4K Enhancement Requirements? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By steve1106
  • 1 Post By ivanhoek
  • 1 Post By DunMunro
post #1 of 5 Old 02-12-2020, 09:07 AM - Thread Starter
FSUDAL's Avatar
Liked: 0
I just purchased a factory refurbished Epson 5040UB projector directly from Epson that has native 1080p (1920 x 1080) with 4K Enhancement. Since the signal is 1080p will I need to upgrade my HDMI cable and receiver so that it allows for 4k pass through or will the 1080p pass through that I have now work as intended? I am on a budget right now and do not want to spend any additional money if it will not make a difference.
Bonus question;
My 8 year old Panasonic AE8000 projector has two light blue vertical lines in it. It is always there, in front of menu and regardless of signal source or picture position. I cleaned the three ribbon cables that connect the optical block but it did not solve the problem. I am assuming expensive parts will need to be replaced but please let me know if you are familiar with this problem and have any other suggestions.
Thank you.
FSUDAL is offline
post #2 of 5 Old 02-12-2020, 10:02 AM
steve1106's Avatar
Quoted: 854 Post(s)
Liked: 576
Well I upgraded to Epson's faux 4K last month and my AVR was a problem. While it allowed for 4K pass through it was only rated to 30Hz instead of the 60Hz the projector supports. This resulted in choppy 4K streaming on some content and a complete incompatibility when trying to play true 4K disks. For now I ended up upgrading my player now to bypass the AVR and send the video signal directly to the projector for streaming, enhancing standard blu-rays to 4K and 4K blu-rays. Since I had to run another HDMI cable, I purchased a cable to support today's 4K standards. (The new inexpensive true 4K Sony player had a HDMI sound out for the bypass.)
I plan on this being a temporary fix until I decide on a AVR since I miss the simplicity of just using the AVR for everything and ATMOS is tempting.
FSUDAL likes this.
https://www.avsforum.com/forum/15-ge...eap-build.html
Epson HC3800/HC2000; Screen - 151.5" 16:9/TV or 143.5" 2.35:1/HT at a seating distance of 12-15 feet; Yamaha RXV675 for 7.4; Speakers - Infinity Primus; Subs - 3 Polk PSW10s, 1 BIC F12; Headphones - 5 JVC wireless; Sony 4K Blu-ray player/six pairs 3D glasses.
steve1106 is offline
post #3 of 5 Old 02-12-2020, 10:37 AM
ivanhoek's Avatar
Quoted: 59 Post(s)
Liked: 66
Bonus question;
Thank you.
The Epson CAN accept a 4k signal, but isn't restricted to a 4k signal. You can replace your 1080p projector with the Epson and continue to use it as you had been using your previous projector. The Epson will apply 4k enhancement to that 1080p signal and make it look better. However, to get a true 4k signal from source to display you will need to invest in an AVR that has HDCDP 2.2. You don't have to do that right now if you don't want. The projector is perfectly capable of rendering 1080p signals.
FSUDAL likes this.
ivanhoek is offline
post #4 of 5 Old 02-12-2020, 10:50 AM
Quoted: 1084 Post(s)
Liked: 524
You can use an HDMI switch to bypass the receiver and feed 4K directly to the projector and the switch can extract the audio and send it to the receiver/amp. I use this switch:
https://smile.amazon.com/gp/product/B07ZNKF7C8/ which is a bit more expensive as it's a 4 in x 2 out. The 4x1 version is cheaper.
FSUDAL likes this.
DunMunro is offline
post #5 of 5 Old 02-12-2020, 01:07 PM - Thread Starter
FSUDAL's Avatar
Liked: 0
Thank you!
FSUDAL is offline
