference using the players HDR tone mapping vs the internal Epson tone mapping? I know its all the rage on the JVC's with its tone mapping.
LIPLASMA is offline
post #2000 of 4367 Old 06-21-2019, 02:04 PM
Quoted: 29 Post(s)
This is very true, the vast majority of people will be satisfied by its out of box settings especially Natural and Digital Cinema. When I got mine I put in my trusty calibration disc and adjusted the contrast and brightness to what it suggested..... imagine my shock when Gordon put both these two settings back to 50/50 and said these along with colour and tint need no adjusting as these are spot on right out of the box. What a professional calibration does (well my take on it) is fine tune an already well calibrated machine.
My money is on the Apple TV and the issue is your installer. My 4K Apple TV saw my 5050 as 4K HDR immediately.
post #2001 of 4367 Old 06-21-2019, 02:06 PM
Liked: 718
Honestly what kind of installer leaves before checking everything is running correctly and optimally. I feel so bad for this guy. I would definitely be asking for some of my money back.
post #2002 of 4367 Old 06-21-2019, 07:24 PM
Quoted: 29 Post(s)
There are a 1080 and a 4K model that look identical...... wrong one installer?
post #2003 of 4367 Old 06-21-2019, 08:23 PM
Liked: 0
It is a 4k apple TV, just checked the mode. Yeah something wrong with the amp/apple TV, cables are these ones - https://www.blustream.co.uk/precision-18-hdmi. Im pretty sure its a software issue rather than hardware.
post #2004 of 4367 Old 06-22-2019, 05:39 AM
Liked: 1
Do you have a 4k TV to try your Apple TV
Regards
Envoyé de mon iPad en utilisant Tapatalk
danield71 is offline
post #2005 of 4367 Old 06-22-2019, 08:13 AM
bommai's Avatar
Quoted: 624 Post(s)
Liked: 203
Cheers
I have Apple TV 4K hooked up to my epson 5040UB through a denon 4300 receiver and it does 4K no problem. Is the hdmi cable capable of 4K? Does your Apple TV work with another tv at 4K. Do you have the latest software for the Apple TV?
Sent from my iPhone using Tapatalk Pro
bommai is offline
post #2006 of 4367 Old 06-22-2019, 10:26 AM
Quoted: 724 Post(s)
Liked: 399
What’s the length of the HDMI cable being used?
post #2007 of 4367 Old 06-22-2019, 05:29 PM
SuperMiguel's Avatar
Quoted: 173 Post(s)
any idea when will the projector drop to 2699 again?
SuperMiguel is offline
post #2008 of 4367 Old 06-22-2019, 06:15 PM
Liked: 718
Sounds like somebody didn't pull the trigger and has got not buying remorse right now. Sorry for your pain. Check out Best Buy tomorrow maybe they do something for Independence Day and the Women's World Cup.
post #2009 of 4367 Old 06-23-2019, 11:23 AM
drhankz's Avatar
Quoted: 143 Post(s)
Liked: 94
Why be so cheap just buy it
drhankz is offline
post #2010 of 4367 Old 06-23-2019, 11:28 AM
Liked: 718
Not that low but check out Best Buy today. 24 month free financing as well.
5050 , Epson , frame interpolation , motion smoothing
