THE Epson 5050UB/6050UB Thread - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 1197Likes
post #2011 of 3871 Old 06-23-2019, 10:37 AM
SuperMiguel's Avatar
Quoted: 173 Post(s)
Originally Posted by skylarlove1999 View Post
Originally Posted by SuperMiguel View Post
any idea when will the projector drop to 2699 again?
Not that low but check out Best Buy today. 24 month free financing as well.
Sent from my SM-G965U using Tapatalk
I didnt do the financing part but I did buy it. Lol one of my local (20miles away) had it. Just left the store with it. I really hope its better than mine ht3550 lol I will be comparing them tonight. Any suggestion on ceiling mount??
SuperMiguel is offline
post #2012 of 3871 Old 06-23-2019, 10:46 AM
JonfromCB's Avatar
Quoted: 216 Post(s)
Liked: 156
Lengthy discussion on mounts several pages back.
JonfromCB is offline
post #2013 of 3871 Old 06-23-2019, 06:20 PM
Barrettmr's Avatar
Quoted: 140 Post(s)
Liked: 45
I currently have the 5020UB with a run of 25' to my AV closet so I use the monoprice redmere cable detailed below. If I upgrade to the 5050UB to watch 4K movies, will this cable be good enough or would it need replacing? Confused with the speed ratings and what is needed to watch 4k HDR movies from my Pano 820...The spec on the cable below says 10.2Gbps but I saw something about this new projector supports 18Gbps which sounds like my current 25' redmere would have to be replaced? :-(
Thanks!!
Reliably connect your home theater equipment to greater distances than with passive cables using this Select Active Series High Speed HDMI® Cable with RedMere® Technology from Monoprice!
This High Speed HDMI Cable supports the following general features:
Active signal regeneration to ensure accurate reproduction over longer distances
10.2Gbps data throughput
VW-1 in-wall fire safety rating
28AWG copper conductors
Gold plated connectors
It supports the following HDMI features:
1080p resolution at 60Hz
4K resolution at 24Hz
3D video
Audio Return Channel
Deep Color up to 16-bits per channel
x.v.Color™
High Definition Audio, including SA-CD, DVD-Audio, DTS-HD Master Audio™, and Dolby TrueHD™
Epson 5050UB - Falcon Screens AT 131"
Onkyo TX RZ830 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 2 sets 80F/X-LS Atmos & LSiM703 surrounds - Dual SVS PB2000 subs
Panasonic DP-UB820 - HTPC with Emby
Barrettmr is offline
post #2014 of 3871 Old 06-23-2019, 06:27 PM
skylarlove1999's Avatar
Quoted: 840 Post(s)
Liked: 593
Thanks!!
Reliably connect your home theater equipment to greater distances than with passive cables using this Select Active Series High Speed HDMI Cable with RedMere Technology from Monoprice!
3D video
x.v.Color
High Definition Audio, including SA-CD, DVD-Audio, DTS-HD Master Audio, and Dolby TrueHD
Really depends on your media player and the source. Your current cable supports 4K at 24hz which is the streaming rate for many apps that support 4k and HDR. Depending upon your media player some apps may send 4K/60FPS which the 5050 will receive but your cable will not support that signal many times also referred to as being 18GBPS compatible. So you probably want a new cable. You can certainly try the 5050 with all your current setup and see how it works.
skylarlove1999 is online now
post #2015 of 3871 Old 06-23-2019, 08:23 PM
Quoted: 173 Post(s)
Looked few pages back and didnt see it. I looking for a single beam one. I just have one bean not sure why all these mounts have 4 holes.
post #2016 of 3871 Old 06-24-2019, 07:39 AM
JonfromCB's Avatar
Quoted: 216 Post(s)
Liked: 156
Starts at post #1467 . Discussion is about mounts and alignment but you should find all you need on mounts there. Good luck
post #2017 of 3871 Old 06-24-2019, 07:52 AM
JonfromCB's Avatar
Quoted: 216 Post(s)
Liked: 156
Thanks!!
