Benq ht1075 bulb exploded - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-28-2020, 07:51 PM - Thread Starter
Liked: 0
Well I had an overdue lamp over 5500hrs, it exploded today. I noticed that there is a crack in the glass piece where the lamp pointing to, is the projector totaled?
ID:	2702972   Click image for larger version
Kello Tao is offline
post #2 of 6 Old 03-28-2020, 08:03 PM - Thread Starter
Liked: 0
I guess that's normal? Color wheel?
post #3 of 6 Old 03-28-2020, 11:19 PM
Quoted: 1736 Post(s)
Liked: 515
Can't tell if the color wheel is damaged from the picture.
If you can't tell either get it out and check.
noob00224 is online now
post #4 of 6 Old 03-29-2020, 05:54 PM
tibimakai's Avatar
Quoted: 232 Post(s)
Liked: 69
Pictures are way too small, to be able to see something.
Living Room: Samsung UN65JS8500,Onkyo TX-NR676,Klipsch R-28F,Klipsch RC-62II,Klipsch R-14S,Polk Audio 80 FX/RT(Atmos)
Bedroom: Samsung UN55MU6290,Onkyo TX-RZ610,Klipsch RP-160m,Onkyo & Fluance speakers
Garage: Epson 5040UB,Elite Screens 125" motorized screen,2xKlipsch RP-8000F,4xKlipsch RP-150M,Klipsch RP-450C ,2xKlipsch CDT-3800CII/2xCDT3650CII,Klipsch R115SW/R110SW
tibimakai is offline
post #5 of 6 Old 03-29-2020, 07:27 PM
roni44's Avatar
Quoted: 92 Post(s)
Liked: 74
Mine W2000 bulb exploded last month with only 2XXX hours on it. Upon close inspection, found small pieces of glasses in the compartment and a hole on the bulb itself. Vacuum and shake, shake and vacuum until I don't hear any glass falling noise, installed a new factory bulb and its work fine since then.
roni44 is offline
post #6 of 6 Old 03-30-2020, 05:43 PM
tibimakai's Avatar
Quoted: 232 Post(s)
Liked: 69
Make sure, that the bulb fan(in the center) does not have anything in it.
Don't blow compressor air in it(125PSI). It will disintegrate. Don't ask me how do I know.
