Need help on projector currently have a Epson 1080ub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-26-2020, 03:40 PM - Thread Starter
Csst's Avatar
Quoted: 20 Post(s)
Hello all I currently I own Epson 1080ub and in the market for a great upgrade from what I have now.. Mine is a little outdated and really not sure what would be best..
Looking for a 4k 3D projector really like my Epson projector and had great luck with it.. Any good recommendations on what to get.. I'm just worried if I upgrade I wouldn't notice a different I have a 100in fixed screen right now.
What are the suggestions? Thanks guys in advance.
Csst is offline
post #2 of 6 Old 03-26-2020, 07:20 PM
rekbones's Avatar
Quoted: 1247 Post(s)
Liked: 630
You did't mention budget. The Epson refurbished 5040ub is the best bang for you buck. From lowest to highest the Epson 3200/3800, 4010 and 5050ub are 1080p 2x eshift projectors with 1/2 4K resolution. Describing your room, viewing environment and content would help a lot with a better suggestion. One of the many XPR DLP's might even be a better option with 1080p 4x shift for full 4K. True 4K is out of the $3K range of this forum.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 6 Old 03-27-2020, 12:42 AM
Quoted: 1380 Post(s)
Liked: 402
What is the seating distance?
Color of walls?
Screen fabric?
Any games?
Regular use? Sports, 3D, movies, TV, etc?
Budget?
noob00224 is online now
post #4 of 6 Old 03-28-2020, 10:34 AM - Thread Starter
Csst's Avatar
Quoted: 20 Post(s)
Sorry about that guys... Mostly watch movies and little bit of games..my room size is 21x14 seating distance is about 8 feet from screen in front row and 2nd row is about 14 feet away.. Also would I notice a huge jump from what I have now?
Whats everyone thoughts on the Epson 6050ub?
I just want to make sure I would notice a huge difference.
Thanks again everyone
Csst is offline
post #5 of 6 Old 03-28-2020, 10:29 PM
Liked: 402
What's the wall color and screen fabric?
post #6 of 6 Old 03-29-2020, 01:40 AM
rekbones's Avatar
Liked: 630
If it's a truly dedicated light controlled theater (no white reflective surfaces) for the kind of money the 6050ub costs I would be looking at a JVC NX5 true 4K projector. If that's your budget your also in the wrong forum.
rekbones is offline
