Surprisingly good LED PJ for $200 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 35 Old 09-10-2019, 03:39 PM - Thread Starter
Quoted: 42 Post(s)
Here are some screen shots from the CiBest from last night. Sorry, was too lazy to switch to actual movies. These are all from cable TV. FWIW.
Name:	2019-09-09 21.58.42.jpg
ID:	2613788   Click image for larger version
Name:	2019-09-09 21.58.46.jpg
ID:	2613790   Click image for larger version
Name:	2019-09-09 21.56.16.jpg
ID:	2613792   Click image for larger version
Name:	2019-09-09 22.08.41.jpg
ID:	2613794   Click image for larger version
Name:	2019-09-09 22.14.11.jpg
Name:	2019-09-09 22.30.39.jpg
ID:	2613798   Click image for larger version
Name:	2019-09-09 21.56.34.jpg
HTCrazy2 is offline
post #32 of 35 Old 09-10-2019, 04:32 PM
g4s
g4s's Avatar
Quoted: 21 Post(s)
Liked: 25
Looks great. Does it have an off timer? That would make it a perfect bedroom setup for us if it did.
I looked up the manual, turns out there is an off timer.
g4s is offline
post #33 of 35 Old 09-10-2019, 06:21 PM - Thread Starter
Quoted: 42 Post(s)
Perfect except loud for a bedroom. You might check other units with similar specs but lower fan noise and rave reviews on Amazon. Also don’t forget the video processing is weak. I’m running mine through an Oppo DVD player with Darbee processing. Does noticeably improve the picture. Other upscaling players/receivers etc can do the same.
HTCrazy2 is offline
post #34 of 35 Old 09-10-2019, 06:43 PM
g4s
g4s's Avatar
Quoted: 21 Post(s)
Liked: 25
Yeah, I've got a stand alone Darbee box. I'm sure that kicks it up a notch.
g4s is offline
post #35 of 35 Old 09-11-2019, 08:21 AM - Thread Starter
Quoted: 42 Post(s)
Definitely. There's also a similar projector, the Vankyo V600 that's supposed to have multiple quieter fans and also well reviewed with similar specs. I've gotten used to the fan noise, but quieter's always better.
g4s likes this.
HTCrazy2 is offline
5000 lumens , cheap projector , led
