Benq MH550 vs Optoma HD39Darbee - what is better for home theater for movies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-22-2020, 03:20 AM - Thread Starter
Liked: 0
I have got 2 suggestions from my local shop for home theater projector:
Benq MH550
Optoma HD39Darbee
Which one is better?
DadHobby is offline
post #2 of 7 Old 03-22-2020, 07:04 AM
bud16415's Avatar
Quoted: 2319 Post(s)
Liked: 1217
The HD39Darbee would be my choice between those two. IMO there are a few better choices around the same price point if you have access to them.
Bud
bud16415 is offline
post #3 of 7 Old 03-22-2020, 02:10 PM - Thread Starter
Liked: 0
What?
DadHobby is offline
post #4 of 7 Old 03-22-2020, 04:53 PM
bud16415's Avatar
Liked: 1217
Originally Posted by DadHobby View Post
What?
Bud
bud16415 is offline
post #5 of 7 Old 03-22-2020, 08:05 PM
rekbones's Avatar
Quoted: 1245 Post(s)
Liked: 630
Benq MH550
Optoma HD39Darbee
With out knowing signifently more about your theater/room, mounting requirements, screen size, viewing distance and intended viewing content it's impossible to make any recommendations. The selection of projectors is vast and everyone has pros and cons as to if they will fit into your space and give you the most for your money and or personal enjoyment.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #6 of 7 Old 03-23-2020, 03:50 AM - Thread Starter
Liked: 0
Screen size ~ 280cm width. 16:9
Distance 4.6 meters from lens to screen.
Ceiling mounting.
Movies 90%.
DadHobby is offline
post #7 of 7 Old 03-23-2020, 06:02 AM
rekbones's Avatar
Liked: 630
Of those two the Optoma (shows discontinued) but the BenQ isn't even listed just going by the MH designation its a data grade projector. The BenQ 2050a would be my first choice but it does require a little shorter throw lens too screen then you have listed. You still didn't mention the type of room (size, color of walls/ceiling and light control) and this is one of the most critical factors in projector selection. The Epson 3000 series (US/UK is different) may be a much better choice if the room is less then ideal for light control.
rekbones is offline
