Buying a Draper React Screen.. Projector screen too big? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-19-2019, 11:14 AM - Thread Starter
aoaaron's Avatar
Quoted: 142 Post(s)
Hi guys,
So my plan is to buy a Sony HW40ES project to begin with and get a Draper React ALR screen.
I know it a bit of a mismatch as my PJ will cost 400, the screen 700.
Anyway I have an issue. The draper is about 100 inches but my projected throw of the projector will probably be closer to 90 inches. I can't get a good deal on a draper screen for 90 inches so what are my options?
Is there any material I can use to limit the or disguise the effect of the image that won't be filled in or am I kind of stuffed?
aoaaron is offline
post #2 of 5 Old 11-19-2019, 11:20 AM
eljaycanuck's Avatar
Quoted: 1953 Post(s)
Liked: 2762
Originally Posted by aoaaron
… my plan is to buy a Sony HW40ES project to begin with and get a Draper React ALR screen. … Anyway I have an issue. The draper is about 100 inches but my projected throw of the projector will probably be closer to 90 inches. I can't get a good deal on a draper screen for 90 inches so what are my options? …
Get a different projector, one that will throw a 100" image.
eljaycanuck is offline
post #3 of 5 Old 11-19-2019, 11:21 AM - Thread Starter
aoaaron's Avatar
Quoted: 142 Post(s)
I'm at around 2.5-2.8metres distance and can't locate one which has as good a PQ as the sony with the input lag I need.. damn..
aoaaron is offline
post #4 of 5 Old 11-19-2019, 12:03 PM
AV_Integrated's Avatar
Quoted: 1662 Post(s)
Liked: 1205
Really, the best option in a smaller room is to use a projector with a different throw ratio, or to get a smaller screen. It's far less than ideal to try a mirror bounce and the complexities of setting something like that up.
You need just over 3m to get 100" out of that Sony. It's a fixed minimum distance, so that's what you need if you want 100" diagonal.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 5 Old 11-19-2019, 12:24 PM - Thread Starter
aoaaron's Avatar
Quoted: 142 Post(s)
You guys are right. I need to buy a different projector. Any reccomendations?
aoaaron is offline