3D video
x.v.Color™
Barrettmr, The active cables with "redmere" chips won't support speeds above 10.2 Gbs or 60hz. They have been replaced by the new "spectra" chips. Long story made short, if you want to play all the latest and greatest sources with your PJ you will need to upgrade. There are discussions of HDMI specs at and around post #451 and #1459 in this thread.
post #2018 of 3871 Old 06-24-2019, 12:38 PM
Quoted: 173 Post(s)
Originally Posted by dr bill View Post
The Delong cable works!!!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Story: I saw that all three cables were sitting at the local Post Office, waiting to go onto the truck for delivery. Being the insane person I am, I went over there to intercept the cables, so as not to wait a few hours to get them delivered. Only the Delong was easily locatable, so I took that one home and tried it out. And it friggin' works! No handshake issues.
I believe this was the cheapest of the three, so the other two are going back.
Now I get to see 4K blu-ray and streaming in all their glory. Holy cow - I am sooo impressed by this projector.
Now, if I can only get the wife to admit that she sees a difference compared to the old Sony. "Looks like a regular VCR tape to me..."
what kind of issues were you having with your old cable? when you say handshake? what do you mean by that
post #2019 of 3871 Old 06-24-2019, 12:52 PM
Kelvin1000's Avatar
Quoted: 139 Post(s)
Liked: 112
Thanks!!
3D video
x.v.Color
I believe this is one of the best cables when the application calls for a distance of more than 20 feet. It has worked flawlessly for me so far:
Fiber HDMI Cable RUIPRO 4K60HZ 33 feet Light Speed HDMI2.0b Cable, Supports 18.2 Gbps, ARC, HDR10, Dolby Vision, HDCP2.2, 4:4:4, Ultra Slim and Flexible HDMI Optic Cable with Optic Technology 10m https://www.amazon.com/dp/B06XGDFCSC..._iIseDbBE9CPDX
Kelvin1000 is online now
post #2020 of 3871 Old 06-24-2019, 12:55 PM
ike12's Avatar
Quoted: 29 Post(s)
Can someone please confirm to use Xbox One X as my Movie BluRay player, and get full 4K HDR I would need to purchase an "HD Fury Linker"??
If an example problem helps: everything plays great on my xbox *youtube, dashboard, games are in 4k and life is good* now I throw in a movie lets say "Warcraft 4K HDR" and it reverts to 1080P SDR.. No idea why.
If I replace the Xbox as my movie player with a Ps4 Pro does this problem go away? Or a dedicated 4K player? Or suck it up and buy the HD Fury for approx $250.?
Thank you!
ike12 is offline
post #2021 of 3871 Old 06-24-2019, 06:03 PM
Quoted: 173 Post(s)
As far as mounts go whats the difference between the CHF2500 and the CHF4500???
post #2022 of 3871 Old 06-24-2019, 06:20 PM
Quoted: 840 Post(s)
Liked: 593
As far as I know the 2500 is just the older model from 2015 and the 4500 is the 2019 model. Both black and both can be used for many models of the Epson Home and Pro Cinema line including the 5050 and 6050.
post #2023 of 3871 Old 06-24-2019, 06:25 PM
Quoted: 840 Post(s)
Liked: 593
Thank you!
I don't know why your XBOX One X would not be able to pass the 4K signal through to the 5050. Adding another component into the chain, even something as helpful as the HD FURY LINK, might not resolve your issue because I haven't seen you articulate the root cause of your issue. Can you elaborate please the cause as you believe it to be rather than the result.
post #2024 of 3871 Old 06-24-2019, 06:30 PM
Quoted: 840 Post(s)
Liked: 593
https://support.channelmaster.com/hc...-intermittent-
Good explanation of "HDMI Handshake" issue.
