Help help help choosing between Optoma hd50/HD161X or Benq W1070 at the same price - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rekbones
post #1 of 13 Old 05-19-2019, 03:44 PM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Hi everyone I am asking you for a urgent help about which projector choose. I can have them at the same price $330 and I can’t decide. The main use would be movies in a dark rooom 100” screen. A very simple set. I am grateful for any suggestions. Thank you
jimmyp1974 is online now
post #2 of 13 Old 05-19-2019, 06:20 PM
bud16415's Avatar
Quoted: 1988 Post(s)
Liked: 1005
I like the BenQ of those 3 with the RGBRGB color wheel. Are these new projectors or used?
For 375 you can still buy a refurb Viewsonic Pro7827HD-S straight from Viewsonic. The model number without the –S is the original now discontinued number. I have this projector and it has some nice features the BenQ doesn’t.
Bud
bud16415 is offline
post #3 of 13 Old 05-19-2019, 07:10 PM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 479
These are both old discontinued projectors. The HD50 should be the better projector as it also has an RGBRGB wheel and FI as a bonus. If the are used projectors its a crap shoot as to what one is the best.
Frank714 likes this.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 13 Old 05-19-2019, 08:44 PM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Thank you very much. Yes they are both used. Each $300 same price. The Optoma with less hours on bulb while the BenQ just a thousand. I don’t know what to do, I am a little confused.
post #5 of 13 Old 05-20-2019, 12:19 AM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 479
The Optoma is the higher level projector so if it's in good shape that's the one I would pick.
rekbones is offline
post #6 of 13 Old 05-20-2019, 05:27 AM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Thank you for all your suggestions. I ended up in buying the Viewsonic refurbished as suggested by a member straight from the factory. I hope it is a good unit because after taxes and shipping it comes up to $450. I hope I did the right thing. I needed some built in speakers due to the present situation and the Optoma doesn’t offer this option
post #7 of 13 Old 05-20-2019, 04:07 PM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Hi I still need a help! Which is better a Benq HT2050 with 1200hrs on bulb or a factory refurbished Viewsonic pro 7827hd each at $440 including shipping? I would really appreciate any advice I have to close as soon as possible. Thank you infinitely
post #8 of 13 Old 05-20-2019, 07:01 PM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 479
I go for the one with the best warranty.
rekbones is offline
post #9 of 13 Old 05-20-2019, 08:08 PM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Well the Viewsonic offers just a 3 months warranty and the other projector the BenQ is a used from a private seller with no warranty. Same price, Viewsonic factory refurbished the other perfect condition with 1200 hrs on bulb. Thank you
post #10 of 13 Old 05-21-2019, 05:24 AM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Please I need some advice to do the right choice and avoid unpleasant return of the projectors. Thank you very much
post #11 of 13 Old 05-21-2019, 06:37 AM
rekbones's Avatar
Quoted: 917 Post(s)
Liked: 479
Both projectors are very similar in performance unless you know the seller personally and know the history of the projector why would you gamble on a USED projector over a factory certified refurbished projector with at least some warranty for the same price.
rekbones is offline
post #12 of 13 Old 05-21-2019, 06:48 AM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Yes the refurbished one looks like a more safe deal. I don’t know the owner of the used BenQ. My only concern is about the Viewsonic noisy fan pointed out by many user. I am going to place the projector just over my head... do you have any experience with this projector?
post #13 of 13 Old 05-21-2019, 06:48 AM - Thread Starter
jimmyp1974's Avatar
Quoted: 35 Post(s)
Thank you for your suggestions
