LG HU70LAB 4K RGB LED DLP Projector: Hands-On & Review - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #1 of 42 Old 04-01-2020, 09:51 AM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9507 Post(s)
Liked: 16878
I recently had the opportunity to review the LG HU70LAB 4K LED DLP projector. It's a compact projector that features an advanced 4-channel "wheel-less" design. This is essentially the same projector as the LG HU70LA but it comes in a black enclosure. It's rated to output 1500 lumens and is ceiling-mountable. The MSRP of $1799 puts it in the same price category as a premium 75" TV, making it an attractive option for anyone looking for a much larger picture (up to 140") than a TV provides.
The LG HU70-LAB uses a 4-channel LED light source that features discrete red, green and blue LEDs as well as a fourth "dynamic green" channel. Eliminating the color wheel allows this projector to express extremely vivid color that stays accurate over time.
This projector's lens is sharp, but it is limited in that it does not provide any lens shift functionality. A 1.25X manual zoom is helpful in getting the image to fit, but in the end the options for positioning this projector are limited with ceiling mount being the most likely to work out in many instances. However this projector is also quite compact and can be used as a portable, for example placed on a coffee table and shining on a blank wall.
It's the middle of the day and I cannot black out my living room, but I can already see this projector is nice and bright, and also sharp from edge to edge. It's a DLP so I don't expect miracles in terms of contrast, but the colors look vivid yet accurate right out of the box.
My very first impression is that the simple, somewhat limited lens does have the fringe benefit of being high quality (no visible chromatic aberration or geometric distortion) so there's a give-and-take versus a highly adaptable lens like you'd find on an Epson or Sony. Main thing is, if you can find a good spot for this projector, it appears to be a solid performer for a 4K DLP.
More coming soon, I have to wait for the sun to set to see what this projector is able to do.
I'm using this projector with a Seymour Screen Excellence Ambient Visionaire screen with it (0.9 gain, ALR, 110" diagonal 16:9).
Please feel free to ask any questions in the comments below as I get into my hands-on with this unit.
If you are purchasing this projector through Amazon, please use this link to help support the site.
If you are purchasing this projector through World Wide Stereo, please use this link to help support the site.
We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works here.
Russell Burrows likes this.
Mark Henninger
Editor, AVS Forum
imagic is online now
post #2 of 42 Old 04-01-2020, 12:09 PM
WayneJoy's Avatar
Quoted: 148 Post(s)
Liked: 107
The lack of any lens shift makes this a no buy for me. Especially for $1800.
hk2000 likes this.
WayneJoy is offline
post #3 of 42 Old 04-01-2020, 03:33 PM
blee0120's Avatar
Quoted: 1082 Post(s)
Liked: 782
I read reviews that it uses a .47in chip and others .66in. Which one is accurate?
blee0120 is online now
post #4 of 42 Old 04-01-2020, 06:00 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16878
It's not listed in any specifications, so I'm going to have to ask LG and see if I get an answer.
Mark Henninger
Editor, AVS Forum
post #5 of 42 Old 04-01-2020, 06:02 PM
blee0120's Avatar
Liked: 782
Ok. Thanks. On their homepage, it has the LG HU70LA with 1527 x 2715, which indicates a .66in chip. However, the reviews state differently.
post #6 of 42 Old 04-01-2020, 06:20 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16878
It seems LG's own marketing acknowledges this by either showing it ceiling mounted, or else on a table or stool projecting on a blank wall. It's not a dedicated home theater projector. It would be nice to see the light engine from this projector paired with a more sophisticated lens. FWIW current price is $1600 (there's a $200 discount in effect).
Mark Henninger
Editor, AVS Forum
post #7 of 42 Old 04-01-2020, 07:15 PM
chhanthony's Avatar
Quoted: 310 Post(s)
Liked: 133
Black version????
Thank you for your review.
I changed from Benq HT3550 to this LG HU70LA over 4 months, the picture quality and system stable are huge upgrade!
Anthony Chan
AV Blog: http://www.avnewbie.com
Panasonic DP-UB9000EBK, Shield TV Pro 2019, Zidoo Z9S, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, LG HU70LA, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #8 of 42 Old 04-01-2020, 07:21 PM
chhanthony's Avatar
Quoted: 310 Post(s)
Liked: 133
As I know HU70LA uses 0.47 DMD and HU85LA UST uses 0.66 DMD.
Anthony Chan
post #9 of 42 Old 04-01-2020, 07:24 PM
chhanthony's Avatar
Quoted: 310 Post(s)
Liked: 133
May I have the link, I can't find this information.
Thank you.
Edit: I found that picture, Thank you! I think they just share the same picture with HU85LA, as HU85LA provides from contrast and resolution than HU70LA significantly.
Anthony Chan
post #10 of 42 Old 04-01-2020, 07:28 PM
chhanthony's Avatar
Quoted: 310 Post(s)
Liked: 133
And I have no idea why LG doesn't mention HI70 and HU85 support HLG, at least it support the HDR (HLG) shot by my Sony Z1.
Anthony Chan
post #11 of 42 Old 04-01-2020, 07:53 PM
blee0120's Avatar
Liked: 782
Thank you.
