THE Epson 5050UB/6050UB Thread (No Price Talk) - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 1344Likes
post #241 of 4654 Old 04-14-2019, 06:45 AM
groggrog's Avatar
Quoted: 64 Post(s)
Originally Posted by Alaric View Post
All seems fine then. Assuming others have updated the 5050 and the file works i can't think of much else.
Corrupt file download or unzip fault, may be worth a second go but we're into unlikely realms.
Just the .bin file on the root of a blank fat32 drive should do it.
Certainly be interested in how it gets sorted for my FAQ!
Sent from my HTC U11 using Tapatalk
Yes, thanks again Alaric, will let you know when I have it sorted out.
Alaric likes this.
groggrog is offline
post #242 of 4654 Old 04-14-2019, 08:00 AM
groggrog's Avatar
Quoted: 64 Post(s)
Man, this should not be this hard. I even created a 100mb partition on the USB key, no other partitions on it. The firmware file is EPSONPJ_t5ul.101.bin and it is in root. By default format creates a hidden “System Volume Information” folder and I tried with and without that. Still the same. Just endlessly flashes the three lights. Has anybody else been successful with upgrading the firmware on the US 5050UB to 1.01?
groggrog is offline
post #243 of 4654 Old 04-14-2019, 09:16 AM
BIC2's Avatar
Quoted: 203 Post(s)
Liked: 53
Originally Posted by scottyroo View Post
Movies trade blows but right now I’d give edge to BenQ because just how dead simple it is to get the picture I like with auto HDR.
I was about ready to pull the trigger on the 5050 but this is one thing that gives me pause. I'll use it mostly for movies; I just want to throw the disk in and go, not have to screw around with settings for each movie.
I seem to remember the new disk players coming out from Sony and/or Panasonic have auto tone mapping (I don't even know what tone mapping is), but I could be wrong on that. Thanks.
BIC2 is offline
post #244 of 4654 Old 04-14-2019, 09:23 AM
JonfromCB's Avatar
Quoted: 238 Post(s)
Liked: 166
I certainly hope you solve this soon. For the sake of others it would be helpful to hear what Epson has to say about why you are having the update problem, and it would be helpful to many of us to hear what Marantz/Denon has to say about the signal/cable issue. Thanks and good luck.
JonfromCB is offline
post #245 of 4654 Old 04-14-2019, 09:25 AM
Cattledog's Avatar
Quoted: 72 Post(s)
Liked: 44
I have a 5040UBe combined with a Panasonic DP-UB820 and once I had it set up the way I liked I have never had to change my settings. I assume the 5050 would be the same.
BIC2 likes this.
Reality Based.
Cattledog is offline
post #246 of 4654 Old 04-14-2019, 10:13 AM
groggrog's Avatar
Quoted: 64 Post(s)
Still stuck on the firmware update issue. I suspect it’s that Windows keeps rewriting the System Volume Information folder to the USB key before I remove it from the PC so it’s confusing the Epson. Tomorrow I’m going to try and write the file to the same key using MAC instead of Windows and see if it changes anything.
As for the signal issue I think I just solved it. Fingers crossed it doesn’t happen again but I think I figured out what to do if it does happen again. What I did was eliminate the Marantz from the picture by removing the HDMI cable for each source device. Then I plugged my Optical extender directly into each device one-by-one, making sure the HDCP 2.2 light on the extender lit up. Then I inserted the HDMI cable for that device back into the Marantz and then the extender into the Marantz. One by one every device lit up, so now they’re finally all working. Looks like it was an HDMI handshake issue. Since I am replacing a 4050 with a 5050 maybe the HDMI signals got screwed up and I just had to reset them by doing that process. Whatever it takes. All good now so going to enjoy. Will let you know if it comes up again. Thanks for your interest!
Alaric and JonfromCB like this.
groggrog is offline
post #247 of 4654 Old 04-14-2019, 10:36 AM
gene4ht's Avatar
Quoted: 1994 Post(s)
Liked: 2715
Some enthusiasts represented here strive to maximize performance...either by personally experimenting and tweaking or by professional calibration...it's the nature of the hobby for some. On the other side of the spectrum, I would venture to say there are also enthusiasts here who take the PJ out of the box and never or minimally touch adjustments...and are perfectly happy. And likely, others are somewhere in between.
