LG HU70LA 4K UHD Laser Smart Home Theater CineBeam Projector - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #301 of 341 Old 01-13-2020, 04:08 AM
Quoted: 138 Post(s)
Liked: 77
ALR first choice, on it mate.
Will keep you posted when I receive samples and will test them, sharing results in here.
Cheers
Originally Posted by noob00224 View Post
Paint number one.
ALR number two.
Second video:
https://www.youtube.com/results?sear...ontrast+screen
noob00224 likes this.
Gae80uk is offline
post #302 of 341 Old 01-14-2020, 08:43 AM
chhanthony's Avatar
Quoted: 234 Post(s)
Liked: 127
Hi all,
Found out HU70LA support HLG HDR accidentally.
Anthony Chan
AV Blog: http://www.avnewbie.com
Panasonic DP-UB9000EBK, Shield TV Pro 2019, Zidoo Z9S, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, LG HU70LA, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #303 of 341 Old 01-14-2020, 04:03 PM
Quoted: 138 Post(s)
Liked: 77
@noob00224
what do you think about this ALR 1.5 gain canvas?
https://cine-screen.fr/produit/toile-technique-blanche-de-projection-pour-ecran-videoprojecteur-alr-1-5-ambient-light-rejecting-rejet-de-lumiere-ambiante-sur-mesure/
Maybe mounted on a normal 120" frame could do
Gae80uk is offline
post #304 of 341 Old 01-14-2020, 06:47 PM
Quoted: 981 Post(s)
Liked: 282
Originally Posted by Gae80uk View Post
@noob00224
https://cine-screen.fr/produit/toile...te-sur-mesure/
Haven't heard of the fabric.
The fabric claims 1.2 gain, 100 degrees viewing angle, and no hotspot. Any ALR can have a hotspot. As I mentioned in a previous post, it's less to do with the quality of the fabric and even the gain and other characteristics, and more to do with the technology, of how angular ALR works.
The optical coating is used to increase the reflectivity and hence the brightness of the image, so it doesn't get too dim. The coating also makes the reflective characteristics of the gray screen more mirror-like in it's directionality, so that the projector light is reflected more towards the viewer, less on to the surrounding walls. (If you are facing a white wall and someone shines a fashlight from above your head on an angle at the wall, the white wall will diffuse the light and light will scatter everywhere, lighting up the rest of the room, like a white screen does. Replace the wall with a mirror - now there is no diffusion of the image of the flashlight - what you see reflected is the focused beam of light right into your eyes). In this way, gray screens with optical gain can have a satisfyingly bright image while also helping maintain good contrast if you have some ambient light, or reflective room surfaces.
BUT...there is a trade off. When you add optical coating to make the reflection more mirror-like, you are of necessity focusing the light to a smaller central area of the screen. This results in uneven screen illumination known as "hot-spotting," where - especially apparent if you have a blank white image - you can see the projector beam being focused more in the center of the screen, and the screen dims significantly as you move off center to the edges of the screen. So it's like a mild spot-light effect in terms of brightness.
noob00224 is online now
post #305 of 341 Old 01-14-2020, 07:33 PM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
It looks like this material performs well at least compared to their previous material, I don't have samples to compare to seymour/si/xy/etc materials. The case and tensioning system looks exactly the same as XYs EC2. If the new design has a similar shade of grey as the .8(it looks lighter in the pictures), has a higher gain while retaining viewing angles and reduced artifacts(in the pictures it looks similar to the bc.8, and the cine-screen 1.3 has more sparkle than the bc.8) I'd definitely consider it, it's just that those attributes tend to contradict each other. But with advanced engineering anythings possible. Look at the parallax, matte, sparkle free, lower minimum throw, and a cost to go with the performance. But still could provide a good option if you want to sacrifice some black level for light output.
https://www.passionhomecinema.fr/blo...is-de-gregory/
bdht is online now
post #306 of 341 Old 01-15-2020, 12:03 AM
Quoted: 981 Post(s)
Liked: 282
Both projectors used in the test, the Benq W1720 (upgraded HT2250) and Viewsonic PX725HD have a throw of 1.50 - 1.65.
It doesn't say in the review what throw range was used.
So it could have no hotspot? Gae80uk 's throw is 1.47x.
post #307 of 341 Old 01-15-2020, 01:37 PM
Quoted: 138 Post(s)
Liked: 77
@bdht thanks for the tips, will check them out.