Alaric and dr bill like this.
post #2025 of 3871 Old 06-24-2019, 07:10 PM
Quoted: 173 Post(s)
Ya i basically have a 30ft HDMI cable (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and while im not having as many issues as you guys i think im going to change the cable for a fiber one ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) just to be safe
JonfromCB likes this.
post #2026 of 3871 Old 06-24-2019, 07:15 PM
Quoted: 173 Post(s)
I cant seem to find a 4500 no where for reasonable price. So think ill just pick this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #2027 of 3871 Old 06-25-2019, 08:24 AM
JonfromCB's Avatar
Quoted: 216 Post(s)
Liked: 156
It looks sturdy and it looks adjustable in 3 dimensions but also looks like it takes two people to align the holes and bolts during projector installation and removal. That's where the Chief design has a huge advantage over most others. One person can slide a PJ in place or remove it for a bulb change or PJ swap. From my experience, that convenience is a big plus for the Chief.
gene4ht likes this.
post #2028 of 3871 Old 06-25-2019, 08:30 AM
Quoted: 840 Post(s)
Liked: 593
The price for a chief Mount seems ridiculous at first glance until you own one and then you will beat yourself up over being so cheap all these years. I had four different mounts before I got my chief and I would never go back. When you buy a chief mount you won't have to buy a brand new mount every time you get a new projector in the future since the actual mount is universal. You would just need to buy the mounting plate that matches your projector.
gene4ht and JonfromCB like this.
post #2029 of 3871 Old 06-25-2019, 08:42 AM
Quoted: 173 Post(s)
Ok Ok ill listen went ahead and ordered the Chief RPA 357 and Peerless ACC570 Plate. About $170 both from PP
JonfromCB and tsharp like this.
post #2030 of 3871 Old 06-25-2019, 12:03 PM
Alaric's Avatar
Quoted: 103 Post(s)
Liked: 128
Thank you!
That sounds very strange and i would guess is some form of setting in the Xbox.
UHD is 4k 24p which is less bandwidth than Xbox 4k is using so really should not be an issue.
Certainly no need for a linker, that's typically used to fudge 4k gaming, not uhd disc films!
Sent from my HTC U11 using Tapatalk
Luminated67 likes this.
Sound - Marantz SR6011 (pre/atmos), Yamaha Z9, Mirage Om-6's, Om-C2's, 6x Om-R2's, 4x Nanosat (atmos), Dual Paradigim Servo 15's
Additional - MiniDSP : DDRC-88a, 2x4HD
Source -Panasonic DP-UB420, Toshiba HD-XE1, Sony SCD-XE620
Vision - Epson TW9400, eecolour Lut Box, 120" Spitfire Acoustically Transparent Screen
Alaric is offline
post #2031 of 3871 Old 06-25-2019, 12:57 PM
ike12's Avatar
Quoted: 29 Post(s)
Thank you, I have removed the X1X from the equation and if I use my Roku 4K to stream a Netflix 4K HDR, It will display in 4K, however signal status always shows SDR, and BT.7 not BT 2 etc?
I am thinking it could be my receiver although it says 4K 2.2.. I am going to try to bypass it tonight to see if it shows 4K HDR .
ike12 is offline
post #2032 of 3871 Old 06-25-2019, 01:56 PM
Quoted: 284 Post(s)
Liked: 90
How does CFI actually work?
If I select 24Hz from NVCP, do the Low/Med/High change the frame rate?
noob00224 is online now
post #2033 of 3871 Old 06-25-2019, 03:52 PM
Liked: 0
Thank you!
I used my xboxX as my player and had no issues getting 4k. I had just received my projector and was just testing it out so i was hooked directly into my xbox at the time and not going through my receiver or anything yet though. I didnt have to change any settings on my xbox from when i had it hooked up through my denon going to my samsung js8500 either.
oglk30 is offline
post #2034 of 3871 Old 06-25-2019, 06:11 PM
Barrettmr's Avatar
Quoted: 140 Post(s)
Liked: 45
Thank you for the advice - I found they now have this version that must have that newer Spectra chip so I'll upgrade...
