THE Epson 5050UB/6050UB Thread (No Price Talk) - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 1576Likes
post #901 of 5526 Old 05-09-2019, 12:54 PM
rbk123's Avatar
Quoted: 37 Post(s)
Liked: 33
Originally Posted by Alaric View Post
There's a trick for this, and it is in the set up of the memory. Small back adjustments don't work, so gently go forwards to the point you want and then save the position. If you need to go back, do a very large adjustment and then slowly creep forwards.
It a well known Epson thing!
Which way is forwards (and which is back)? Since we're talking left/right and up/down being off, I must say I'm stumped.
rbk123 is offline
post #902 of 5526 Old 05-09-2019, 01:10 PM
Alaric's Avatar
Quoted: 106 Post(s)
Liked: 132
The exact direction isn't important from what i recall you just need to keep going in one direction to reach the point you want to save.
If you go past, then go massively past and move then slowly back.
Doing little back and forwards to get it spot on confuses it and it is these adjustments that it misses and then it appears like the lens memory is sloppy.
I seem to recall there being a big pdf how to but can't find it to link at the moment.
Sent from my HTC U11 using Tapatalk
ckronengold likes this.
Sound - Marantz SR6011 (pre/atmos), Yamaha Z9, Mirage Om-6's, Om-C2's, 6x Om-R2's, 4x Nanosat (atmos), Dual Paradigim Servo 15's
Additional - MiniDSP : DDRC-88a, 2x4HD
Source -Panasonic DP-UB420, Toshiba HD-XE1, Sony SCD-XE620
Vision - Epson TW9400, eecolour Lut Box, 120" Spitfire Acoustically Transparent Screen
Alaric is offline
post #903 of 5526 Old 05-09-2019, 03:04 PM
rbk123's Avatar
Quoted: 37 Post(s)
Liked: 33
Ok, that makes sense. I encountered similar behavior when trying to optimize the focus so I know what you mean.
Alaric likes this.
rbk123 is offline
post #904 of 5526 Old 05-09-2019, 03:06 PM
Solarium's Avatar
Quoted: 147 Post(s)
At this point, if I can find a 5040UB refurb for $1150 or the new one plus a replacement lamp for $2k, is it worth the upgrade to the 5050UB? I heard there's some optimization for the pixel shifting so the 5050UB is more clear, but is it a significant difference? The 5050UB already doesn't have as sharp of an image as the BenQ HT5550, compromising that sharpness plus more for the 5040UB might be too hard to swallow. Also, is the 5050UB's HDR significantly better than the 5040UB's?
HT: LG OLED65B7A, Denon AVR-X7200WA, B&W CM10 S2, CMC2 S2, CM5 S2, HTR-7000 x4 (atmos), SVS SB13 Ultra x2
Desktop: KEF LS50 Wireless, KEF PSW4000 (https://pcpartpicker.com/user/Fridge...s/#view=r2V6Mp)
Portable: Chord Mojo, Shure KSE-1500
Solarium is offline
post #905 of 5526 Old 05-09-2019, 04:51 PM
skylarlove1999's Avatar
Quoted: 1471 Post(s)
Liked: 1177
Originally Posted by rustolemite View Post
Really quick dumb question, got my 5050 today but will Friday before I can install it, is it okay to leave the box sitting on it's side till I install it?
Like I said dumb.
I would never let anything designed to be horizontal stay vertical for too long. Only Epson themselves could speak to whether being placed vertically for an extended period of time negatively affects internal components.
skylarlove1999 is online now
post #906 of 5526 Old 05-09-2019, 05:07 PM
CallingMrBenzo's Avatar
Quoted: 678 Post(s)
Liked: 1587
Watching Blackhawk Down 4K right now with BEQ and this is another jaw dropping audio and video experience. Using Alaric’s HDR accurate settings with the slider at 5 and lamp in ECO. I have not had to adjust a thing it’s just perfect. The color saturation, details and black levels. I am one happy camper right now the Epson paired with this Panasonic player is a match made in heaven.
Alaric and Luminated67 like this.
