Epson HC 3200 and 3800 revealed - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 281Likes
post #811 of 824 Old 06-30-2020, 09:42 AM
Quoted: 1973 Post(s)
Liked: 601
Originally Posted by srees304 View Post
The price is crazy low...that contrast, though...12000:1 sounds pretty painful.
Which one? The 727 has ~500:1 native and ~1200:1 dynamic and 747 has ~370:1 native and ~750:1 dynamic.
The HC3800 has ~1700-2000:1 native and ~35 000:1 dynamic.
The HC3200 has ~450:1 native and not sure about dynamic. It does have an active iris which helps.
Something that can cause irregular focus is the projector not being perpendicular to the screen. If screens are just mounted to walls it may not straight, since walls are often not straight.
noob00224 is online now
post #812 of 824 Old 06-30-2020, 10:38 AM
Liked: 2
HC3200 has 40 000:1 dynamic, and is OK but not impressive by any means. I haven't seen the native contrast ratios, I guess I'll have to dig more for that info.
The projector is perpendicular to the screen. The difference in focus requires moving the particular corner multiple feet closer to the projector to rectify (tested with a sheet of paper walked closer, and I can guarantee you my wall/screen are not _that_ uneven.
Flipping the projector (ceiling mount vs tabletop) results in the blurry section moving to the opposite quadrant, which is also proof it isn't the wall.
srees304 is offline
post #813 of 824 Old 06-30-2020, 11:04 AM
Quoted: 30 Post(s)
I'm no pro, but it sure sounds like a defective or damaged unit to me. There's no way having that much area be so out of focus (multiple feet) be acceptable for a properly functioning device, assuming no environmental or installation flaws.
Sent from my ONEPLUS A6003 using Tapatalk
Trapani likes this.
GeoGemini is offline
post #814 of 824 Old 06-30-2020, 11:18 AM
Trapani's Avatar
Quoted: 92 Post(s)
Liked: 53
Ouchers on that 3200s native contrast
450 vs 1700-2000 is a big difference in true native contrast... where is the source for that data?
The irises are probably the same
Also sounds like each respective tier has lesser and lesser defects
IE 3200<3800<4010<5040<5050
If your focus is that far off though like it takes multiple feet, I'd return it
My focus on my 3800 isn't perfect but it was equal to the DLPs in its class
When I say not perfect, I can't get the focus razor sharp, not like it is physically out of focus
In no area can I not resolve individual pixels on the screen in other words
The best test is to bring a friend over and have them look at it.
If they can see wrong stuff, yeah your machine is broke.
If not, you may have projectoritis; a mild form of OCD contracted from owning a projector. This is remedied by spending more money.
elee532 and GeoGemini like this.
My Rig :)
Samsung UN65HU8550 -TS01
Onkyo TXNR809
Adcom GFA-555
Martin Logan Aeon i - DefTech CS8060hd - Klipsch Reference RW-12D - B&W SCM8
Logitech Harmony Ultimate (Making sure everybody plays nicely)
Trapani is offline
post #815 of 824 Old 06-30-2020, 11:35 AM
XK_HT's Avatar
Liked: 0
LOL Projectoritis - most people on this form have mild-severe symptoms of that.
Are the 3800 black levels significantly better than the DLP units? what about Mixed scenes (Mid-High APL)?
XK_HT is offline
post #816 of 824 Old 06-30-2020, 11:53 AM
Liked: 601
I'm certain the HC3200 does not have 40 000:1 dynamic. I assume that you're taking that figure from Epson's specification. Which are not true (contrast).
The HC3800's contrast claimed by Epson is 100 000:1, which is obviously not true.
