30’ throw with an Epson 5040UB? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-14-2019, 08:11 AM - Thread Starter
crimsonblue's Avatar
Quoted: 138 Post(s)
Liked: 89
I’m considering the projector placement right now, and it dawned on me that I have a 24” rear soffit where I could put a projector. Easy connections to the rack, and completely out of sight, minus the hole for the lens to pop through.
An Epson 5040UB can throw 30 feet to a 150” screen. What are the pros and cons of having it back that far?
Brightness may be slightly less (image would be telephoto light cannon vs a wide angle, but supposedly the contrast would be better.
Anyone else do a long-throw projector and/or have thoughts?
________________________________________________
Home theater build 1 | Black & Grey Theater 2 | Yet Unnamed Theater 3
Marantz AV7702mkII | Epson 5040 | 7.2.4 Elusive 1099 LCR + Volt 8 Atmos & Surrounds + Dual UM18 Subs
crimsonblue is offline
post #2 of 13 Old 08-14-2019, 09:53 AM
DavidinGA's Avatar
Quoted: 235 Post(s)
Liked: 82
It's gonna be pretty dim at that distance even with a fresh bulb in the pj. Get the pj setup and try it for youself; maybe you'll like it, who knows...
According to the online calculators that would put you at 25 fL at the 5040's brightest setting. Once calibrated that will be much much dimmer.
Source: HTPC w/madVR, Video: Epson 4000, Epson 5040 (coming soon), 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofer: MiniMarty um18 w/NX3000D.
DavidinGA is offline
post #3 of 13 Old 08-14-2019, 11:18 AM
Dave in Green's Avatar
Quoted: 3670 Post(s)
Liked: 2874
Independent testing by projectorreviews.com measured the 5040UB lens losing over 40% of lumens when going from full wide angle to full telephoto. A 24' throw is about 3/4ths of maximum throw to a 150" screen so figure somewhere in the neighborhood of 30% lumen loss over mounting at the closest throw (14' 9"). As long as it's satisfactorily bright with a new lamp the main penalty for mounting so far away from a 150" screen is that the lamp would need to be replaced more frequently as it would reach unacceptable dimness sooner in the aging process.
Dave in Green is offline
post #4 of 13 Old 08-14-2019, 02:39 PM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
Light is subject to the inverse-square law. Simplistically, if you double the distance from the light source, you will have 1/4 the intensity. If you triple the distance from the source you will have 1/9 the intensity, etc. You also have to understand that while doubling the distance results in 1/4 the intensity, the light is also spread out over 4 times the area and triple the distance will result in 9 times the area, etc. as well.
In your case, you're proposing to use the same area of illumination or a fixed area, that is a 150" diagonal 16:9 aspect screen. Using that fixed area within the throw distance zoom range of the 5040 for that fixed area should give you ~ the same brightness within that throw range of ~14'-30'. Any drop in brightness will be associated with the lens' speed and construction and not so much the inverse-square law as the lens is able to concentrate the light flux on the same size area using the telephoto aspect of its design. In other words, you're not going to see a very noticeable difference in brightness in your situation.
No doubt people posting will take exception sighting the lumen drop as reported in Projector Reviews review of the 5040ub and different throw/zoom positions. What's not taken into account is that Projector Reviews reports different throw/zoom positions with different image sizes. Any brightness drop suggested sighting this review as a reference is inaccurate and an apples and oranges comparison as you're proposing changing the throw for a fixed size area vs. brightness drop from the review using different size areas. This of course brings you back to the inverse-square law and will account for the difference in brightness relative to the area illuminated in Projector Reviews review.
IMHO the Epson 5040ub is perfect for your application of mounting at 24' and stretching the throw to 30' if you must. Keep in mind that the brightness or foot-lambert value (what your eye sees) can be mitigated by increasing the screens gain. Increasing the gain from a 1.0 screen to a 1.3 gain screen can get you an easy 5-8 fL increase with the same throw from the same projector and settings.
b curry is offline
post #5 of 13 Old 08-14-2019, 03:00 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
Very interesting -- and differing -- perspectives!
This adds some visuals to my setup. There is a bulkhead all around, extending 24 inches in the back, 36" on the sides, and 48" in the front (to hide the speakers behind the screen).
35 feet total
-3 feet in front (bulkhead will overhang screen by 12" for lights"
-2 feet in the back for projector mounting in box
30 feet of throw
Name:	Screen Shot 2019-08-14 at 5.57.18 PM.png
ID:	2602966   Click image for larger version
post #6 of 13 Old 08-14-2019, 03:34 PM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
35 feet total
30 feet of throw
Yes it is... And quite easy to verify for yourself.
