White spots on projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-11-2020, 03:21 PM - Thread Starter
Liked: 0
Hey
I just bought a BenQ 1080ST off eBay. Unfortunately I noticed these big white spots on darker scenes and when the screen turns black. I cleaned the front of the lens but it didn't change anything. I also tried switching rooms, still the same.
Warranty is way gone.
It looks like something is dirty inside the projector.
See attached images.
How can I fix it?
Name:	spots on image 1 Room A.jpg
ID:	2696528   Click image for larger version
Name:	spots on image 2 Room A.jpg
gazoome is offline
post #2 of 7 Old 03-11-2020, 09:12 PM
Quoted: 1380 Post(s)
Liked: 402
Originally Posted by gazoome View Post
Hey
How can I fix it?
Those look like dust spots. If you focus/refocus the image, do the spots focus/refocus as well?
Might want to try High Altitude mode for a little while.
If not, it will have to be cleaned. Benq can do it for a relatively small cost, or you can do if you feel confident.
noob00224 is online now
post #3 of 7 Old 03-11-2020, 09:38 PM
rekbones's Avatar
Quoted: 1247 Post(s)
Liked: 630
Defiantly looks like dust in the optical block. I am willing to bet someone attempted to clean the dust out of the projector with compressed air without disassembling the projector. This usually results in forcing more dust into the optics. To fix the projector needs to be dissembled and cleaned out, not for those not familiar with delicate electronic connectors.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 7 Old 03-18-2020, 01:14 PM - Thread Starter
Liked: 0
Thanks noob00224 and rekbones for your answer.
BenQ has gotten back to me with a price for cleaning, which is almost as much as I paid for the entire projector with a new lamp. Their turn-round times are also slower than usual due to the virus outbreak.
Is this not something I can do myself?
I've noticed some dust spots also appears outside the image area.
gazoome is offline
post #5 of 7 Old 03-18-2020, 01:26 PM
Liked: 402
These projectors are roughly the same.
Starts at 8:58:
post #6 of 7 Old 03-21-2020, 06:56 AM
the7mcs's Avatar
Quoted: 527 Post(s)
Liked: 235
I thought I read some where that one of the advantages of DLP projectors is that they are not as prone/ affected by dust blobs as opposed to LCD types like the Epsons?
the7mcs is offline
post #7 of 7 Old 03-21-2020, 02:26 PM
Liked: 402
They are less prone, but DLP light tunnel is not 100% sealed.