Marantz 7011- Panasonic UB-820- Xbox One X - JVC RS4910 (FOR THE TIME BEING) * - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is offline
post #907 of 5526 Old 05-09-2019, 06:48 PM
Liked: 1177
Originally Posted by groggrog View Post
Originally Posted by dimi123 View Post
Why do people keep saying that Epson colors are not accurate? Here's what Projector Reviews are saying:
"Right out of the box, the color performance of this Epson is definitely a cut above. Epson has long been reported in many reviews, as putting out home projectors with really good color “right out of the box” without adjustment, for many years. No, they aren’t the best. Overall, I’d say Sony HT projectors offer the closest to calibrated color, of any brands, without doing any adjustment. But, that said, Epson may well be the closest to them."
I haven't messed with any color settings at all and it looks great to me out of the box.
I would say depending upon the picture mode the color seems to be very accurate judging by human eye alone I'm sure once use instruments you are going to find differences from what would be be considered ideal. But the picture looks so good out of the box I am anxious about what happens as the lamp dims every so slightly in the next 50-100 hours as is normal with a new projector. But I would put my 6050 up against a JVC DLA-NX5 and without telling people anything about either projector which picture they prefer. Obviously both projectors have their pros and cons. I dont feel you can go wrong with either. My only complaint of the 6050 so far would be some slight judder in a small percentage of panning scenes. Not a deal breaker by any means but worth mentioning. Good example would be the camera moving towards the pyramid panning over the desert at the beginning of X-men Apocalypse. Tough scene for any display in terms of judder.
post #908 of 5526 Old 05-09-2019, 06:59 PM
Liked: 1177
The 5040 put out a great image. I was very impressed with everything including HDR. That is until I pressed the power button on my 5050 and put my Avenger Infinity War 4K disc in my Panasonic ub820. Then I couldn't unsee how poor HDR really was on my 5040. The 5050 has a sharper more detailed image overall in SDR or HDR. My wife noticed the increased sharpness and resolution. she isn't usually one to notice or comment. HDR is night and day difference. I had two Epson 5040s with power supply issues. So I was skeptical of how much better could the 5050ub be in real world viewing. It just is.
post #909 of 5526 Old 05-09-2019, 10:23 PM
JewDaddy's Avatar
Quoted: 418 Post(s)
Liked: 179
I know people have asked and I’ve searched and can’t find Alaric’s settings for HDR movies. Can someone please send me a link to his settings?
JewDaddy is offline
post #910 of 5526 Old 05-09-2019, 10:43 PM
MidnightWatcher's Avatar
Quoted: 231 Post(s)
Liked: 230
Scroll down to Projector Set-Up:
https://sites.google.com/view/dreaming-cinema/home
My Theater | Vero 4K | Epson 5030UB + Peerless PRG-UNV | 100" EluneVision Reference 4K Screen | Denon X3600H @ 5.2.4 | 4 x ADX Maximus w/ Dayton Audio SA230 | Polk Audio RTi A9 + CSi A6 + OWM3 + Micca M8C + SVS PC2000 + Monolith 15 | 40" HDTV w/ Z83V Mini PC + MoviePosterApp | Z83V + DietPi FTP Server + 4 x 8TB HDDs + 4 x DLink DHP-701AV
MidnightWatcher is online now
post #911 of 5526 Old 05-10-2019, 02:16 AM
Liked: 1177
Originally Posted by MidnightWatcher View Post
Thank you Midnight Watcher. Much appreciated.
post #912 of 5526 Old 05-10-2019, 11:05 AM
ckronengold's Avatar
Quoted: 322 Post(s)
Liked: 130
plus, you can reverse / flip the direction in the settings anyway. up is down, down is up. and also depends if your projector is hanging or standing.
But the "start big, then go small" is a great tip. Thanks!
Video: Epson 6050 / Panny DP-UB420 / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #913 of 5526 Old 05-10-2019, 12:28 PM
Solarium's Avatar
Quoted: 147 Post(s)
You convinced me with the HDR How about the sharpness? How much % improvement would you say over the 5040UB? The $1150 refurb price is really tempting lol
Would a JVC X790R provide as good black levels, brightness, HDR but also much improved sharpness due to using x4 instead of x2 lens shifting?
