Best HD Projector under $1K that will take 4K? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-24-2019, 01:38 PM - Thread Starter
JackB's Avatar
Quoted: 1413 Post(s)
Liked: 345
What is the best 1080P projector under $1K that will take a 4K signal and down-rez it? It would be nice if it was LED or laser. No Chinese imports for now as they seem to have too many HDCP and language issues.
Jack
JackB is offline
post #2 of 10 Old 08-24-2019, 02:01 PM
scoobdude's Avatar
Quoted: 66 Post(s)
Liked: 32
Only one I know of is the hd27hdr
Sent from my Pixel 3 using Tapatalk
scoobdude is online now
post #3 of 10 Old 08-24-2019, 02:07 PM
3DBob's Avatar
Quoted: 1074 Post(s)
Liked: 572
I don't know if this is the best because it depends on what you are looking for. If you want a very bright 1080p projector that accepts 4k HDR, this might be it: Optoma HD27HDR. In fact, this might be your only option. Check out the review here: https://www.projectorcentral.com/Opt...HDR-Review.htm.
I have not seen it, but appears to be very good based on the review.
3DBob is offline
post #4 of 10 Old 08-24-2019, 06:59 PM - Thread Starter
JackB's Avatar
Liked: 345
it's around 500+ dollars on Amazon so It looks like a good candidate.
Jack
JackB is offline
post #5 of 10 Old 08-25-2019, 12:49 AM
Quoted: 737 Post(s)
Liked: 357
You can get a refurbed Viewsonic PX747-4K within your budget. See the deals found subforum. you might see some BenQ TK800 refurbs there too.
DunMunro is offline
post #6 of 10 Old 08-25-2019, 01:04 AM
DaGamePimp's Avatar
Quoted: 580 Post(s)
Liked: 605
I owned the HD27HDR for a couple weeks and it was just very 'meh' regarding the image, I returned it for that reason (it just did not impress me beyond it's ability to accept 4K HDR and 1080p 120hz for gaming).
Feature wise it cannot be beat for the money but the image is not as good as some other entry level 1080p projectors (of course none of those accept and process 4K).
Regarding gaming it's brilliant, playing at 1080p 120Hz with ~8ms input lag is fantastic.
- Jason
HT = BenQ HT3550 - Sony HW45ES @133" / Marantz SR6013 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" x2 / CV 15" / Panasonic UB820 / Toshiba HD-A3
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI - 9900K PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is online now
post #7 of 10 Old 08-25-2019, 03:19 AM
Liked: 2
In Europe you can get the Acer G550 Nitro - its basically the HD27HDR but with an RGBRGB Color Wheel.
THXfreak is offline
post #8 of 10 Old 08-25-2019, 09:46 AM - Thread Starter
JackB's Avatar
Liked: 345
Acer sells pc's here in the US. I wonder if they sell projectors.
Edit: They do. Just not the G550.
Jack
JackB is offline
post #9 of 10 Old 08-25-2019, 10:59 AM - Thread Starter
JackB's Avatar
Liked: 345
Read a review on Projector Central on the HD27HDR.A major problem called out is that it converts a 1080P input signal to UHD and then converts it back to 1080P for display. According to PC this decreases the image quality. I wonder why they would do that instead of having two digital paths inside the electronics.
Jack
JackB is offline
post #10 of 10 Old 08-25-2019, 11:29 AM
Quoted: 737 Post(s)
Liked: 357
That's not quite correct. The HD27HDR signals that it accepts 4K input, so the source (if capable) will upscale 1080p output to 4K to match the input, and then the HD27HDR downscales it to output 1080p. The solution, as per PC, is to tell the source not to upscale non-4k content.
DunMunro is offline
