Optoma UHD370x 4k/60hz problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-16-2019, 06:41 AM - Thread Starter
Liked: 0
Hello
The projector is amazing,but when i connect it to my PC,over a 10m long MONSTER BLACK PLATINUM Hdmi cable,i just can't get a 3840x2160/60hz+HDR.basically i cant get 60hz on any resolution.my graphics card is a Asus Geforce RTX 2070.Operation system is Windows 10 1809. the cable was so expensive,the specs is more than good enough in my opinion.Can you recommend something to achive a 4k/60hz HDR?the hdmi edid option was set to 2.0(so weird that i have two Hard drive with two windows 10(1809)and one of them cant even let me change the hdmi version to 2.0,the other is allow it but when i change it for 60hz at 3840x2160,the projector lost the signal,and also i can check the option and enable the HDR on this win 10 as well.Thank you for all the suggestions&sorry for my poor english
Peter44 is offline
post #2 of 5 Old 08-16-2019, 06:48 AM
rekbones's Avatar
Quoted: 1016 Post(s)
Liked: 527
Just because a cable is expensive doesn't mean it is any good. At that length a active cable is a must or preferably OPTICAL.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 5 Old 08-16-2019, 07:04 AM - Thread Starter
Liked: 0
why do they advert it as a 4k/60hz hdr cable than?could you recommend a cablo for that lengt?thank you
Peter44 is offline
post #4 of 5 Old 08-16-2019, 09:48 AM
Quoted: 737 Post(s)
Liked: 357
There are various threads about cables on the forum. However, I would suggest that you explore ways to get your PC closer to the projector, maybe by using a remote keyboard.
DunMunro is offline
post #5 of 5 Old 08-20-2019, 05:25 AM - Thread Starter
Liked: 0
Unfortunately there is no way to get my pc closer to the PJ,i ordered a signal booster,hopefully will work!the issue is that if i watch a movie on media player classic than cause the 30 or 24hz,its lagging,really frustrating
Peter44 is offline