Solarium is offline
post #914 of 5526 Old 05-10-2019, 02:28 PM
asolor78's Avatar
Quoted: 71 Post(s)
GOOD DAY EVERYONE,
New EPSON 5050ub Owner here... Appreciate all the information provided on this Beast of projector on this forum. I have now named it the Kraken for my own pleasure. Any who, I have to give thanks to @Alaric rewatched Wonder woman 4k last night and enjoyed the pictue view with hdr bright option.. have yet to use accurate. I do have a question, and as of now I am currently running a 4k uhd sony x700 at 24hz 4k hdr.. only reason is all cabling at this point is 1.4 hdmi 10gb and thats because im coming from a epson 5010. I will upgrade cabling soon enough.
My question is regarding all the "new tech" options i show on here ... I noticed when running a 4k movie 4k enhancement is greyed out.. and running 1080p bluray may also show 4k enhancement with presets... does anyone know what each preset do??
Also HDR Slider, I used again "HDR" bright setting @Alaric calibrations provided.. I do notice that going high to low brightens the image .. but not certain how to tell what may be the sweet spot?.. learning as I go with this new beast and hope to get some feedback.. Oh and one last question @Alaric , any recommendations to gaming calibration setting and/or 3d movies?
asolor78 is online now
post #915 of 5526 Old 05-10-2019, 02:50 PM
Liked: 1177
You convinced me with the HDR [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] How about the sharpness? How much % improvement would you say over the 5040UB? The $1150 refurb price is really tempting lol
HDR improvement is night and day difference for me from the 5040. Black level, contrast, depth, sharpness and resolution I would say about 25%. Black level increase would be only about 10% but then again the black levels were really good on the 5040 already.
I have not seen the X790R but I have seen the JVC NX7 and NX5. I would take the 5050 over the NX5 due to better HDR IMHO. NX5 was noticeably sharper and more detailed but not amazingly so. I sit at 12 ft as was the demo. The NX7 blew me away in almost every respect as did the 6050. I would need a side by side to compare to which one throws a better image. I was just too in awe of each to be objective. I have had the 6050 for three days now and each 4K disc has me dropping my jaw. This is the end of Infinity War on my 6050 from 12 ft back. Blacked out theater with black masking panels on a 120 inch 16:9 Seymour Glacier White screen.
Last edited by skylarlove1999; 05-11-2019 at 02:29 PM. Reason: Removed a percentage for the HDR improvement
post #916 of 5526 Old 05-10-2019, 03:04 PM
Liked: 1177
Another shot from my 6050 viewing Guardians of the Galaxy 2 only using my phone. Doesn't nearly do it justice.
CallingMrBenzo likes this.
post #917 of 5526 Old 05-10-2019, 03:48 PM
ezelkow1's Avatar
Quoted: 51 Post(s)
Liked: 32
Originally Posted by asolor78 View Post
GOOD DAY EVERYONE,
with a 4k signal 4k enhancement is always on no matter what. With a 1080p signal you can enable/disable
Alaric likes this.
ezelkow1 is offline
post #918 of 5526 Old 05-10-2019, 03:51 PM
Quoted: 678 Post(s)
Liked: 1587
More screen shots please and tips on how to take them properly . I have so many pictures but they pale in comparison
I did like this gem though great details on the shadow and the sun and sky looked great
post #919 of 5526 Old 05-10-2019, 04:08 PM
GCS
GCS's Avatar
Quoted: 102 Post(s)
Liked: 75
Gosh I am just so chicken sh*t I so want to pull the trigger on this projector I even have it in my cart ready to click buy. Just such a cheap a$$ and don't want to spend the 3k, LOL.
You guys posting all these pics just makes me want to buy even more.
XBL Gamertag - blowfish7494
"Pull up your big boy pants and deal with it" - The Wife!