Set up your projector at the minimum throw distance and zoomed/focused for a 150" screen. Measure the light output in Lux or foot-candles. You can measure with the meter pointed at the projector, incident reading, or reflected from the screen surface. Move the projector to the maximum throw distance with the projector zoomed/focused for the 150" screen and measure again. You'll want to keep the meter aimed at or reading the same points for a fair comparison. I think you'll find the readings quite close in comparison.
b curry is offline
post #7 of 13 Old 08-14-2019, 06:05 PM - Thread Starter
Quoted: 138 Post(s)
Liked: 89
That makes sense, even to a simpleton like me.
If you take a zoomable flashlight and focus in on a 4x4 foot area on a wall, then walk forward while zooming out (widening) the beam size, the amount of light hitting the same size area (important note) will be the same. Being farther back doesn't make light go away or not travel as far - it's all still there - just directed to one spot. If the light weren't all getting there -- it would have to be going somewhere else.
post #8 of 13 Old 08-15-2019, 08:25 AM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
Bingo.
I'm not saying there will be no change. But the change should be rather small and associated with the lens speed change through it's zoom range. The possible change in contrast is influenced by the speed/aperture change as you've noted in your OP. You're also offsetting the inverse-square as you physically change the throw distance as the zoom changes to illuminate the same 150" screen size area. Your flashlight analogy is good.
And to quote Buckaroo Banzai, "No matter where you go, there you are."
b curry is offline
post #9 of 13 Old 08-15-2019, 03:03 PM
AV_Integrated's Avatar
Quoted: 1563 Post(s)
Liked: 1156
...Projector Reviews reports different throw/zoom positions with different image sizes.
No, they do not.
When you change the zoom on a lens, you change the aperture of the lens, with longer throw reducing the aperture and reducing the light output that the lens is capable of. This is photography 101. To get the same amount of light through a lens that is further away from something you need a much larger lens. This is why you see professional photographers with absolutely huge telephoto lenses. It's not to get the zoom, it's to capture the light into the lens.
With reviews I've done, I move the projector closer and further and keep image size the same (110" diagonal) and my light meter in the same position. If they simply adjusted the zoom without moving the projector and keeping the same image size that would indicate that they have no idea how lenses actually work or how to do their job.
Projector Central, by example, specifically measured a 33% falloff in light output for the 5040UB from closest to furthest.
So, with a 150" diagonal, which is 66.4 square feet, and a desire for at least 15 lumens per square foot, you would need right around 1,000 lumens minimum. This won't deliver solid 3D, and it will lack with some punch, but will work.
Since this is what really matters, then 1,500 measured lumens will be an absolute minimum (with 33% light loss) and that's something that the 5040 can't really do in it's absolute best mode, but can do bright cinema, in low-lamp mode, and get 1,800 lumens (closest) with about 1,200 lumens at 30' or so. That should be plenty solid for viewing.
But, have no doubt that there will be some light falloff.
The obvious way to get around this is to get a screen with 1.3 to 1.4 of gain and get that light right back! A minimal gain screen does a great job of adding punch, versatility, and flexibility to any installation that may need it. This one especially.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10 of 13 Old 08-15-2019, 04:28 PM
Liked: 2874
If the furthest throw distance is preferred for room esthetics just be aware that there ain't no such thing as a free lunch. The further back you go the higher the potential associated costs depending on how bright you want your image to be through the dimming process of the aging lamp. Mounting closer to the same size screen is the cheapest way to get more image brightness because it costs nothing. All other options, such as a higher gain screen, have associated costs.
As @AV_Integrated has confirmed, both projectorreviews.com and projectorcentral.com have measured a 30%-40% difference in lumen throughput between the 5040UB's full wide angle and full telephoto on the same size screen. It's a fundamental fact of projector zoom lenses that they all lose light throughput going from wide angle to telephoto, same as camera zoom lenses. The 5040UB's zoom lens is rated with a variable F-number of 2.0 – 3.0.
post #11 of 13 Old 08-15-2019, 05:32 PM
b curry's Avatar
Quoted: 995 Post(s)
Liked: 632
Originally Posted by AV_Integrated View Post
No, they do not.
