Ht2050a or Ht3550 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 3 Post By bud16415
  • 1 Post By sage11x
  • 1 Post By bud16415
  • 1 Post By sage11x
  • 1 Post By melvin74
post #1 of 8 Old 11-26-2019, 07:13 AM - Thread Starter
melvin74's Avatar
Ht2050a or Ht3550
I am getting ready to buy one of these and wondering if the 3550 is worth over twice the price of the 2050. I know this is subjective but there are other places I could place that 800 bucks. 🙂
melvin74 is offline
post #2 of 8 Old 11-26-2019, 07:32 AM
bud16415's Avatar
Quoted: 2171 Post(s)
Liked: 1097
It for me would boil down to how much that extra money means to you and if you are on a tight budget and that extra money could go for screen or room. Or even other equipment that you may need to improve the overall experience.
Then there is the size screen and seating distance. At a normal seating distance the difference for most people wont be that great IMO.
Then there is the media you will be playing. If your streaming and hard media is all 1080p or less the HT2050A may be a more logical pick.
I’m still quite happy with my projector that is quite similar to the 2050A.
sage11x, dreamstate and noob00224 like this.
Bud
bud16415 is offline
post #3 of 8 Old 11-26-2019, 07:56 AM
sage11x's Avatar
Quoted: 2878 Post(s)
Liked: 2895
I have both. I did an in depth comparison between the two here (see post 2):
https://www.avsforum.com/forum/68-di...or-review.html
noob00224 likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #4 of 8 Old 11-26-2019, 10:57 AM - Thread Starter
melvin74's Avatar
Thanks for the responses and I started reading through your thread Sage,, but its time to get back to work.
Money isn't typically a big deal but I am finishing my whole basement so its going to get expensive this winter.
I am getting ready to run electric and figuring out where to mount my projector. Not a big fan of drop ceiling or it might not matter.
melvin74 is offline
post #5 of 8 Old 11-27-2019, 06:41 AM - Thread Starter
melvin74's Avatar
Would it make sense to get the ht3050 over the 2050a for about a hundred bucks more?
melvin74 is offline
post #6 of 8 Old 11-27-2019, 07:49 AM
bud16415's Avatar
Liked: 1097
The 3050 is more like the 2050A and shouldn’t be confused with the HT3550. between the 3050 and the 2050A I would take the 2050A as it is a newer generation. If you can truly find a HT3550 for just 100 more without any catches it would be by far the best deal.
sage11x likes this.
Bud
bud16415 is offline
post #7 of 8 Old 11-27-2019, 11:54 AM
sage11x's Avatar
Liked: 2895
Ht2050a or Ht3550
The Ht3050 is calibrated right from the factory and has better built in speakers. This means the Ht3050 will have an edge in out-of-the-box color accuracy. That being said, the Ht2050A is really really good out of the box already. In fact, there was a thread here comparing the two side by side and the owner had difficulty spotting the differences.
I would, personally, go with the Ht2050A between the two. The 2050a has a longer 3 year warranty and a game mode that reduces lag to a blistering 16ms. The 3050 has a 1 year warranty and lacks the game mode so input lag is a respectable but not as impressive 30ms.
sage11x is offline
post #8 of 8 Old 12-02-2019, 05:04 PM - Thread Starter
melvin74's Avatar
They had the price even lower yesterday so I snagged the ht2050a. Now I have money left over for a screen option and money towards a new receiver!
sage11x likes this.
melvin74 is offline
