XGIMI (极米) A2 Pro XJ20T 4K Laser UST - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-08-2019, 11:31 AM - Thread Starter
Quoted: 200 Post(s)
Liked: 48
TR: 0.2:1
Brightness: 3000 ansi lumens
HLG Support
100% DCI-P3
https://shop.xgimi.com/goods/1194000567.html
ID:	2625358   Click image for larger version
qoopy is online now
post #2 of 3 Old 10-08-2019, 02:19 PM
bix26's Avatar
Quoted: 734 Post(s)
Liked: 391
TR: 0.2:1
HLG Support
100% DCI-P3
Specs are a lot like the Lune 4k Pro. Shorter throw ratio is the only difference I found. The Lumens are actually specified as 2,300
It’s crazy how Xiaomi and Xgimi are able to put out a new model every 6 months. I wish they would import these UST models instead of only their compact led models.
bix26 is offline
post #3 of 3 Old 10-09-2019, 09:25 PM - Thread Starter
Quoted: 200 Post(s)
Liked: 48
Looks like you're looking at the wrong page.
The A2 has an extra yellow segment in the colour wheel to boost brightness while the Pro's is pure RGB using a more powerful light source. Not clear where it is made, but does look like a JMGO.
The jd pre-order page has been taken down. Perhaps you'd like to try later.
qoopy is online now
