THE Epson 5050UB/6050UB Thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 1261Likes
post #2791 of 4254 Old 08-22-2019, 02:18 AM
Quoted: 32 Post(s)
Liked: 3
Update on the convergence issues I had:
Had contact with Epson. They can't do much about it. They said if the panel alignment does not work then there is probably something wrong with the optics.
Within 30 days of purchase the DOA procedure can be started. Which means you can send the projector back to the seller and get a new one.
Just sended mine (tw9400) back to the seller this week. Expecting a new one next week.
Biggydeen is offline
post #2792 of 4254 Old 08-22-2019, 03:36 AM
Luminated67's Avatar
Quoted: 709 Post(s)
Liked: 392
I can't understand why when purchasing a projector at $3K anyone would try a skimp on the HDMI cable feeding it like it's not that $50-70 is a lot of money in the grand scheme of things.
When buying a 4K capable projector and your lead is beyond 5M.
BUY A BLOODY OPTI-HDMI
Alaric likes this.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is online now
post #2793 of 4254 Old 08-22-2019, 04:37 AM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
I wasn't aware that there was a big difference in 4k HDMI cables. I went on Amazon, and found one that had great reviews. I wasn't trying to "skimp" on the price, I was trying to find one with great reviews. My biggest fault, was not knowing that some were capable of doing more than others. Just because something costs more, doesn't necessarily mean it's better, was my thought process. Monster has been gouging people for years with their high priced cables, and they are no better than some cables that are 1/3 their price.
Sent from my SM-G950U using Tapatalk
biglen is offline
post #2794 of 4254 Old 08-22-2019, 04:48 AM
Quoted: 709 Post(s)
Liked: 392
No a dig at anyone just a general comment, the problem with reviews is it includes all sizes rather than the particular one you have highlighted.
post #2795 of 4254 Old 08-22-2019, 05:10 AM
skylarlove1999's Avatar
Quoted: 1013 Post(s)
Liked: 711
Yes HDMI cable reviews on Amazon should be specific to the exact size. Most six foot cables exhibit very similar performance but once you get to beyond 20 ft the results become very hit or miss. Even within the same size and same brand their is inconsistency. It truly is frustrating. The higher price doesn't guarantee performance but from personal experience I do believe there is a higher percentage for successful handshake and 4K/60FPS 12bit 4:4:4 BT.2020 HDR10 performance. It is usually true that you get what you pay for. Finding that budget cable that works is a time consuming process. Thanks to all who post cables that work, regardless of price.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #2796 of 4254 Old 08-22-2019, 05:41 AM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
I didn't take it as a dig. I was just pointing out my thought process.
Luminated67 likes this.
biglen is offline
post #2797 of 4254 Old 08-22-2019, 06:03 AM
mach250's Avatar
Quoted: 58 Post(s)
Liked: 37
I went from THIS CABLE to THIS CABLE. First one would give me pink and green dots with anything above 4:2:0 60hz, second one is perfect at any color depth. I would say anything above 10-15 feet needs to be optical.
Originally Posted by skylarlove1999 View Post
The Xfinity 4k box playback should automatically default to the appropriate 4K color depth based on your display device capabilities. The 5050 is capable of 12bit 4:4:4 which is from a UHD disc. Streaming formats are never that high. They are usually 12bit 4:2:2 or 12bit 4:2:0. So I am not sure why you are getting 10 bit . Could be a receiver setting or the HDMI cable is only capable of 10 bit or could just be Netflix through Xfinity is limited to 10bit. Do you have a UHD player yet? That way you could pop in a disc and narrow down what is going on.
I don't think I'm able to get 12bit 4:4:4 from my PC with a 1080 nvidia card.
mach250 is offline
post #2798 of 4254 Old 08-22-2019, 06:15 AM
Quoted: 709 Post(s)
Liked: 392
That Opti HDMI is actually more than 2.5 times the price of mine. There’s a vast difference in price of these leads, but from what I have read is that with Opti leads it will either work perfectly or it won’t and this is purely down to how careful you are with the fitment.
post #2799 of 4254 Old 08-22-2019, 07:00 AM
BIC2's Avatar
Quoted: 198 Post(s)
Liked: 45
PJ at top or center of screen
Setting up new Epson 6050 with lots of lens shift available. 10 ft ceiling, 7 ft top of screen. Adjustable 2-3 ft extension down rod. Centered side wall to wall. 17 ft throw. 2:35 screen 135-145 inches wide x 60 high.
I've read PJ should be at top of screen and I've read PJ should be centered on screen. I can pretty much do either in the upper one-third of screen. Which is preferable? Thanks.
