Epson PowerLite Home Cinema 5010 Blues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-15-2019, 07:48 AM - Thread Starter
Russ Rubman's Avatar
Quoted: 99 Post(s)
Liked: 29
I have an Epson PowerLite Home Cinema 5010 and it has stopped working.
The lamp leaves wont retract and the thing won't respond to any commands. Just a blue blinking light.
Does anyone know if this spells the end for my PJ (since it's not valuable enough to send out for repair) or if this is maybe just indicative of a lamp replacement required?
I took out the lamp cube and it looks OK to my eye (not sure what I should expect to see). I also don't want to buy a new lamp just to find out that it isn't the issue.
Out of warranty now so Epson won't advise :-(
Russ Rubman is offline
post #2 of 2 Old 05-16-2019, 07:35 AM
descalabro's Avatar
Quoted: 386 Post(s)
Liked: 129
Hi,
which blinking blue light is it? Does it have any specific pattern to the blinking?
What do you mean by "The lamp leaves wont retract"?
Is there any activity on the fans, or ar they stopped? If there is, are they spinning loudly or normally?
descalabro is online now