@Trapani
https://www.avsforum.com/forum/68-di...l#post59021304
https://hometheaterhifi.com/reviews/...jector-review/
Trapani likes this.
post #817 of 824 Old 06-30-2020, 11:56 AM
Liked: 601
Those scenes will have an advantage with DLP, at least on paper. IRL the difference is not that big, with the room hampering whatever advantage DLP might have. Even in a treated room the difference is not significant IMO, and noticeable. However poor black level in low ADL scenes will be noticeable.
post #818 of 824 Old 07-01-2020, 11:48 AM
mostau's Avatar
Hi,
I've had issues with uniform focus as well and played around with placement for a while.
This is a snippet from my 3800 review on Amazon (You can go there for my full review, I have the picture of my Panel Alignment pattern there, sorry I can't find the original at the moment to post here).
"Update: As some have commented on inability to focus across the entire screen. I had to work on the projector position a bit as I had a similar experience, but after I pointed the projector "slightly up" (still no keystoning), and used lens shift to bring the image down I was able to get a completely uniform focus at all sections of the screen. I added a picture of the Panel Alignment pattern to show it is sharp on all locations of the screen (the missing lines are due to my black velvet screen masking). Maybe I got lucky with mine but I've had no issues with focus or blurring after adjusting."
mostau is offline
post #819 of 824 Old 07-01-2020, 01:35 PM
Liked: 2
Originally Posted by mostau View Post
Hi,
Is that ceiling mount or tabletop? I think you got lucky. I've been through three of them, all easily reproducible. A major Epson benefit is the flexible placement, and if you have to stand just so with it to get it to work, that benefit is nullified.
Projectoritis definitely...funny...I'm certainly looking at the spending more solution.
srees304 is offline
post #820 of 824 Old 07-01-2020, 03:14 PM
Trapani's Avatar
Quoted: 92 Post(s)
Liked: 53
I've tried ceiling, low table, and I'm currently doing high table floating-shelf style mount
The third is best for me at this point because it's less precarious and prone to vibration than the hanging (underneath my furnace unfortunately) so I have mine on a floating shelf.
Image uniformity was best with the low table style mount... IE just over your couch or on a table or shelf
When I hung mine, I used an extended ceiling mount which also did bring the PJ closer to center, just more upside down.
Mostau might be right about pointing the projector slightly up too, my setup is actually slightly inclined, though I'm using a lot more lens shift to bring down the high shelf upright style mounting.
My Rig :)
Onkyo TXNR809
Adcom GFA-555
Trapani is offline
post #821 of 824 Old 07-01-2020, 03:28 PM
Trapani's Avatar
Quoted: 92 Post(s)
Liked: 53
Also, btw for those who might have been curious the list of official accessories is at this link
https://files.support.epson.com/doci...3200_3800.html
That has the part #s for filters, lamps, the official mount that's supposed to go on this, etc.
There's even some wifi chip but it looks limited
My Rig :)
Onkyo TXNR809
Adcom GFA-555
Trapani is offline
post #822 of 824 Old 07-01-2020, 08:24 PM
Quoted: 452 Post(s)
Liked: 215
I've got a 3800 and focus uniformity is not much of an issue, I get pretty good clarity on a 150" screen.
Ceiling mounted about a 1.4x zoom.
GeoGemini likes this.
longhornsk57 is offline
post #823 of 824 Old 07-02-2020, 06:41 AM
kensingtonwick's Avatar
Quoted: 527 Post(s)
Liked: 110
The 3800 has been nothing short of amazing for me. I will never go back to regular TV!
kensingtonwick is offline
post #824 of 824 Old 07-02-2020, 09:38 AM
mostau's Avatar
I am ceiling mounted, however I have a vaulted ceiling and I've lowered the projector 16" so it is a tad below the top of the screen (maybe 1 foot down a 6 foot tall screen) so I have some headroom to point the projector up. You view can my setup here (scroll down past the video zoom screen shots for the room setup, or up a tad to see the projector mount)...
Unfortunately I deleted my original picture of the alignment pattern after I uploaded it to Amazon. I grabbed it back from there but it is lower resolution than the original. I'll try to take another this weekend (after the sun is down).
Update: I took a new full resolution picture of my panel alignment pattern. Have a look.
mostau is offline