Monoprice Cabernet Ultra Series Active High Speed HDMI Cable - [email protected] HDR 18Gbps 28AWG YUV 4:4:4 CL2
post #2035 of 3871 Old 06-25-2019, 10:49 PM
Quoted: 44 Post(s)
Liked: 2
Originally Posted by --Sclaws View Post
The dynamic range of the 5050 does change automatically. What setting are you referring to that doesn't change?
Can you explain the difference in these settings. Mine is also set to Auto but it shows SDR currently as I'm watching news on DirecTV.
When I go to Signal, I have several other settings that pop up compared to your picture. Curious why yours doesn't show all these or are you in a different setting.
3D Setup
Aspect
Overscan
Color Space
Dynamic Range
Advanced
Reset
BUman is offline
post #2036 of 3871 Old 06-25-2019, 10:51 PM
Quoted: 44 Post(s)
Liked: 2
HEAT
Can anyone speak to their own 5050 projector how hot the top left and left side of the projector gets when you've had it on for an hour or two?
Mine is set up in a cut out shelf that was professionally done inside a soffit next to the ceiling. There is only 1-2 inches on each side and at the top but a couple feet behind. Since the fans are in the front I was told it shouldn't be an issue but I was curious about how hot the side and top of the projector was when I felt it for the first time because it shut off automatically.
My standby mode was on but I also checked on a heat warning and they said if it had overheated there would be a red blinking button which there is not.
BUman is offline
post #2037 of 3871 Old 06-25-2019, 11:11 PM
Quoted: 44 Post(s)
Liked: 2
When you go to Menu - Info what does your Source say. I'm still concerned w/ my installation. I'm not sure when watching TV why it's saying HDMI2. There was some debate on whether to have my 4k HDMI cables go straight from my Xbox 1/BlueRay and Apple4k into HDMI 1 and HDMI2 instead of having them to my Marantz then to HDMI 1 so it doesn't look like they did that.
Also - why doesn't EPSON have an official in here answering questions. Their customer service is OK but they are basically reading from their manual. Would be nice to have an expert Epson support person be able to respond unless that's not allowed on AVS.
BUman is offline
post #2038 of 3871 Old 06-26-2019, 04:48 AM
Viche's Avatar
Quoted: 793 Post(s)
Liked: 191
Why do you think skylarlove1999 is here?
Viche is offline
post #2039 of 3871 Old 06-26-2019, 05:57 AM
ike12's Avatar
Quoted: 29 Post(s)
After removing the Yamaha Receiver from the equation the Projector and X1X work as should and display automatically a 4K HDR image! The Receiver is 4K 2.0 not 2.2 and therefore the issue.. Time to swap it out. Thanks everyone
ike12 is offline
post #2040 of 3871 Old 06-26-2019, 06:09 AM
rustolemite's Avatar
Quoted: 372 Post(s)
Liked: 114
After removing the Yamaha Receiver from the equation the Projector and X1X work as should and display automatically a 4K HDR image! The projector is 4K 2.0 not 2.2 and therfore the issue.. Time to swap it out. Thanks everyone
Are you saying the new Epson 5050 doesn't support 2.2? Cause here are the specs.
Terminal Inputs:
2x HDMI (HDCP 2.2)
1x USB Type A (for optical HDMI cable 300 mA max. power supply only)
1x USB (for wireless and firmware)
1x Mini USB (service only)
1x LAN (RJ45)
1x Computer/D-sub 15 pin
1x RS-232c
Trigger out 12 V DC, 200 mA maximum
VIDEO: Epson 5050UB * SeymourAV CenterStage XD 137.7" * Samsung UBD-M9500 * Nvidia Shield * HTPC * Xbox OneX * URC MX-990
AUDIO: Yamaha CX-A5200 * Emotiva XPA-9 Gen3
SPEAKERS: PSA MTM-210T L/C/R * PSA MTM-110 (2) Surrounds * S2(4) Atmos * HSU VTF-3MK4
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
5050 , Epson , frame interpolation , motion smoothing
