Originally Posted by
Frank714
As a DLP owner who had a JVC 5500 for testing in my home theater I can confirm that its contrast ratio and black levels are unbeatable (and therefore is one of my upgrade candidates, although Sony's MotionFlow Frame Interpolation is probably better than JVC's Clear Motion Drive).
In terms of 3D the general consensus is that DLP delivers best, but has been downgraded to "DLP Link" only (JVC uses 3D-RF glasses). Supposedly JVC isn't flicker-free (3D works at 96 kHz in contrast to DLP's 120 kHz), but my eyes are so slow that I neither notice flicker or DLP's rainbow effect.
4K eShift supposedly isn't that great with a JVC, but one of the recent Panasonic UHD players should improve the 4K performance.
With all you need to weigh up the Pros and Cons.
JVC - Pros: blacks and contrast, motion, lens memory
Cons: slow handshake, e-shift, expensive to buy and replace bulbs
Sony - Pros: Native 4K, motion and Reality Creation
Cons: low lumens, expensive to buy & bulbs, average HDR
DLP - Pros: cheap to buy, True 4K, motion
Cons: poor contrast, rainbow effect, no great HDR
Epson - Pros: cheapish & cheap bulbs, decent contrast, high lumens, handshake, lag, HDR, lens memory
Cons: e-shift, size, noise in high fan mode
Personally I don’t see e-shift as a negative on either the JVC or Epson but since the others are better I put it there.
