THE Epson 5050UB/6050UB Thread - Page 69 - AVS Forum | Home Theater Discussions And Reviews
 1198Likes
post #2041 of 3887 Old 06-26-2019, 06:11 AM
skylarlove1999's Avatar
Quoted: 849 Post(s)
Liked: 601
Originally Posted by ike12 View Post
After removing the Yamaha Receiver from the equation the Projector and X1X work as should and display automatically a 4K HDR image! The projector is 4K 2.0 not 2.2 and therfore the issue.. Time to swap it out. Thanks everyone
I'm glad you were able to solve your issue I believe you meant to state that the receiver is the issue and time to swap it out
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #2042 of 3887 Old 06-26-2019, 06:12 AM
Quoted: 849 Post(s)
Liked: 601
Originally Posted by rustolemite View Post
Are you saying the new Epson 5050 doesn't support 2.2? Cause here are the specs.
Terminal Inputs:
2x HDMI (HDCP 2.2)
1x USB Type A (for optical HDMI cable 300 mA max. power supply only)
1x USB (for wireless and firmware)
1x Mini USB (service only)
1x LAN (RJ45)
1x Computer/D-sub 15 pin
1x RS-232c
Trigger out 12 V DC, 200 mA maximum
I believe the original poster misspoke they were talking about the receiver not supporting 2.2 and they need to swap the receiver out not the projector
post #2043 of 3887 Old 06-26-2019, 06:14 AM
Quoted: 849 Post(s)
Liked: 601
Originally Posted by BUman View Post
When you go to Menu - Info what does your Source say. I'm still concerned w/ my installation. I'm not sure when watching TV why it's saying HDMI2. There was some debate on whether to have my 4k HDMI cables go straight from my Xbox 1/BlueRay and Apple4k into HDMI 1 and HDMI2 instead of having them to my Marantz then to HDMI 1 so it doesn't look like they did that.
Also - why doesn't EPSON have an official in here answering questions. Their customer service is OK but they are basically reading from their manual. Would be nice to have an expert Epson support person be able to respond unless that's not allowed on AVS.
It sounds like your DirecTV box is plugged into HDMI 2 for the video signal. it's also plugged into the receiver I would assume it would have to be since you are getting sound from your speakers. I believe you mentioned some while back that you were going to be getting a new 4k receiver anyway at that point I would just run everything into your receiver and then just one HDMI cable from your receiver to the projector. As long as it's all working for now I don't know if it really matters if the projector changes sources for you if you have to change it manually that's a little bit of a pain in the butt.
post #2044 of 3887 Old 06-26-2019, 06:16 AM
Quoted: 849 Post(s)
Liked: 601
Originally Posted by Viche View Post
Why do you think skylarlove1999 is here?
LOL. I have spent enough time either over the phone or by text or by email with Epson at this point I feel like they should be paying me. But all opinions here on my own LOL.
Alaric and dr bill like this.
post #2045 of 3887 Old 06-26-2019, 06:17 AM
Quoted: 849 Post(s)
Liked: 601
Thank you, I have removed the X1X from the equation and if I use my Roku 4K to stream a Netflix 4K HDR, It will display in 4K, however signal status always shows SDR, and BT.7 not BT 2 etc?
I am thinking it could be my receiver although it says 4K 2.2.. I am going to try to bypass it tonight to see if it shows 4K HDR .
Did you ever resolve your issue?
post #2046 of 3887 Old 06-26-2019, 07:01 AM
Viche's Avatar
Quoted: 793 Post(s)
Liked: 191
Haha...it's all good. We appreciate your presence and contributions.
Viche is offline
post #2047 of 3887 Old 06-26-2019, 07:05 AM
Quoted: 849 Post(s)
Liked: 601
HEAT
Can anyone speak to their own 5050 projector how hot the top left and left side of the projector gets when you've had it on for an hour or two?
Mine is set up in a cut out shelf that was professionally done inside a soffit next to the ceiling. There is only 1-2 inches on each side and at the top but a couple feet behind. Since the fans are in the front I was told it shouldn't be an issue but I was curious about how hot the side and top of the projector was when I felt it for the first time because it shut off automatically.