The question is do you adjust brightness, contrast, and color for each movie or program when watching your TV/flat panel? Or do you set it and forget it? Bottom line, this hobby affords something for everybody and to each their own...there is much to like about projectors...the 5050 is no different.
Relative to tone mapping...simple explanation....some HDR content tends to be too dark...some players have a "slider" that adjusts overall image brightness.
WynsWrld98, JonfromCB and BIC2 like this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #248 of 4654 Old 04-14-2019, 04:16 PM
skylarlove1999's Avatar
Quoted: 1134 Post(s)
Liked: 800
I have a 5040UBe combined with a Panasonic DP-UB820 and once I had it set up the way I liked I have never had to change my settings. I assume the 5050 would be the same. [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG]
I have the same combination except for I don't have the wireless and it delivers an amazing picture quality especially in HDR which I never thought I would say about a projector honestly. I had originally set up with an Oppo 203 quite frankly the Panasonic beat the Oppo 203 in every respect picture quality up conversion of 1080p to 4K and audio
skylarlove1999 is offline
post #249 of 4654 Old 04-14-2019, 07:03 PM
BIC2's Avatar
Quoted: 203 Post(s)
Liked: 53
I'm probably going to do a 125"-130" diagonal 16:9 screen. Dedicated, completely dark theater. Throw distance can be 15-18 ft or so. First row (MLP) about 12 ft, second row about 16 ft. Would 0.9 gain spandex be a good choice to go with the 5050? If not, any recommendations for a suitable AT screen? Thanks.
Epson Pro Cinema 6050, Seymour Center Stage XD 130"w 150"d 16:9, Onkyo DX-C390 Six-Disk CD Changer
Triad Silver Speakers (11 in a 7.2.4 configuration), 2 JTR 118HT Subwoofers
Yamaha CX-A5200 11 Channel Processor, Monoprice Monolith 11 Channel Amplifier
Panasonic DP-UB820 UHD Blu-ray, Sony BDX-BP57 BD/SACD, Harmony Elite Remote, 10 Seats
BIC2 is offline
post #250 of 4654 Old 04-14-2019, 07:04 PM
BIC2's Avatar
Quoted: 203 Post(s)
Liked: 53
Is the 6050 available? Any MSRP? Thanks.
BIC2 is offline
post #251 of 4654 Old 04-15-2019, 08:17 AM
groggrog's Avatar
Quoted: 64 Post(s)
Unfortunately that fix was short lived. Next time I powered everything up every source was again unable to connect. At this point I have switched to using a 24 foot HDMI cable temporarily (works fine) while I work with the vendor of the optical extender to figure out what's happening.
groggrog is offline
post #252 of 4654 Old 04-15-2019, 08:40 AM
Madkao's Avatar
Liked: 3
HI,
I am in need of some advice please.
I just got my UHZ65 over the weekend and have been testing it in my non-dedicated theater room with a 125in SI Slate screen. The projector is about 13feet away from the screen. So far I am impressed with the picture quality. I currently own a Sony HW65ES projector. The difference in contrast and picture quality is significant.
However, I do notice a significant lag with the UHZ65 when I game. This was expected as I knew the lag on the UHZ65 is 80ms compare to my old Sony HW65ES at around 30ms.
I am thinking about maybe getting the new Epson 5050UB to test it out and see how it compares to the UHZ65. I understand the technology is quite different (laser vs lamp, DLP vs LCD?), but as long as the picture quality is just as good on the Epson, then I might switch to the Epson due to potentially lower lag. (I can't find the lag time for the 5050UB but I think i read somewhere the lag for the 5040UB was in the low 30s so I am assuming the new 5050UB shouldn't be too far off).
Can someone help me decide whether of not they think the 5050UB would be a good alternative to consider. Thanks!
Madkao is offline
post #253 of 4654 Old 04-15-2019, 08:54 AM
CallingMrBenzo's Avatar
Quoted: 645 Post(s)
Liked: 1430
I know that without doing the modification to your projector outlines by TVS Pros I believe the Epson hits more of the HDR color space and potentially has better contrast. If the filter is installed from what I have read it’s fantastic but almost double the price of the Epson. The lag if I remember is around 28.
