Difficult mounting scenario - massive skylight in center of room ! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By descalabro
post #1 of 10 Old 07-17-2019, 06:17 PM - Thread Starter
Liked: 0
Hi guys,
I've installed probably 20 or so projectors commercially but I find myself in a challenging scenario for an install in a Tap House.
Specifics:
150" 16:9 Motorized screen suspended from ceiling just 6" or so
16:9 projector w/ installation features such as vertical lens shift, 12v trigger out, etc
3 Possible projector locations:
1. 18'-25' directly in front of projector
2. 9' 6" directly in front of projector
3. 9' directly behind projector
Location 1 would be the obvious choice if there wasn't a goddamn skylight. Pretty much all my top pick choices for 5000 lumen installation projector are within this throw range. The issue here is we are literally shooting through light coming in from above skylight on route to projector screen.
Location 2 should be better.. still ambient light will reach the screen but the projector will be brighter at this distance and not shooting through ambient light. The trick here is finding one with a throw range that will work.. .7-.8 ratio puts us into short throw territory though.
Location 3 just occurred to me.. rear projection scenario, imagine there is an ambient light rejection screen that is meant for rear projection and will block out the front-facing ambient light. Again the throw range is a tough one. This Optoma seems to fit the job though: Optoma EH515st
* I installed a short throw projector once.. it looked terrible, sure they're better these days
bencarson is offline
post #2 of 10 Old 07-17-2019, 06:33 PM - Thread Starter
Liked: 0
Layout / Photo attached
ID:	2592052   Click image for larger version
post #3 of 10 Old 07-17-2019, 06:35 PM - Thread Starter
Liked: 0
That entire area that is not drywalled in is becoming a skylight LOL
I will update on the progress of this project regardless but welcome all input too
post #4 of 10 Old 07-18-2019, 07:03 AM
descalabro's Avatar
Quoted: 407 Post(s)
Liked: 155
Originally Posted by bencarson View Post
Hi guys,
Specifics:
Hi,
why is there no option of installing a device to cover and uncover the goddamn giant skylight?
I think shooting through light doesn't make any difference. As far as I know, light rays do not interfere with each other, so you'll have the same amount of natural light hitting the screen on all 3 situations.
rekbones likes this.
descalabro is online now
post #5 of 10 Old 07-18-2019, 08:19 AM
bud16415's Avatar
Quoted: 2065 Post(s)
Liked: 1030
Originally Posted by descalabro View Post
Hi,
This is correct. You can set up two projectors 90 degrees to each other and one wont interfere with the other.
With a skylight that big there is little you can do to expect it to work in the daytime IMO. At night you have a chance.
Bud
bud16415 is offline
post #6 of 10 Old 07-18-2019, 11:04 AM
Quoted: 618 Post(s)
Liked: 325
Hi guys,
Specifics:
2- The BenQ LK953ST would work:
https://www.projectorcentral.com/Ben...ulator-pro.htm = 152in at 9ft
and:
https://www.projectorreviews.com/ben...w-performance/ = ~4000 lumens.
DunMunro is online now
post #7 of 10 Old 07-18-2019, 01:11 PM
AV_Integrated's Avatar
Quoted: 1563 Post(s)
Liked: 1156
The skylight is the issues because it's a skylight.
It won't actually interfere in any way with the light that is coming out of the projector, it is just going to completely destroy the on-screen image because it is letting a ton of daylight in.
If the use of the 150" setup is for after dark only, then just install any projector in front of, or behind the skylight and call it a day.
I don't really see any problem here at all.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #8 of 10 Old 07-21-2019, 10:51 AM - Thread Starter
Liked: 0
Thank You for the input!
Suppose I will just proceed as normal and tell them that it won't work in daylight unless they invest in skylight covering.
That said, even with the front ambient light rejecting screen / rear projection scenario, it won't make it that much better ? I've never done one of these. I gather though that the extra costs would be better put towards skylight covering.
Projector will be mostly used at night, but during summer hours it's light out until 10pm here.
post #9 of 10 Old 07-22-2019, 03:00 PM
Dave in Green's Avatar
Quoted: 3670 Post(s)
Liked: 2874
A moveable covering for the skylight would be the most effective, economical and elegant solution along with a standard projector and screen. If the customers ask for an explanation ask them if they've ever been to a commercial movie theater with a giant skylight in the middle of the ceiling flooding the theater with sunlight.
Dave in Green is offline
post #10 of 10 Old 07-22-2019, 03:57 PM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
I would suggest that you go look at any sports bars in your area that have projectors set up to get a feel for it. Since you have projector installation experience, looking at some actual install's will be worth a thousand opinion posts on a forum. I would also suggest that you stay away from rear projection. There is a propensity to have hot spotting with on axis viewing with rear projection and rear projection usually has reduced brightness uniformity off axis as well.
There is a local watering whole near me overlooking a lake. They have three projectors set-up on very inexpensive (cheap) 120" pull down screens. The projectors are Epson HC 21xx units and they do a good job for sports and TV.
I've attached a customer snapshot from their facebook website. The picture is not in focus, but, you can see there is a fair amount of ambient room light and the front of the room projector is backed by windows over looking the lake. The projector still works during the day by adjusting the window shades.
b curry is offline
