Projector recommendations please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-28-2019, 05:21 AM - Thread Starter
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 156 Post(s)
Liked: 79
Looking for a projector to replace my Optoma HD50 in a completely light controlled and black dedicated theatre room.
On a budget so looking for secondhand/closeout/refurbished deals etc
Would like it to have Lens Memory or Powered Zoom as I have CIH screen setup
Ideally would love a Laser but will settle for a lamp
Epson 5040UB seems to fit the bill but looking for other suggestions up to $2000
niterida is offline
post #2 of 4 Old 04-28-2019, 07:16 PM
rekbones's Avatar
Quoted: 1057 Post(s)
Liked: 547
A gently use JVC is about your only other and best option as no others have lens memory. A RS46/x35 or newer preferably a RS400/x520 or better if 4K/HDR is wanted. Be very careful as many owners way over price these used JVC's asking way more then they are worth but if your patient good deals come up all the time.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 4 Old 04-29-2019, 12:21 AM - Thread Starter
Quoted: 156 Post(s)
Liked: 79
The used JVCs seem to be very expensive
After a long hard search the choices are basically 5040UB or Benq W2700/HT3550 - I can live without powered zoom and brand new they are cheaper than 5050 second hand
Or I could fix my HD50 as I have found a cheap repair for exactly my symptoms and then save up for a 4K Laser projector
niterida is offline
post #4 of 4 Old 04-29-2019, 04:06 AM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
Used RS-46's or RS-4810 go for about $1200 in the AVS Classified section, sometimes less.
Ebay doesn't have many good deals on projectors, thanks to the high fraud rates (against sellers) of high-end used electronics.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