Marantz 7011- Panasonic UB-820- Xbox One X - Epson HC 5050UB *Calibrated by ChadB* - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is offline
post #254 of 4654 Old 04-15-2019, 09:08 AM
Madkao's Avatar
Liked: 3
Thanks for the info!
Madkao is offline
post #255 of 4654 Old 04-15-2019, 09:11 AM
Quoted: 645 Post(s)
Liked: 1430
Having said that if you could afford to send to to TVS it’s like $1600 to modify it. It does not change the warranty and from the videos on YouTube makes that projector a very high end price of kit not only helping out the color coverage but also improves contrast. Of course this does not help your gaming situation
post #256 of 4654 Old 04-15-2019, 09:32 AM
Madkao's Avatar
Liked: 3
Thanks again. How does your Xbox one X do as a 4k bluray source for your Epson? Recommended or should I just get a dedicated bluray player? thanks.
Madkao is offline
post #257 of 4654 Old 04-15-2019, 11:17 AM
Quoted: 645 Post(s)
Liked: 1430
I still don't have the new Epson. I get that tomorrow night but I have taken the Xbox out of the equation long ago. yes, it plays a 4k disc that is that. It does not do it well, and I often had audio drop outs for a hot second when playing discs only. I purchased it to do a little gaming which I didn't end up doing often enough and to get Atmos support through the Netflix app. I will be picking up a Panasonic UB 820 when I get my Epson tomorrow. I feel when spending this kind of money, I should make sure I pair it to fantastic player which the Panny is. I will not bother wondering if there is any more performance left on the table. It also provides the option to do tone mapping with its HDR optimizer function which has been highly reviewed. As a bonus it provides Neflix and Amazon apps which support Atmos and 4K HDR.
So I will gladly spend the extra $500 to get PQ that rivals or surpasses an Oppo and adds streaming apps to boot.
post #258 of 4654 Old 04-15-2019, 12:00 PM
Stephen Opipari's Avatar
Quoted: 12 Post(s)
I ended up ordering a new 5050UB last Friday to replace my Vivitek HK2288, which is only a year-ish old. Don't like sending in the Vivitek for firmware updates (in fact it's out for one now) and I see rainbows with it too. I was looking at the 5040 when I bought the HK2288 and opted against it because there wasn't an 18GB connection for my XB1X.
Since the 5050 fixed my complaint about the 5040 and my Vivitek has been off site for over 10 days now, I pulled the trigger. My 5050UB shows on Wed, very much looking forward to it.
CallingMrBenzo likes this.
Stephen Opipari is offline
post #259 of 4654 Old 04-15-2019, 02:37 PM
Luminated67's Avatar
Quoted: 751 Post(s)
Liked: 416
The Crimes of Grindelwald (1080p) 4K Enhancement ON + image enhancement Preset 3
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #260 of 4654 Old 04-15-2019, 06:42 PM
germanplumber's Avatar
I've got mine on order from Best Buy. Should be here by the 23rd for pickup.
germanplumber is offline
post #261 of 4654 Old 04-15-2019, 08:30 PM
mactoast's Avatar
Quoted: 42 Post(s)
Liked: 36
I have not been on an Epson thread in years even though I own and still use a 6010. But, its time to upgrade and was about to buy a JVC 790 which really does seem like a great deal at its lower price. But now with the new Epson out its got me wondering. The JVC has always been highly regarded but there are complaints about varied amounts of E-shift buzzing noise which concerns me. Have any of the Epson shifters ever suffered from anything similar? Price points are close enough for me to consider either one but hate to get a noisey JVC and potentially have issues getting a replacement this close to the reported end of its production. These new Epson sound very good for the money also.
mactoast is offline
post #262 of 4654 Old 04-15-2019, 08:46 PM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 825
So I’ve been doing some more prep work for my shoot out with the BenQ HT5550 and thought this would be an interesting share since 1) I am on record for not recommending the HT5550 for sports (foot now in mouth) and 2) I still can’t get past that I can see pixels from 16 feet away on my 160” screen. Call me crazy.