Well then I would refer to section 8. EPSON HC5040UB, PC6040UB HOME THEATER PROJECTOR REVIEW PERFORMANCE - LAMP MODES, ZOOM EFFECT
Please explain why they list 3 zoom position lumen values each with a different image height.
https://www.projectorreviews.com/eps...es-zoom-effect
Correct. After looking at the spec's of the 5040ub, it has an f stop range, with out doing the math, of slightly more than one full stop. As I said in multiple posts, it will depend on lens speed. All lens/projectors are not equal as I'm sure you're aware. But the difference between mounting a 5040ub at 24' vs. 30' is de minimis. And will stand buy the fact that one would have to compare two 5040ub's side by side with the extreme's of the zoom limits and the projectors adjustments to see the difference and that an increase in screen gain from 1.0 to 1.3 will offset much of the difference.
Who could have guessed?
And Projector Central also states that the 5040ub can deliver 41% over spec and that Bright Cinema mode in high lamp comes in at the ~ advertised lumen value. My experience with the newer Epson's shows very little difference in Bright Cinema vs. Cinema for practical viewing. Measurement and calibration, yes, but for practical use, not so much.
https://www.projectorcentral.com/eps...ge=Performance
See my first post in this thread.
So if one were to use Bright Cinema mode, recommended in the Projector Central review BTW, at 2400 lumens and discount the value by 30% for the maximum throw with a 150" screen you would be left with 1680 lumens. 1680 lumens would yield 25 fL on a 1.0 gain 150" screen and 33 fL on a 1.3 gain screen of the same size.
SMPTE 196M defines the luminance target as 16ftL open gate or without a film in the projector, which typically equates to ~14ftL with a film. So using the 16 fL open gate number, the 5040ub would yield ~60% more luminance than required by SMPTE 196M on a 1.0 gain, 16:9, 150" screen and an ~110% luminance over SMPTE 196M using a screen of the same size with an increased gain of 1.3.
Is there something wrong with that? I don't know, but it seems to me there is some room for some lamp ageing in there too.
b curry is offline
post #12 of 13 Old 08-16-2019, 08:47 AM
Liked: 1156
You know, I'm not sure, but the reality is that I suppose that is another way to do things. I never thought about doing my measurements that way, but by the numbers they are giving, they did it exactly right...
With a image 66" tall and a total light output of 2137 lumens, then the meter would read about 39.51 lumens/foot over a 53.625 square foot screen area. (likely measured in nits and converted).
With a image 48.75" tall and a total light output of 1850 lumens, then the meter would read about 61.57 lumens/foot over a 29.94 square foot screen area.
With a image 31.75" tall and a total light output of 1463 lumens, then the meter would read about 115.47 lumens/foot over a 12.67 square foot screen area.
I wouldn't do my measurements that way, but as long as you plug in the math for the screen size you are working with, the math still is the same. So, with my 110" diagonal, I have a 35.625 square foot screen, so whatever my lumen measurement is, I multiply it by 35.625 to get the total lumen output of the projector. That certainly seems easier than fully calculating size every time, but if they have a room with limited placement flexibility, which is very likely in a good theater space, then they probably don't have the option of moving the projector 20+ feet out. So, they just changed the size and did measurements that way. It may be a lot easier to do things that way.
In reality, with the rise in the measured lumens that the meter would show with a smaller screen size, if they had done the math wrong, they would show much higher brightness. Instead, their math indicates very similar light output falloff that Projector Central also claimed in their review.
Can we agree that the math on this looks accurate and both sites are performing valid tests of light falloff related to zoom of the lens?
I fully believe that the projector will look excellent at that distance. I like playing with the math, so hopefully you didn't read anything that was going after you in my post. Just working the numbers. I'm sure I read both reviews at some point, but it would have been a solid year and I'm sure the numbers didn't register with me.
25 lumens is plenty of light on any screen for non-3D viewing. It may be a bit tough for 3D viewing. They can certainly turn some lights on as well as long as they aren't falling right on the screen or too close to the screen. Projectors certainly do a very good job with their increased brightness in recent years, and Epson seems to be really leading the pack with their LCD models and superb color brightness.
post #13 of 13 Old 08-16-2019, 02:59 PM
Liked: 2874
Projector lamps are commonly said to lose up to 25% of initial lumens over the first 500 hours of use with lumen loss gradually slowing to end of lamp life, which is generally considered to be 50% of original lumens. So if you want to get a satisfactorily bright image over the lifespan of the lamp you'd need to have a setup that would remain acceptably bright at 50% of original lumens. If not then the lamp would need to be changed prior to normal end of life to restore acceptable image brightness.
