Would my projector show a better image if my wall colors were different? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-04-2019, 09:41 AM - Thread Starter
Quoted: 130 Post(s)
Right now they are agreeable gray.
ng4ever is offline
post #2 of 8 Old 07-04-2019, 05:15 PM
kthejoker20's Avatar
Quoted: 31 Post(s)
probably not.
Unless you calibrate it and your wall lid smooth
Sent from my Pixel XL using Tapatalk
kthejoker20 is offline
post #3 of 8 Old 07-04-2019, 06:46 PM
markmon1's Avatar
Quoted: 5225 Post(s)
Liked: 3393
Originally Posted by kthejoker20 View Post
probably not.
Are you using your wall as a screen? Or just asking if avoiding the reflections would help? If reflections, read the "blacker theater better image" thread.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #4 of 8 Old 07-04-2019, 09:01 PM
airscapes's Avatar
Quoted: 516 Post(s)
Liked: 428
your probably fine but here is a thread with 6200 posts on the subject
https://www.avsforum.com/forum/24-di...ter-image.html
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is online now
post #5 of 8 Old 07-05-2019, 09:53 AM
Dave in Green's Avatar
Quoted: 3787 Post(s)
Liked: 3001
Since you've stated in another thread that you have a matte white screen the answer to your question is simple. The darker the walls (and ceiling and floors) the less cross-reflection you'll get from image light from the screen reflecting off room surfaces and back onto the screen, contributing to at least mild image washout. Obviously bright white is the worst for cross-reflections and flat black is best. So anything darker than what you already have will make incremental improvements in image performance.
The next question is how dark to go and whether it's worth the compromise to you and your spouse. For example, it's easier justifying a flat black dedicated theater room than a flat black mixed use family room. Beyond this general advice it's entirely up to you how dark you want to paint your room for the incremental improvement each darker shade of paint will provide. For some, agreeable gray is as dark as they would want to go for a mixed use family room while for others it might be too light or too dark. It's purely a personal preference compromise between image performance and room esthetics.
Dave in Green is offline
post #6 of 8 Old 07-05-2019, 11:11 AM
AV_Integrated's Avatar
Quoted: 1611 Post(s)
Liked: 1184
Yes.
The answer to this is pretty much ALWAYS going to be yes.
Not sure the make and model of your projector. Entry level DLP projectors have a pretty weak black level floor, but they do produce a good entry level image. Entry level being a key point. If you are looking for top tier results after paying an entry level price, then you will need to adjust your expectations accordingly.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #7 of 8 Old 07-05-2019, 11:23 AM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
The answer is by a 'huge' amount, yes... You need to treat the ceiling as well, and I would use Triple Black Velvet instead of paint. Black paint will never be all that great.
It won't help the really really dark scenes that much, but it will help evening time to dark scenes with some bright highlights in them, hence mixed 'darkish' scenes will be helped quite a bit, and evening time scenes will be improved immensely.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #8 of 8 Old 07-05-2019, 12:29 PM - Thread Starter
Quoted: 130 Post(s)
Originally Posted by AV_Integrated View Post
Yes.
I have a BenQ HT3550
ng4ever is offline