A member here known as Kraine reviews for a site called passionhomecinema.fr and he posted his review of the HT5550 today. I used his settings in the User mode and a new veil was lifted for use of the HT5550. Nearly 1500 lumens of color accurate image, within a margin of error of the 1800 or so good lumens from the 5050UB. Picture of the theater and the HT5550 playing with my back half completely illuminated.
And some shots of the projectors in action. The Epson is in Alaric’s recommended settings and the HT5550 in Kraine’s (love our community). 4K enhancement is on - image preset 2.
GlenH and CallingMrBenzo like this.
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #263 of 4654 Old 04-15-2019, 09:17 PM
MidnightWatcher's Avatar
Quoted: 200 Post(s)
Liked: 201
Good pics. If you need to zoom in that much to see pixels, I think the majority will be very happy with the 5050, especially with better blacks/contrast.
Question - are the pixels visible with the naked eye up close with 4K enhancement on, or is that just the camera capturing what it sees in a split second that isn't visible to the naked eye?
My Theater | Vero 4K | Epson 5030UB + Peerless PRG-UNV | 100" EluneVision Reference 4K Screen | Denon X3600H @ 5.2.4 | 4 x ADX Maximus w/ Dayton Audio SA230 | Polk Audio RTi A9 + CSi A6 + OWM3 + Micca M8C + SVS PC2000 + Monolith 15 | 40" HDTV w/ Z83V Mini PC + MoviePosterApp | Z83V + DietPi FTP Server + 3 x 8TB HDDs + 4 x DLink DHP-701AV
MidnightWatcher is offline
post #264 of 4654 Old 04-15-2019, 09:22 PM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 825
True for most. However those who a) are coming from a True 4K projector and b) have good eyes, will notice. Coming from 1080p or the 5040? You’ll be happy. If you think you meet both criteria, chances are you need to see an eye doctor because I can most definitely tell a difference.
And while you make a good point, what is the point of 4K then? Especially as screen sizes are trending towards bigger and viewing distance preferences trend towards closer to screen?
My question is rhetorical... I don’t want to debate that here. Haha I will just continue to beat my drum. Don’t mind me.
post #265 of 4654 Old 04-15-2019, 09:31 PM
Quoted: 200 Post(s)
Liked: 201
There's also the matter of cost for the price conscious -- whether it's by choice, resources or by force (WAF) \o/. Not sure who would be coming from a true 4K projector to a pixel shifter, unless it's for the increased brightness for HDR. Bottom line is that people will decide based on what's important to them and what isn't. There's no wrong choices.
post #266 of 4654 Old 04-15-2019, 09:58 PM
FendersRule's Avatar
Quoted: 51 Post(s)
Liked: 38
Assuming that’s a 4K source?
Since most sources are 1080p, does the 4K enhancement make the image softer like the prior models?
FendersRule is offline
post #267 of 4654 Old 04-15-2019, 09:59 PM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 825
Per CTA HT5550 is ‘True 4K’, Sony 295ES is ‘Native 4K’.
Pictures above are of a True 4K 1080x4 shifter vs a 1080x2 shifter. 4.1M pixels vs 8.3M pixels. Some will prefer the blacks and input lag of 5050. Some will prefer the higher resolution and motion handling of HT5550. Hopefully all this info is to help people make a decision they’ll be happy with.
post #268 of 4654 Old 04-15-2019, 10:00 PM - Thread Starter
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 825
This is of a 4K source, yes. Many reviewers of the 5050 say that the 4Ke has improved vs last gen and to just leave it on the whole time. I agree.
post #269 of 4654 Old 04-15-2019, 10:07 PM
Quoted: 200 Post(s)
Liked: 201
Per CTA HT5550 is ‘True 4K’, Sony 295ES is ‘Native'.
Ah I see, I presumed "true" and "native" were synonymous.
WynsWrld98 and Alaric like this.
post #270 of 4654 Old 04-15-2019, 10:08 PM
Quoted: 51 Post(s)
Liked: 38
Cool. I’d love for you to do some 4ke on and off for common blu rays with those same grade photos!
WynsWrld98 likes this.
5050 , Epson , frame interpolation , motion smoothing
