Bands in sony vpl-hw50es projector-any pointers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-01-2019, 09:05 AM - Thread Starter
drgnanam's Avatar
Liked: 1
Hi forum members,
iam from india, own SONY VPL-HW50ES projector since 2013, with original lamp which clocked around 3000 hrs, there has been warning message to change bulb for past 6 months, since was planning to upgrade to 4K next year, i just postponed it and frankly it was good till last week, suddenly there alternated vertical bands at regular intervals , changed every thing in chain and checked pretty convinced the projector is the culprit(new pc,hdmi cabel)searched here and online not much there about this particular issue, uploaded some photos,palnning to take it to service center, but if its due to lamp,i can chage one my self, any pointers and advice will be helpful
thanks
ID:	2635274   Click image for larger version
ID:	2635276   Click image for larger version
ID:	2635278   Click image for larger version
ID:	2635280   Click image for larger version
drgnanam is offline
post #2 of 5 Old 11-01-2019, 09:18 AM
Sonyad's Avatar
Quoted: 247 Post(s)
Liked: 140
Originally Posted by drgnanam View Post
Hi forum members,
thanks
This model has its own thread in the $3000+ section. Best to search there.
Sonyad is offline
post #3 of 5 Old 11-01-2019, 09:21 AM
descalabro's Avatar
Quoted: 468 Post(s)
Liked: 178
Hi forum members,
thanks
Hi,
not,it's not the lamp. Issues like this are often caused by a bad contact to one of the SXRD panels, or by an issue on the motherboard or image processing board. To eliminate the possibility of a bad input signal, just try the projector without any connected input.
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | Planar PD7150
descalabro is online now
post #4 of 5 Old 11-01-2019, 09:24 AM - Thread Starter
drgnanam's Avatar
Liked: 1
Originally Posted by descalabro View Post
Hi,
ok,
thanks that what i thought too,
drgnanam is offline
post #5 of 5 Old 11-01-2019, 09:28 AM - Thread Starter
drgnanam's Avatar
Liked: 1
ok, thanks, posted there too
drgnanam is offline