BIC2 is offline
post #2800 of 4254 Old 08-22-2019, 07:18 AM
Liked: 711
Centered in the middle of your screen both vertically and horizontally is supposedly best for image quality. Obviously not practical for 99% of the population. Centered horizontally and hanging about six inches to a foot down from the top of your screen will give you fantastic results. I haven't found lens shift vertically or horizontally to have a negative impact on the image for my Epson projectors through the past 10 years. I have my 6050 centered horizontally and a foot down into my screen vertically. There are some lens shift limitations when you use both at the same time but only at the upper recommended usage.
post #2801 of 4254 Old 08-22-2019, 07:22 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3790 Post(s)
Liked: 1760
You are definitely the king of awesome AV on a very discerning budget. I did originally try the Fiber Optic HDMI cable you suggested but alas the signal cut in and out too much for me to use it. I am glad it has worked out for you. It can never hurt to try the cheaper chicken. Thanks for your recommendation.
Your welcome. I certainly did not mean to discount the recommendation you made. That it too does the job intended is probably a given thing. Indeed, I am always trying to cut costs but without cutting corners, so when I do suggest a viable, less expensive alternative, it's only one that I myself have used "repeatedly" and can personally vouchsafe. It doesn't take but a few coming back on the Threads and saying "That was crap" to effectively put all one's suggestions to question.
I figured I'd give it a shot, because it has free returns. I have nothing to lose. I'll let you know if it works for me. Thanks for your help !
Exactly the right outlook to take...iffin' you are a Prime'r. I found the suggested FO-HDMI to be very flexible and forgiving...well protected from kinking. People do have issues when too many bends...even sweeping ones...are made. Any FO line loses Light signal pass-through efficiency when it must pass through repeated bends. And when the efficiency is a dpendent factor as far as consistantly maintaining the speed and signal level of a transmission, all the advantages of having a FO-HDMI can come to naught.
If it works you saved around $100. That is a savings you could put towards a UHD player so definitely nothing to sneeze at. I really hope it works for you.
Again....the 100.00 saved is not chicken feed, and when one does find they both saved a lot as well as met their goals, the satisfaction index rises almost exponentially.
(............I hope it works for him too !!!........it better! )
@Kelvin1000
For many who have a 5040ub, what with it's limited non-18 gb Input abilities, the pursuit of Active cords has been a solution as well as a Rabbit Hole. Actives are among the most "Crap-shoot" type, some...if indeed many working wondermusly...others failing. (usually because someone presses the limits of reasonable sanity with 45'-50 ' + runs )
I've advocated the use of Cable Matters Certified 4K HDMI cords for about 3 yrs now...and over that time and in at least 30+ installations, only had one that didn't live up to my expectations. (...and that only recently...) A 25'er is a few dollars under 25.00 and it too is a "Prime" offering so there is little risk for A-Prime buyers to be concerned about.
https://www.amazon.com/Cable-Matters...ronics&sr=1-28
But beyond the 25' limit, the scramble to get the most 4K performance "Bang" for the least "Buck" has been at the forefront of many a Member's concerns. That accounts for why so many will rush to purchase any Cable someone touts as being "the one worth the money". It's been that way for sometime...all the way back to the days when HDMI was "new".
So it is a good thing you have vetted a Active HDMI cord that works as claimed.As such it is another viable alternativeand I'm sure many will be happy to know of it.
As for myself, now that there is a dependable and affordable FO-HDMI available....I'll not look backwards to a Wire-based cord. Especially since I'm primarily installing JVC units, both E-Shift and Native 4K'ers, both that absolutely require pristine 18 gb pass-through..
MississippiMan is online now
post #2802 of 4254 Old 08-22-2019, 02:45 PM
BIC2's Avatar
Quoted: 198 Post(s)
Liked: 45
Tried it at about 1 ft down from top. Image beamed a foot or two up on the ceiling. I quickly changed the pitch to correct, but now PJ is pointing down a bit. Presume I want PJ level and use vertical lens shift instead of pitch? Thanks.
Epson Pro Cinema 6050 Projector, Screen TBD, Onkyo DX-C390 Six-Disk CD Changer
Triad Silver Speakers (11 in a 7.2.4 configuration), 2 JTR 118HT Subwoofers
Yamaha CX-A5200 11 Channel Processor, Monoprice Monolith 11 Channel Amplifier
Panasonic DP-UB820 UHD Blu-ray, Sony BDX-BP57 Blu-ray, Oppo DV-981HD, Harmony Elite Remote
BIC2 is offline
post #2803 of 4254 Old 08-22-2019, 02:46 PM
Rob Greer's Avatar
I've been trying to add my new 6050 to my Harmony Elite remote, but that model projector isn't listed as available. Harmony was once be pretty good about adding mainstream gear quickly, but the 6050 isn't on the list--at least for what I'm entering. Any suggestions short of manually adding the remote features to Harmony? Am I not entering the model number info correctly? TIA
"By my troth, I care not; a man can die but once; we owe God a death.... He that dies this year is quit for the next." -- William Shakespeare, Henry the Fourth, Part II
Rob Greer is offline
post #2804 of 4254 Old 08-22-2019, 03:07 PM
--Sclaws's Avatar
Quoted: 83 Post(s)
Liked: 63
Iirc I used the 5040 profile for my 5050. The HDR button was the only one I had to add manually.
