Epson 5040ub no signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-22-2019, 01:03 PM - Thread Starter
Liked: 0
Hi everyone,
I’m now to the forum so I hope I am putting this in the correct place. My projector is less than 2 years old and it has been great. I had it ceiling mounted for about a year and then we moved. It was packed in the original box and sat for about 8 months. I just hooked it up again and there is no signal on the HDMI ports. I have tested the source and cable on my regular tv and they work fine. I have followed the trouble shooting steps the Epson recommended (very simple ones, they were all things I tried before I even started searching.). None of that worked so I upgraded the firmware and reset to factory defaults... still no luck. Any advice would be appreciated.
Russ
[email protected] is offline
post #2 of 2 Old 09-22-2019, 02:40 PM
skylarlove1999's Avatar
Quoted: 846 Post(s)
Liked: 596
Originally Posted by [email protected] View Post
Hi everyone,
Russ
If the projector is turned off and you press menu can you see the menu?
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
