Any way to increase projector image size? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-02-2019, 06:46 PM - Thread Starter
aoaaron's Avatar
Quoted: 139 Post(s)
Hi I have a HW40es and I'm at its maximum range of wide angle. However I still need a few more inches to fill in my screen. Is there a cheap lens adaptor I can buy which can aid me in this or am i stuck?
I've heard of the mirror trick but it wont work in my setup.
aoaaron is offline
post #2 of 11 Old 12-02-2019, 06:56 PM
m0j0's Avatar
Quoted: 747 Post(s)
Liked: 809
Can you move the projector mount closer to the screen or move the screen closer to the projector?
m0j0 is online now
post #3 of 11 Old 12-02-2019, 06:58 PM - Thread Starter
aoaaron's Avatar
Quoted: 139 Post(s)
If needed but shouldn't I be moving them farther away to increase the image size?
aoaaron is offline
post #4 of 11 Old 12-02-2019, 07:12 PM
m0j0's Avatar
Quoted: 747 Post(s)
Liked: 809
Oh yeah, my bad, you are right. Farther back would give you a bigger picture.
m0j0 is online now
post #5 of 11 Old 12-02-2019, 07:48 PM
rekbones's Avatar
Quoted: 1118 Post(s)
Liked: 577
Why won't a mirror work in your setup? They're are a lot of configurations that are possible you just need to think outside the box.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #6 of 11 Old 12-02-2019, 08:02 PM
coderguy's Avatar
Quoted: 2529 Post(s)
Liked: 1371
Mirrors are a major pain and can cause artifacts, absolute last resort.
They are also usually a bit of an eye sore in an HT room.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #7 of 11 Old 12-03-2019, 01:19 AM - Thread Starter
aoaaron's Avatar
Quoted: 139 Post(s)
Eye sore and just huge space constraints in my current setup
aoaaron is offline
post #8 of 11 Old 12-03-2019, 03:13 AM
coderguy's Avatar
Liked: 1371
How big is your current screen and what aspect ratio?
coderguy is offline
post #9 of 11 Old 12-03-2019, 11:01 AM
AV_Integrated's Avatar
Quoted: 1656 Post(s)
Liked: 1203
The bottom line answer is 'no'.
There's no cheap way to do this effectively. You can certainly buy a wide angle adapter lens, of large enough size, but that will cost you quality like nothing else. Similar to a mirror bounce, or likely worse.
This goes back to measuring twice (or thirty times) and buying once. In your case, you will have to go smaller, or go with a mirror bounce. I'm not familiar with real world wide-angle lens testing, but there is a thread...
https://www.avsforum.com/forum/68-di...hortthrow.html
Yes, that thread is ancient, but believe it or not, the link to the .7x Sony adapter lens is still good. So, you may be able to get acceptable results going that route if you just need a foot or so more. But, you will need to take care in positioning the lens.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #10 of 11 Old 12-03-2019, 02:43 PM - Thread Starter
aoaaron's Avatar
Quoted: 139 Post(s)
I have a 95 inch screen and a HW40Es at around 2.7m so I'm going to assume a 2.7m throw producing a 90'' image approximately so its not the end of the world i guess. just a bit of a bummer i couldn't squeeze out an extra 5''.
i cant think of another PJ which can give me the extra 5'' except the panasonic ae8000 because its so tiny.
aoaaron is offline
post #11 of 11 Old 12-03-2019, 09:47 PM
rekbones's Avatar
Liked: 577
Many of the DLP's have a shorter throw and will fit well into your throw/screen size like the BenQ 2050a or the 3550 for 4K. Some LCD's will also work but no LCOS that I know of.
