Possible to push a UST PJ somewhat past the max image size? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-18-2019, 02:42 PM - Thread Starter
sec1has's Avatar
Generally, it appears most UST projectors are rated for a max image size of 150 inches. For anyone who has one, would pushing the projector back a bit further from the wall in order to get a 160 inch image cause too much of a reduction in brightness or image quality? Would the image still be in focus?
sec1has is offline
post #2 of 3 Old 09-18-2019, 07:03 PM
AV_Integrated's Avatar
Quoted: 1612 Post(s)
Liked: 1184
Focus is the main issue. If you've ever worked with closeup photography you would know that depth of field is very difficult to maintain, and this is the limiting factor with size.
Brightness is irrelevant as projectors with under 1,000 lumens claim they can deliver a 300" image size. In fact, they can typically go even larger without losing focus, but at about 100" or so, you lose the brightness.
Stay within manufacturer spec with UST projectors.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 3 Old 09-18-2019, 07:06 PM
bix26's Avatar
Quoted: 726 Post(s)
Liked: 388
Most UST’s are only rated up to 100”-120”. The Dell and Xiaomi UST’s are the only ones I know of that can go up to 150”s. Also, the ceiling height can become an issue as well. As you move the projector out from the wall the bottom of image becomes higher and higher above the projector. That said, usually the ratings are conservative and you should be able to eek out a little larger screen size without having distortion or focus issues. This can’t be guaranteed of course, take that for what is. So please don’t blame me if it doesn’t work.
bix26 is offline
