Optoma GT 1080 Darbee projector is not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-15-2019, 05:49 PM - Thread Starter
Carlos Martinez's Avatar
Quoted: 30 Post(s)
Today it happened what I never thought might happen: my projector refused to turn on. I bought it two years ago.
Even worst: the red led turned off and it's not responding to anything I did.
AC cable is fine, as I checked power coming through it with a multimeter. I also tried another AC cable and another AC wall socket. Nothing.
My suspicions are the worst possible: that the power supply stopped working.
I can't find any fuse socket to see if there's a fuse that might have blown. Does anyone know if there may be a fuse anywhere and how I get to it?
The problem is serious, because I do not live in the USA. I live in Brazil, so I don't have access to projector repair facility of any kind. Even less for Optoma.
It will be unlikely that I find someone that would look into this or repair it.
So the first question is: is there a way I can get a Service Manual for this projector? Where?
Second, is there a place where I can get a replacement board, if the problem is in the power supply and needs to be replaced?
Carlos Martinez is offline
post #2 of 4 Old 09-15-2019, 07:15 PM
rekbones's Avatar
Quoted: 1057 Post(s)
Liked: 547
If the fuse blew in the power supply it is most likely soldiered in and blew because a component failed and just replacing it won't fix anything. I can't help with a Manuel but anyone qualified in electronic repair should be able to repair it. Check eBay for a PS as one used or new maybe available. Of course if a component shorted out on the main board it could also blow the fuse.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 4 Old 09-16-2019, 03:30 AM - Thread Starter
Quoted: 30 Post(s)
It's most likely you are right about an eventual blown fuse being the result of a failure somewhere else.
Unfortunately things are not so easy in my country to find someone qualified in electronic repair that will want to solve my problem.
I have already contacted Optoma's Parts department to see if I can get a manual.
post #4 of 4 Old 09-16-2019, 10:19 AM
AV_Integrated's Avatar
Quoted: 1619 Post(s)
Liked: 1185
Don't count on Optoma to provide an end user with a ton of support beyond telling you where service shops are.
Check FixItFrank on YouTube. He does a complete breakdown of a HD20 from Optoma with a power supply replacement. Maybe not at all the same, but will get you a good idea of the level of effort which may be required here.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
