HT Room, Paint First OR Setup First?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-11-2019, 08:37 AM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
I will be setting up my first HT room ever and I'm super pumped. I will be painting the room with the ROSCO black velvet paint with a base primer of regular black matte paint just like someone on this forum did(can't remember the name). The only thing I am not sure what to do is if I should setup the room with the projector and screen FIRST(nothing else), then take down the screen and projector to paint OR should i just paint the whole room and then setup the project, screen, speakers, etc.......?
mon2479 is offline
post #2 of 7 Old 09-11-2019, 08:42 AM
skylarlove1999's Avatar
Quoted: 628 Post(s)
Liked: 441
This is the blackest least reflective paint Rosco makes. Keep in mind the paint scuffs easily. I would not seeing any benefit of putting any equipment in the room prior to painting . That would only seem like a negative to me.
https://www.filmtools.com/rosco-tv-paint-black.html
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #3 of 7 Old 09-11-2019, 11:05 AM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
What about the Rosco supersaturated velour black? Would this one be darker?
mon2479 is offline
post #4 of 7 Old 09-11-2019, 12:18 PM
Quoted: 628 Post(s)
Liked: 441
Yes. It has been tested. Slightly better.
https://www.avsforum.com/forum/24-di...218000?page=39
Post 390 from Nigel owner of Arrow AV
post #5 of 7 Old 09-11-2019, 03:37 PM
Quoted: 628 Post(s)
Liked: 441
https://r.tapatalk.com/shareLink/top...ink_source=app
Another one that people like.
post #6 of 7 Old 09-11-2019, 03:47 PM
Lucky Strike's Avatar
Quoted: 136 Post(s)
Liked: 27
I didn't go all the way black with special AV paint (mine's just matte Sherwin Williams paint, can't remember the name but their higher end line) but I chose a really dark red on the walls and dark grey on ceiling. I painted first and then made liberal use of blue non marking painters tape to aid with marking locations/distances with all the setup. I went with a false wall mounted acoustically transparent screen which resulted in some scuffing due to being friction fit but that was fixed with a small amount of touch up painting.
Lucky Strike is offline
post #7 of 7 Old 09-11-2019, 06:37 PM - Thread Starter
Quoted: 51 Post(s)
Liked: 3
Thanks for all your help
mon2479 is offline