@noob00224 is my official screen guru
Gae80uk is offline
post #308 of 341 Old 01-16-2020, 12:46 AM
Quoted: 138 Post(s)
Liked: 77
@noob00224
first impressions with vividstorm sample ALR 0.8 grey screen
https://nsa40.casimages.com/img/2020/01/16/200116084557569744.jpg
https://nsa40.casimages.com/img/2020/01/16/200116084601253168.jpg
https://nsa40.casimages.com/img/2020/01/16/200116084934766454.jpg
overall feeling is that there is more contrast and black is deeper, much more black than grey...but looks like overall colours and brightness might take a big hit with a full screen like this...:/
Gae80uk is offline
post #309 of 341 Old 01-16-2020, 12:55 AM
Quoted: 981 Post(s)
Liked: 282
@noob00224
https://nsa40.casimages.com/img/2020...4557569744.jpg
https://nsa40.casimages.com/img/2020...4601253168.jpg
https://nsa40.casimages.com/img/2020...4934766454.jpg
Sounds like a higher gain is required, but with higher gain comes the increased hotspot.
Have you tried putting the sample in the center of the screen?
Try this:
Since hotspotting is relative to your eyes and the lens, you can have a sample at your screen location, look at it straight on and move off the side and see the illuminance of the material change.
Once you have an idea of the various materials and their requirements, you can just hit a sample with a flashlight and gauge what the recommended throw ratio would be as its entirely how matte the material is.
You might be slowly coming to the conclusion that paint is the best way here.
post #310 of 341 Old 01-16-2020, 01:21 AM
Quoted: 138 Post(s)
Liked: 77
@noob00224
During the weekend will try with the center + other 5/6 samples (grey 0.8 to white 1.0+ gain) from XY.
They are quite small to get a proper idea, hopefully it will help to decide gains, colours and materials
Thanks again!
chhanthony likes this.
Gae80uk is offline
post #311 of 341 Old 01-16-2020, 01:37 AM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
What, uhh... is that on high lamp? The hu70 puts out about 300-800 lumens, calibrated minimum energy saving around 550-600. What size screen is that and current gain?
https://www.projectorcentral.com/LG-...tor-Review.htm
In direct comparisons like that the lower gain screen needs more light output to hit the same illuminance as your current screen.
bdht is online now
post #312 of 341 Old 01-16-2020, 01:40 AM
Quoted: 138 Post(s)
Liked: 77
@bdht
It's on minimum energy saving so I guess High Lamp (not sure)? It's a 120" picture at roughly 4 meters far from the wall.
Any suggests?
Gae80uk is offline
post #313 of 341 Old 01-16-2020, 01:45 AM
Quoted: 138 Post(s)
Liked: 77
@bdht
It's a 0.8 gain grey ALR sample vs white wall on the back
Gae80uk is offline
post #314 of 341 Old 01-16-2020, 01:45 AM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
@bdht
Any suggests?
Ya thats high lamp. What preset? 600 lumens on the .8 sample is only 11fl, too dark, you wanna shoot for 16-20fl for most sdr content.
bdht is online now
post #315 of 341 Old 01-16-2020, 01:47 AM
Quoted: 138 Post(s)
Liked: 77
@bdht
the image is set and calibrated on Dark room (Anthony settings)...might need a 1.2+ gain screen right?
Gae80uk is offline
post #316 of 341 Old 01-16-2020, 09:57 AM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
@bdht
Ya that or drop down to 100"
bdht is online now
post #317 of 341 Old 01-16-2020, 11:43 AM
Quoted: 138 Post(s)
Liked: 77
@bdht thanks! Better grey or white one?
Gae80uk is offline
post #318 of 341 Old 01-16-2020, 01:14 PM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
Hmm, that projectors contrast ratio is 500:1? Its never going to have any kind of decent black. If you dont want to deal with the impact on uniformity from +gain grey alr screens then you can probably just use a white material.
See how contrast at 5% is fairly similar on both projectors, thats the highest a white room is capable of.
https://i0.wp.com/projectiondream.co...size=798%2C233
https://i0.wp.com/projectiondream.co...ble.png?w=1252
With a native contrast of 500:1 a treated room wont make any difference and neither will a darker screen, as the projector doesnt have the output to shift its contrast down. I.e. say a projector can do 40fl white and 0.08fl black. You could improve that projectors black level by reducing output or shifting contrast with a grey screen down to 20fl white and 0.04fl black. Using alr screens offsets the room though where reducing output from the projrctor doesnt. But if your stock is 20fl theres nowhere to go. So best to shoot instead for a very uniform and artifact free image. I cant suggest a studiotek100 lol or even a seymourav glacial white. Maybe elunevisions fixed frame reference 100, its supposed to be very matte and texture/artifact free. My general experience with the base white materials like elites cinewhite, silver tickets white, etc, is they still hotspot and have a gain artifact sheen at 1 4-1.5 throw ratios, better than drywall though. I dont have any experience with painting but perhaps that can provide a very matte surface.
avsmja and chhanthony like this.
bdht is online now
post #319 of 341 Old 01-16-2020, 03:59 PM
Quoted: 981 Post(s)
Liked: 282
I did mention painting which seems to provide the best option, at least from what I've read. The paint mix can be customized so you can get at the edge of having hotspot/artifacts.