Epson HC5050UB | 110" DEA Infinity Edge FF | Marantz NR-1607 | Kodi HTPC | Panasonic DP-UB820 | PS4 Pro
JimK
--Sclaws is online now
post #2805 of 4254 Old 08-22-2019, 03:15 PM
Mike Garrett's Avatar
Quoted: 12665 Post(s)
Liked: 10291
Yes, projector should be pointed straight ahead and you use lens shift to adjust the image height.
Mike Garrett is offline
post #2806 of 4254 Old 08-22-2019, 03:48 PM
Liked: 711
The projector should be level with Earth and use the vertical shift to move the image up and down
post #2807 of 4254 Old 08-22-2019, 04:42 PM
Liked: 711
I think the 5050 profiles available in the Harmony remote
post #2808 of 4254 Old 08-22-2019, 05:31 PM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
I'm confused about 4k Enhancement. It's grayed out with my Xfinity box, and my Nvidia Shield. Both are set to output 4k, so I'm assuming that's why it's grayed out? Does that mean the projector is outputting 4k, or no? Should I set the Xfinity box and Nvidia Shield to output in 1080p, then turn on 4k Enhancement?
biglen is offline
post #2809 of 4254 Old 08-22-2019, 05:36 PM
Cattledog's Avatar
Quoted: 72 Post(s)
Liked: 44
A 4k signal is 8 million pixels. The Epson can only do 4 million. So no need to e shift. What it is doing is down-resing the signal.
Reality Based.
Cattledog is offline
post #2810 of 4254 Old 08-22-2019, 09:31 PM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
Okay, so when I set my Nvidia Shield to 1080p instead of 4K, I'm now getting 12 bit 4:2:2 when watching Netflix. If I switch the Shield back to 4K, I only get 10 bit. Does that make sense?
biglen is offline
post #2811 of 4254 Old 08-22-2019, 09:43 PM
Liked: 711
Doesn't make sense to me. Did you get the new cable yet?
post #2812 of 4254 Old 08-22-2019, 09:45 PM
Liked: 711
Does the 10bit still give you BT.2020 HDR10?
post #2813 of 4254 Old 08-22-2019, 09:52 PM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
This is Netflix on my Xfinity box.
biglen is offline
post #2814 of 4254 Old 08-22-2019, 09:55 PM
Quoted: 784 Post(s)
Liked: 397
You need a 4K feed for 4K enhancement to work.
DunMunro is offline
post #2815 of 4254 Old 08-22-2019, 09:58 PM
Quoted: 784 Post(s)
Liked: 397
10bit should still give HDR10:
DunMunro is offline
post #2816 of 4254 Old 08-22-2019, 09:59 PM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
Nope, the old $35 cable.
biglen is offline
post #2817 of 4254 Old 08-22-2019, 10:02 PM
Liked: 711
Can you please explain how that works because I thought the 4k enhancement was for upconverting below 4k content to 4k as 1080p as an example and upconverting it to 4k.
post #2818 of 4254 Old 08-22-2019, 10:04 PM
biglen's Avatar
Quoted: 551 Post(s)
Liked: 92
This is what I get when I set the Xfinity box back to 4K, but then 4K Enhancement is grayed out. When the Xfinity box is set to 1080p, 4K Enhancement is not grayed out, and it engages.
biglen is offline
post #2819 of 4254 Old 08-22-2019, 10:08 PM
Liked: 711
I get that 10bit can still produce BT.2020 HDR10 but if you look at the screen shot the projector is being fed a 1080P signal. Unusual for Netflix to send 12bit BT.2020 HDR10 when it sends a 1080p signal. My guess is that the Shield can be set to 12bit BT.2020 HDR10 even if that is not the signal being sent from Netflix and that is what the Epson projector is reading even though the projector is not actually receiving that 12bit BT.2020 HDR10 signal.
post #2820 of 4254 Old 08-22-2019, 10:08 PM
Quoted: 784 Post(s)
Liked: 397
See page 82 of your manual:
Using 4K Enhancement
Using the projector's 4K Enhancement Technology, you can receive 4K (3840 × 2160 pixel) signals and
project ultra high-definition images. This technology shifts each pixel diagonally by 0.5 pixel to double
the image resolution.
Note: This feature may not be available depending on the projection mode and input signal.
Basically 4K enhancement takes a 4k signal and down samples it to something like 2.6K, but it still requires a 4K feed. Super Enhancement is for 1080P, IIRC, and that uses e-shift to reduce the SDE.
DunMunro is offline
5050 , Epson , frame interpolation , motion smoothing