Ok. That's kind of confusing to do. I was thinking this projector is a major deal for the price. But I'm sure its still nice and sharp
post #12 of 42 Old 04-01-2020, 08:34 PM
chhanthony's Avatar
Quoted: 310 Post(s)
Liked: 133
But here is a tricky thing, HU70LA accept 4096 x 2160 resolution from CalMan VideoForge Pro. I don't know whether 0.47 DMD will accept this kind of resolution as I never test with my previous HT3550 but menu says the highest resolution is 3840 * 2160
Anthony Chan
post #13 of 42 Old 04-01-2020, 10:47 PM
73shark's Avatar
Quoted: 589 Post(s)
Liked: 299
Is it a true 4K or a pixel shifter?
In space, no one can hear you scream . . .
73shark is offline
post #14 of 42 Old 04-02-2020, 12:23 AM
Quoted: 1794 Post(s)
Liked: 534
Pixel shifter with 8 million adressable pixels. So it's up to the required standard.
The only native 4K models are LCoS fron Sony and JVC.
4K pixel shifters can be as sharp as native 4K on the LCoS. Sharpness is impacted by other factors other than the type of 4K technology used.
noob00224 is online now
post #15 of 42 Old 04-02-2020, 05:01 AM
Ruined's Avatar
Quoted: 2643 Post(s)
Liked: 1273
There are native 4K (and higher) dlp projectors too (which are far sharper than the native 4k lcos ones) but they start at $25k+:
https://www.barco.com/en/product/bragi%20cinemascope
Ruined is offline
post #16 of 42 Old 04-02-2020, 06:37 AM
humbland's Avatar
Quoted: 1166 Post(s)
Liked: 367
How about a 4K DLP model with powered lens controls and lens memory?
Both JVC and Sony have had them standard for years...
humbland is offline
post #17 of 42 Old 04-02-2020, 09:02 PM
Quoted: 1390 Post(s)
Liked: 719
Here's a review:
https://audiovision.de/lg-largo-4k-hu70ls-test/ (use google translate for language of choice).
They claim 1430 lumens uncalibrated and 1000 calibrated, and .42 lumens minimum which is over 2200-1 contrast.
DunMunro is offline
post #18 of 42 Old 04-03-2020, 02:17 AM
Liked: 0
Sorry but I can’t find anywhere 2200:1 contrast ratio, it’s reported 300:1 after calibration.
AaronPurple is offline
post #19 of 42 Old 04-03-2020, 04:47 AM
Liked: 719
Schachbrett = 300-1 = checkerboard or ANSI contrast = 300-1
EBU = 500-1 = modified ANSI contrast (IIRC it's a 40% black and 60% white.
Helligkelt Kalibriert= Maximum calibrated brightness = 1000 lumens
schwarzwert = black level = .42 lumens.
1000 / .42 = 2381-1 on/off contrast ratio.
noob00224 and imagic like this.
DunMunro is offline
post #20 of 42 Old 04-03-2020, 05:12 AM
Liked: 534
What is the difference between the 70LA/B and LS?
That on/off contrast is similar to what the HT3550 can do. I wonder why some of the people that reviewed (the LG) said it has weaker blacks.
How does the active iris on the Benq compare to the dynamic (?) or dimming functions on the LG?
post #21 of 42 Old 04-03-2020, 05:44 AM
Liked: 719
I'm just translating the article but it seems that the HT3550 and a DI might do a bit better. The LS seems to be a newer model with higher output but maybe it's just the EU designation?
Chris Eberle reported that the dynamic contrast was difficult to measure with the standard static test patterns, but that it seemed better with actual content.
DunMunro is offline
post #22 of 42 Old 04-03-2020, 05:53 AM
Liked: 534
Shouldn't the LED source act as an instant iris?
Is it due to it's implementation?
post #23 of 42 Old 04-03-2020, 09:13 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16878
For those who asked, LG says it is a 0.47" DMD chip in this unit.
Mark Henninger
Editor, AVS Forum
post #24 of 42 Old 04-03-2020, 10:06 AM
JeffreyMercado's Avatar
Quoted: 20 Post(s)
So this does not support Dolby Vision at all.
JeffreyMercado is offline
post #25 of 42 Old 04-03-2020, 10:21 AM
Liked: 534
No projector currently does.
post #26 of 42 Old 04-03-2020, 10:48 AM
Ruined's Avatar
Liked: 1273
More succinctly, Dolby Vision doesn't support projectors.
nathan_h and Russell Burrows like this.
Ruined is offline
post #27 of 42 Old 04-03-2020, 10:50 AM
Quoted: 20 Post(s)
Thank you
post #28 of 42 Old 04-03-2020, 11:59 AM
Liked: 719
Theoretically, yes but currently it seems that only the BenQ HT9060 has implemented it, at least in a traditional way where it can be measured with static test patterns, although the BenQ uses a very modest dimming.
noob00224 and DoctorCyclops like this.
DunMunro is offline
post #29 of 42 Old 04-03-2020, 09:02 PM
blee0120's Avatar
Liked: 782
Thanks for the update
post #30 of 42 Old 04-04-2020, 05:38 AM
dan webster's Avatar
Quoted: 303 Post(s)
Liked: 311
The only difference between this 2020 model from last years white case model on the lg website is that its black not white. My question would be has the new model improved in anyway. You would think lg would have shown that on the marketing and web site if it had.
Dolby Atmos 7.2.4 Yamaha CX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 panasonic ub820 Ultra HD Blu-ray Jvc RS3000 projector
Eulenvusion 130 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Emotiva T1 rears
4 RSL C34 in ceiling SVS PB2-plus sub SVS PC13 ultra sub
dan webster is offline
lg hu70lab