"Put on your man suit and fake it" - The Wife
GCS is offline
post #920 of 5526 Old 05-10-2019, 04:11 PM
ezelkow1's Avatar
Quoted: 51 Post(s)
Liked: 32
Here are my shots from when I first set it up, just using 'our planet' as a test image. The jungle and desert scenes are with some ambient light since this is our family room and we have panel shades on the back door that block out most light, but not all during the day (also not sure why the insect shots are upside down, they also arent particularly indicative of what you see since theres motion so they end up a bit blurry in shots, in real life its amazing detail)
ID:	2565064   Click image for larger version
ID:	2565066   Click image for larger version
ID:	2565068   Click image for larger version
ID:	2565070   Click image for larger version
ezelkow1 is offline
post #921 of 5526 Old 05-10-2019, 04:23 PM
Quoted: 17 Post(s)
Liked: 0
Those screen shots are impressive. Are you using the 5050 or the 6050? Thanks!
carmona is offline
post #922 of 5526 Old 05-10-2019, 04:24 PM
ezelkow1's Avatar
Quoted: 51 Post(s)
Liked: 32
Originally Posted by carmona View Post
those screen shots are impressive. Are you using the 5050 or the 6050? Thanks!
5050
ezelkow1 is offline
post #923 of 5526 Old 05-10-2019, 04:26 PM
Quoted: 17 Post(s)
Liked: 0
5050
Thanks for the info and the beautiful pics.
carmona is offline
post #924 of 5526 Old 05-10-2019, 05:02 PM
Liked: 1177
Thanks for sharing that is a beautiful shot Logan looks amazing on these projectors
post #925 of 5526 Old 05-10-2019, 05:10 PM
rustolemite's Avatar
Quoted: 383 Post(s)
Liked: 135
HDR improvement is 200% honestly if not more. Black level, contrast, depth, sharpness and resolution I would say about 25%. Black level increase would be only about 10% but then again the black levels were really good on the 5040 already.
What Color Mode and Power/Fan setting are you using?
VIDEO: Epson 5050UB * SeymourAV CenterStage XD 137.7" * Samsung UBD-M9500 * Nvidia Shield * HTPC * Xbox OneX * URC MX-990
AUDIO: Yamaha RX-A3080
SPEAKERS: PSA MTM-210T L/C/R * PSA MTM-110 (2) Surrounds * S2(4) Atmos * HSU VTF-3MK4
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #926 of 5526 Old 05-10-2019, 05:17 PM
Quoted: 383 Post(s)
Liked: 135
So hooked my 5050 up a little while ago, and one thing I noticed was it seemed to take a little longer to switch input devices than on the 5040, this could be just me not sure.
I was using the 5040 on Bright Cinema + Eco Mode and left Rec.2020 on, I tried Bright Cinema on the 5050 but it's not the same for now I am using Dynamic + Eco mode which I so far enjoy the most.
Anybody that's using Eco mode do you have any settings you can share?
post #927 of 5526 Old 05-10-2019, 05:57 PM
Liked: 1177
I have been using Bright Cinema with Medium Power Consumption and preset 3 with high speed auto Iris. I usually don't really dial in any settings until the lamp hours get to around 100 and let the lamp brightness start to normalize. I have heard alaric's settings work really well. I will play around with his settings this weekend
post #928 of 5526 Old 05-10-2019, 06:10 PM
Quoted: 55 Post(s)
Has anyone been able to watch YouTube videos in 4K/60hz?
My 5050ub works up to 4K/30hz but at 4K/60hz, the video either won't load at all or it's extremely choppy and unwatchable.
I have an expensive fiber optic HDMI cable and my receiver is set up to 4:4:4 on all HDMI inputs/outputs.
If anyone can get 4K/60hz for YouTube to work, please let me know.
Gellert is offline
post #929 of 5526 Old 05-10-2019, 06:22 PM
Liked: 1177
What streaming device are you using with YouTube?
post #930 of 5526 Old 05-10-2019, 06:26 PM
Quoted: 55 Post(s)
I'm using the Amazon Fire 4K (2nd generation). It's on the latest firmware.
Everything looks great but it can't do 4K/60. One of the reasons I bought the 5050 was it's supposed ability to stream YT in 4K/60.
Gellert is offline
5050 , 5050ub , Epson , frame interpolation , motion smoothing , shieldtv , strdn1080
