Optoma HD39Darbee Calibration HELP!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-30-2019, 12:15 PM - Thread Starter
gmanw54's Avatar
Guys,
I have no idea what i'm doing. Ever since I got the HD39Darbee I haven't been able to get it looking right. All the colors look blown out, even when using the presets. Almost looks distorted or out of focus but i've adjusted the focus using the test pattern. I know it's something i'm doing but I don't know what. PLEASE HELP!
Can anybody recommend some good baseline calibration settings that you guys have come up with?
Here's some of my settings attached
ID:	2647522   Click image for larger version
ID:	2647524   Click image for larger version
ID:	2647526   Click image for larger version
ID:	2647528   Click image for larger version
gmanw54 is offline
post #2 of 5 Old 12-01-2019, 02:50 AM
Quoted: 628 Post(s)
Liked: 188
Originally Posted by gmanw54 View Post
Guys,
Taking pictures with the lights on doesn't help.
https://www.avsforum.com/forum/139-d...libration.html
noob00224 is online now
post #3 of 5 Old 12-01-2019, 11:08 AM - Thread Starter
gmanw54's Avatar
i realize that. just wanted to show the settings i currently have. not the actual picture.
thought people would have some good baseline settings for this thing. guess not
gmanw54 is offline
post #4 of 5 Old 12-01-2019, 01:48 PM
Quoted: 628 Post(s)
Liked: 188
I literally linked a calibration disc in the previous post.
There are no universal/baseline settings, it's setup and user specific.
On my Optoma I remember Cinema and Reference being the most accurate.
Turn Brilliant Color off.
Can't remember what the Color setting in the Display menu did.
Try playing around with the Darbee settings.
The images don't look out of focus.
As I mentioned, there is a link for a calibration disc that you can use. Other than other calibration discs, only a calibrator or self calibration via external hardware (like colorimenters) would help.
Also this model has a RGBCY color wheel which does not offer the best in terms of color. The best color wheels are RGBRGB.
Some people are fine with non RGBRGB color wheels though.
LE: also set the color space correctly:
https://forum.kodi.tv/showthread.php...438#pid2739438
post #5 of 5 Old 12-04-2019, 12:33 PM
Ftoast's Avatar
Quoted: 2720 Post(s)
Liked: 908
Many Optoma's will also have a setting called something like "Dynamic Black" or Dynamic Contrast" (sorry, it's been a while), and turning this OFF can often help the image look more realistic and natural.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