My standby mode was on but I also checked on a heat warning and they said if it had overheated there would be a red blinking button which there is not.
Anytime you enclose anything that generates Heat there is the possibility however remote that your technology could suffer and overheat. You are correct in stating that the fan exhaust it's from the front and as long as the front exhaust is clear you should not have any real issues. It was not clear from your post at least to me whether you had the projector shut down due to overheating. I believe you did not. I would expect your projector to feel a little warmer because it is an enclosed space.
post #2048 of 3887 Old 06-26-2019, 07:24 AM
bluer101's Avatar
Quoted: 636 Post(s)
Liked: 733
HEAT
I have the 5040 and it does get pretty warm on that one side that the bulb is housed in. I have mine in a soffit to but I also added an exhaust fan to pull fresh air into the projector soffit and out of the room.
bluer101 is offline
post #2049 of 3887 Old 06-26-2019, 07:28 AM
Luminated67's Avatar
Quoted: 680 Post(s)
Liked: 381
Your assumption is based on what..... the cable you probably swapped from your amp to the XBox? Almost always the problems are the cable used.
The Epson has the identical spec of a JVC in this.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
post #2050 of 3887 Old 06-26-2019, 07:37 AM
Quoted: 849 Post(s)
Liked: 601
I agree that many times the issue is the cable. In this case I think the original poster misspoke. They now believe the Yamaha receiver is the issue not the projector. Because they took the receiver out of the signal path and everything worked correctly I believe using the same cable.
post #2051 of 3887 Old 06-26-2019, 07:38 AM
ckronengold's Avatar
Quoted: 270 Post(s)
Liked: 111
maybe your upgrade path is their way of saying "thanks!"
Video: Epson 5050 / nVidia Shield / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #2052 of 3887 Old 06-26-2019, 07:44 AM
Quoted: 849 Post(s)
Liked: 601
Maybe LOL. Hope you are doing well. Nice to meet you at the Epson event.
post #2053 of 3887 Old 06-26-2019, 09:36 AM
ike12's Avatar
Quoted: 29 Post(s)
Yes, Sorry for that dam typo! I meant to state the "receiver" is 2.0 not 2.2 and therefore the issue is the receiver.
Same cable used etc and all signs point to receiver. Thanks all
rustolemite likes this.
ike12 is offline
post #2054 of 3887 Old 06-26-2019, 09:44 AM
Quoted: 44 Post(s)
Liked: 2
Did you install your projector right side up or did you install it upside down? My former Epson projector was installed upside down but the installers put this one right side up and the lens shift literally is all the way down to the inch to fit the bottom of the screen. Curious if I should install it upside down instead.
BUman is offline
post #2055 of 3887 Old 06-26-2019, 10:04 AM
Quoted: 44 Post(s)
Liked: 2
This is what the projector looks like in our soffit. I was surprised to see the light on the ceiling above the projector. I'm guessing that would go away if we installed it upside down.
ID:	2584680   Click image for larger version
BUman is offline
post #2056 of 3887 Old 06-26-2019, 10:07 AM
Quoted: 849 Post(s)
Liked: 601
You will still see that light because of how close you are to the ceiling regardless of the position of the projector it should no way affect the picture quality the only way that it could is if you were really close to the screen it could reflect off the ceiling and onto the screen but I believe you said you were quite a bit back
post #2057 of 3887 Old 06-26-2019, 10:28 AM
CallingMrBenzo's Avatar
Quoted: 635 Post(s)
Liked: 1393
Those lightly colored walls will affect the picture quality. Too much light reflecting. I just removed most of my black sheets and replaced it with 49 yards of velvet. There is a noticeable increase in picture quality
Ordered another 40 yards of velvet.
