Why LCD 4K pixel-shift projectors are so huge? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-10-2020, 06:51 AM - Thread Starter
Liked: 0
To my knowledge, these projectors like Epson 4010, 5050UB, 5050UBe are just using native 1080p LCD panels with pixel-shifting to create faux-K image.
Why they are so HUGE? Is the LCD prism larger or are the optics larger?
Please someone explain...
BaltarWithSix is offline
post #2 of 9 Old 01-10-2020, 07:37 AM
Luminated67's Avatar
Quoted: 776 Post(s)
Liked: 426
The simple answer is 3 panels compared to 1 on a DLP projector.
LED
DLP
Each method have their advantages and disadvantages.
They are more complicated inside with more mirrors and different light paths to travel before reaching the lens.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #3 of 9 Old 01-10-2020, 07:46 AM - Thread Starter
Liked: 0
Yes. I know that DLP projectors are much smaller than LCD projector because of their technology BUT my question rather is why these LCD pixel shifter projectors are much bigger than non-pixel shifter LCD projectors?
are the pixel-shifter 3xLCD panels bigger and require bigger opics?
post #4 of 9 Old 01-10-2020, 08:15 AM
Quoted: 776 Post(s)
Liked: 426
The Epson TW-7000 is 410‎ x 310 x 157 mm (WxDxH) 4K e-shifter
The Epson TW-5650 is 309‎ x 285 x 122 mm (WxDxH) 1080P
So not a million miles bigger but of course the more professional models like the 4010/5050/6050/9400 are considerably bigger. Both optics are bigger and with a higher lumen output the cooling fans etc will be bigger too, you then need to consider their motorised lens system.
post #5 of 9 Old 01-10-2020, 09:29 AM
tibimakai's Avatar
Quoted: 202 Post(s)
Liked: 63
They also have the lens mechanism motorized. For better cooling(less noise).
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-160M,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800CII/2xCDT3650CII,Klipsch R115SW/R110SW
tibimakai is offline
post #6 of 9 Old 01-10-2020, 10:30 AM
bdht's Avatar
Quoted: 358 Post(s)
Liked: 141
My single chip dlp projector is kind of big...
21"w x 9"h x 25"d 55lbs
bdht is online now
post #7 of 9 Old 01-12-2020, 06:18 PM
Quoted: 274 Post(s)
Liked: 93
what! 55lbs
I have also noticed that even those single LCD pj's have a very big Lens opening, about more than 2". Would that make their optics more complex & expensive? that some vendors just use plastic lens? Compared to pico dlp which have smaller Lens & I guess there will never be a PICO LCD pj.
XGimi CC, XGimi Z6, UKCSIS, Vmai M200 Pico
Xbox One S, LG SH4
wheelee is offline
post #8 of 9 Old 01-12-2020, 06:30 PM
bdht's Avatar
Quoted: 358 Post(s)
Liked: 141
Originally Posted by wheelee View Post
what! 55lbs
The actual chip size too contributes to the size of the optics required, and not just the lens but all the mirrors and prisms in the light path and even the light source(or at least the size of the light sources output/opening). Those pico dmds are small, 0.23, 0.33 inches, the LCD chips are 0.7 inches I think. Now imagine the size of lens and optics needed for 3chip 1.38" dmds
bdht is online now
post #9 of 9 Old 01-14-2020, 08:33 AM
Dave in Green's Avatar
Quoted: 3952 Post(s)
Liked: 3118
Projector size is often related to intended purpose. For example, projectors designed for portable use are often about the same smaller size regardless of whether they are 3LCD like the Epson HC 2150 or DLP like the BenQ HT2050A. Projectors intended to be permanently installed in home theaters don't need to be small and portable. In addition to often having larger lens systems and additional features, having a larger case allows for more internal baffling to cut down on fan noise which is a higher priority in dedicated home theater projectors than in portable models.
Dave in Green is offline
