Need some connection help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-18-2019, 06:10 AM - Thread Starter
Morphx2's Avatar
Quoted: 18 Post(s)
Hi everyone,
I am having trouble figuring out connection options for a projector
Right now I have a Vizio 5.1 sound bar that mainly has an optical in and a 3.5mm input; no HDMI in or HDMI out
I have an Nivida Shield that goes from the Shield, to the TV, and then optical from the TV to the sound bar.
I would like to get a projector for the room too; which would be on the opposite side of the room.
What options would there to hook up the projector?
I thought of a Firestick 4K at the projector and bluetooth the sound to the sound bar by buying a bluetooth receiver to the 3.5mm input of the sound bar; but I hear that can cause sync issues; and would the 3.5mm still bring the dolby/DTS or just stereo?
Thought of getting a wireless HDMI sender/receiver ($$) for the projector ; and then I would assume I would also need an HDMI splitter-type device (and audio extractor for the optical to the sound bar) from the shield to the TV/projector. On the same note, I can wire an HDMI all around the room, but would have to make it look nice and neat for wife approval (a lot of wire tracks I guess).
Any other ideas I am missing?
Morphx2 is online now
post #2 of 2 Old 07-18-2019, 07:02 AM
rekbones's Avatar
Quoted: 986 Post(s)
Liked: 510
Sound bars and projectors don't go together very well. The best solution is a HDMI switch with opt out for audio, their might be a splitter with opt out. I would get rid of the sound bar and get an AVR as its much more practical can even cost less and sound much better.
https://www.ebay.com/itm/HDMI-1x2-HD...MAAOSw4ylccEcn
This will do what you need.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