Those pictures are lights on and flash on
Marantz 7011- Panasonic UB-820- Xbox One X - Epson HC 5050UB *Calibrated by ChadB* - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is online now
post #2058 of 3887 Old 06-26-2019, 10:39 AM
bluer101's Avatar
Quoted: 636 Post(s)
Liked: 733
Mine is right side up. But I have just a little more space around the projector.
bluer101 is offline
post #2059 of 3887 Old 06-26-2019, 10:40 AM
Quoted: 849 Post(s)
Liked: 601
Impressive. Most Impressive.
post #2060 of 3887 Old 06-26-2019, 10:41 AM
Quoted: 849 Post(s)
Liked: 601
Absolutely beautiful home theater well done
bluer101 and CallingMrBenzo like this.
post #2061 of 3887 Old 06-26-2019, 10:55 AM
Quoted: 635 Post(s)
Liked: 1393
Amen to that very nice looking
bluer101 likes this.
post #2062 of 3887 Old 06-26-2019, 10:56 AM
Quoted: 635 Post(s)
Liked: 1393
Just installed my new subwoofers. Replace my dual Power Sound Audio S3611’s with TV36 NEO’s 500 pounds of bass
post #2063 of 3887 Old 06-26-2019, 10:59 AM
Quoted: 45 Post(s)
Liked: 5
Has anyone gone from a 5040 to a 5050? Is it worth upgrading? My HDMI 1 is out on my 5040, trying to decide whether to get a 5040 refurb or a 5050
ClayM325 is offline
post #2064 of 3887 Old 06-26-2019, 11:01 AM
Quoted: 635 Post(s)
Liked: 1393
post #2065 of 3887 Old 06-26-2019, 01:21 PM
Quoted: 44 Post(s)
Liked: 2
I like the slide out. Do you have to slide that out every time you use it? Also, what did you line your box w/, looks like some type of padding? Is that for noise or heat or what?
BUman is offline
post #2066 of 3887 Old 06-26-2019, 01:23 PM
Quoted: 44 Post(s)
Liked: 2
Yes, it's why we bought a black diamond 4 years ago and needed the Epson because of the Lumens. We have black out shades but obviously it is still light grey walls. The picture is still great even in the day w/ lights on so that's not been an issue. The problem was this is somewhat of a game room, not a dedicated theatre room like the two above. The room is very large, 25 feet deep by 20 feet wide.
CallingMrBenzo likes this.
BUman is offline
post #2067 of 3887 Old 06-26-2019, 03:07 PM
bluer101's Avatar
Quoted: 636 Post(s)
Liked: 733
Slide out is for servicing the PJ, connecting cables, firmware, etc. The inside of the box is lined with 1 inch acoustic foam wedge. This is on the sides, top, and back for sound. Without this it would be a echo chamber and make the PJ seem louder.
BUman likes this.
bluer101 is offline
post #2068 of 3887 Old 06-26-2019, 04:00 PM
SuperMiguel's Avatar
Quoted: 173 Post(s)
Originally Posted by SuperMiguel View Post
Ya i basically have a 30ft HDMI cable (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and while im not having as many issues as you guys i think im going to change the cable for a fiber one ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) just to be safe
So got the fiber cable table, test it on my xbox one and no issues, (i only tested the menu) then ran it from my my projector to my receiver, tested the xbox one menu still works, then tried to switch to my apple tv and I get a black screen, tried connecting the apple tv directly (bypassing the receiver) and same thing, so reseted my video settings on my apple tv and by default it gets set to 4k SDR, i can see image with the new cable, i tried switching the mode to 4k HDR and i get a blank screen, i tried my old cheap cable and it took a while but eventually showed up, moved cables around again and the screen stared flickering and eventually went back to black screen.... i guess a need a new cable? i thought i was buying the best, i guess not
SuperMiguel is offline
post #2069 of 3887 Old 06-26-2019, 05:29 PM
Quoted: 849 Post(s)
Liked: 601
You went with the ruipro correct? This is the one I currently use between my Denon 6500 and Epson 6050. No issues.
https://www.amazon.com/HDMI-FURUI-HD...8-1&th=1&psc=1
post #2070 of 3887 Old 06-26-2019, 05:55 PM
Quoted: 173 Post(s)
Yup I went with ruipro. Just ordered the one you linked. I'll update on my results Friday. I got the braided version
5050 , Epson , frame interpolation , motion smoothing
