Help With Epson Home Cinema 1060-No Power! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-24-2020, 06:58 PM - Thread Starter
Liked: 0
I bought a "For Parts or Repair" Epson 1060 for 50$ in an auction hoping it was a minor fix. Well Lucky me i plug her in and not even a blue light After taking it apart i find what seems to be a fried transistor or chip. Can anyone tell me where i might find the entire board to replace it? no luck with google or ebay or epson parts dealer. lastly is it even possible to find the burnt component and solder back on or am i dreaming
NuwaBic_Spitter74 is offline
post #2 of 5 Old 01-25-2020, 12:57 AM
rekbones's Avatar
Quoted: 1206 Post(s)
Liked: 611
The chances thats the only failed component are slim and soldiering on these new multi-layer circuit boards are not for novices. I would say finding another 1060 with a light engine problem might be your only hope. Unfortunately with the fairly low cost of these new most people just throw them out instead of trying to sell them for parts.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #3 of 5 Old 01-26-2020, 09:14 AM - Thread Starter
Liked: 0
Thanks I’ll keep searching for the pcb board online. May get lucky.
post #4 of 5 Old 01-26-2020, 03:00 PM
b curry's Avatar
Quoted: 1132 Post(s)
Liked: 724
I would suggest contacting Royal Camera. They do this type of repair. They will do free diagnostics/estimates through the end of the month.
The HC1060 is a great little unit. If you can get it repaired for under $200.00 you got yourself a pretty good deal.
https://royalprojectorrepair.com/projector-repair/
b curry is offline
post #5 of 5 Old 01-26-2020, 03:45 PM - Thread Starter
Liked: 0
Thanks I’️ll keep searching for the pcb board online. May get lucky.
Awesome Thanks for the info !