The description seems very encouraging:
https://www.avsforum.com/forum/68-di...l#post58790176
post #320 of 341 Old 01-16-2020, 05:13 PM
JackB's Avatar
Quoted: 1570 Post(s)
Liked: 379
I have tried the painting. I found it very difficult to get it right and eventually gave up.
Jack
JackB is offline
post #321 of 341 Old 01-16-2020, 06:11 PM
Quoted: 981 Post(s)
Liked: 282
What mix did you try?
Was it with MM's assistance?
post #322 of 341 Old 01-16-2020, 06:39 PM
JackB's Avatar
Liked: 379
I tried the mix that MM suggested at the time. Maybe 3-4 years ago. It had about 5 elements. I even used a pro painter. The biggest problem was getting an even coat across the whole screen. The issue may have been that spraying is the desired method. That wasn’t possible at the time and may have solved the problem. I did like the parts that didn’t have problems from rolling instead of spraying. My impression though was that spraying would be a challenge too. But that’s based on my spraying experience, which is extremely amateurish.
Jack
JackB is offline
post #323 of 341 Old 01-16-2020, 06:49 PM
Quoted: 981 Post(s)
Liked: 282
Doesn't look that hard.
https://www.youtube.com/channel/UCvS...ubscribe_title
https://www.youtube.com/watch?v=aQ03-EyMhfo
https://www.youtube.com/watch?v=oLDKI3F-jVI
https://youtu.be/DNhd2o5bmN4
<div>">">
Now then....if a "large" 65 + yr old guy can shuffle along a 2 x 12" Plank 4' off the floor at a steady speed and hold a spray gun level and at the same approximate distance from a Wall-sized Screen surface............................
@Trogloraptor , surely with just a few practice "dry Runs" you can get'ter dun.
Hint.....try to elevate your Screen off the Floor at least 12" so you can overlap the Bottom edge with a Vertical spray pattern and don't have to do a vertical cut-in.
post #324 of 341 Old 01-16-2020, 06:53 PM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
I suck at painting im really apprehensive about it :[ Im going to get a white hardboard to practice before i paint the elunevision screen though. You have to rapidly cropdust and overlay perfectly and put several coats letting it dry for a day in between, in a non humid enviroment thats well ventilated and covered in plastic as to not get paint everywhere
bdht is online now
post #325 of 341 Old 01-16-2020, 06:58 PM
Quoted: 981 Post(s)
Liked: 282
Better than spending 4000 dollars on a screen .
post #326 of 341 Old 01-16-2020, 07:35 PM
chhanthony's Avatar
Quoted: 234 Post(s)
Liked: 127
Hi
As per my measurement, the Peak brightness of HU70 on 126" 1.0 gain white screen was only around 45 nits which is 13 ftL.
Anthony Chan
post #327 of 341 Old 01-16-2020, 08:01 PM
chhanthony's Avatar
Quoted: 234 Post(s)
Liked: 127
@Gae80uk
Sorry for can't giving any advice on the screen as I don't have many experience on those ALR screen, but I believe it is a give and take game, there is no perfect solution.
I was looking for a screen can optimize the picture contrast in last few months, but after a few researches I gave up this idea, as I didn't want improve the contrast by trading off the brightness and color and having the sparking, hot spot on the screen.
I think the biggest challenge is we are using short throw projector.
Anthony Chan
post #328 of 341 Old 01-16-2020, 08:22 PM
bdht's Avatar
Quoted: 369 Post(s)
Liked: 146
Does that look dim to you or comfortably bright and detailed?
Can't buy a blacker screen anyway so paintings the only option. But idk... the screens 50% of the display and impacts image quality in several areas. If you're not spending much on the projector I wouldnt expect you to be interested in a 4k screen, but if you're spending 3k+, it should be an attractive option. I would be suprised if any painted material performs as well as an ST100, alot of engineering went into that material and advanced manufacturing is needed to make it. They're generally 3k for typical screen sizes and there's a used market as well. The parallax at 4k provides a similarly matte and artifact free surface with the added bonus of above/below light rejection and shifting contrast for improved black levels, well worth the price. The screens invisible with these materials, I think alot of people dont realize how grainy and flat the cheaper materials make the image look, a pixel should look solid and uniform, not like a little pile of sand.
I can only imagine what the mico40 would look like on a full sized st100/parallax. It already has incredible dimensionality and removing any hotspotting/gain artifacting would make it look like actual 3D. I'm pretty sure rgb dlp + st100/parallax = perfection(aside from 0-1% apl black levels...). Upgrade path for me is still a parallax.8
bdht is online now
post #329 of 341 Old 01-16-2020, 08:31 PM
chhanthony's Avatar
Quoted: 234 Post(s)
Liked: 127
In most of time, it is acceptable for me.
With some movies with lower APL, yes...I will want more brightness.
Anthony Chan
post #330 of 341 Old 01-16-2020, 08:48 PM
chhanthony's Avatar
Quoted: 234 Post(s)
Liked: 127
Sorry for wrong information....deleted.
Anthony Chan
