Dear Enthusiast Friends,
Hello and Have a nice sunday to all of you. I hope i open this topic to correct section on the forum, if it’s mistake i apologise about that.
So, my question is simple. I’m a daily user and i travel a lot. (Diffrent countries and places.) My main source of entertainment is a projector and i need to capable of move everywhere with me.
I bought a LG PF1500G Full Hd LED DLP Projector at november 2015. It has a lots of bug and crap futures but it’s ultra portable and i’m quite satisfied everytime i use. Unfortunetly last week it was broken (also i explain this situation at this topic;
#3468 )
https://www.avsforum.com/forum/68-di...38377?page=347
Anyway, I’m researching and i found this two device from LG again. The one of the lazer and another one is a led but both of color wheel-less.
In summary, my old device has a lots of creepy things. Such as, the black scenes are always blurry and grey-ish, light leaks from the lens, not a sharp and focused image on every corner, rainbow effects, cloudy parts on screen (especially dark ones), no smart apps, no internet, and high noise levels at maximum bright settings.
I need a average or great black levels, satisfying color gamut, internet and smart things is plus and ultra portable projector. I know the both device are a not true 4K. But I guess they’re good enough according to my expectations, lumen levels too.
Finally, which projector should i choose ? Is there any opinions for me ? All advice and comments are appreciated. Thank you for your time.
Regards, thanks.
