Uhd30 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 05-18-2020, 10:59 AM - Thread Starter
Liked: 0
Uhd30 question
I had a optoma hd20 before on third lamp with over 2000 hours now upgraded to uhd30.
The problem is the new projector is darker than the old one I don't know what I could be doing wrong I'm in a totally light controlled environment.
Brian19876 is offline
post #2 of 25 Old 05-18-2020, 02:36 PM
Quoted: 1335 Post(s)
Liked: 703
What is the source device and is it an HDR signal?
HDR can sometimes appear too dark, but this can be adjusted via the HDR Dynamic range options menu.
DunMunro is offline
post #3 of 25 Old 05-18-2020, 03:23 PM - Thread Starter
Liked: 0
I've tested with a xboxone x and a roku ultra both look dark. I do have dynamic menu set to bright. Seems like I'm missing something if you try to look a the simple calibration on the xboxone you can't see the dark eye no matter what I set brightness to
post #4 of 25 Old 05-18-2020, 03:27 PM
Liked: 703
Also setting Gamma = 2.0, 1.8 or video should brighten things further.
What does the UHD30X menu->info state for incoming signal (bit depth, HDR, 4:4:4, frame rate)?
DunMunro is offline
post #5 of 25 Old 05-18-2020, 03:33 PM - Thread Starter
Liked: 0
10bit4:2:0
bt. 2020 hdr
post #6 of 25 Old 05-18-2020, 03:34 PM - Thread Starter
Liked: 0
60hz
post #7 of 25 Old 05-18-2020, 03:41 PM
Liked: 703
10bit4:2:0
bt. 2020 hdr
60hz
OK.
How does it look if you turn HDR off in the source devices?
DunMunro is offline
post #8 of 25 Old 05-18-2020, 03:51 PM - Thread Starter
Liked: 0
It's a little brighter but it just looks kinda dark and dull the picture is definitely higher resolution then my old projector but color and brightness not right
post #9 of 25 Old 05-18-2020, 04:10 PM
Liked: 703
Can you ensure that the source devices are outputting YCBCR?
projector HDMI color space should be set to auto
(options are auto YUV RGB 16-235, RGB full range)
In general for non-HDR sources, these settings should be a good balance between brightness and colour:
Display mode = Cinema or Game, gamma = 2.0/1.8/video or graphics. Graphics seems to work well for broadcast TV.
Color temp - D65 (higher = brighter)
Brilliant colour = 10
Dynamic Black = on (important).
color gamut = HDTV
On my UHD50 I was able to access the service menu and turn on ISF day mode:
https://www.avsforum.com/forum/68-di...l#post58340808
DunMunro is offline
post #10 of 25 Old 05-18-2020, 08:09 PM - Thread Starter
Liked: 0
Display mode = Cinema,
gamma = 2.0
Color temp - D65
Dynamic Black = on
color gamut = HDTV
Brightness 7
Contrast -6
post #11 of 25 Old 05-18-2020, 09:19 PM
Liked: 703
gamma = 2.0
Color temp - D65
Dynamic Black = on
color gamut = HDTV
Brightness 7
Contrast -6
OK, does menu->info report YUV (YCBCR)?
How do the above settings look?
DunMunro is offline
post #12 of 25 Old 05-19-2020, 02:50 AM
Quoted: 1739 Post(s)
Liked: 515
@Brian19876 how large is the screen and what type of fabric?
noob00224 is offline
post #13 of 25 Old 05-19-2020, 05:15 AM - Thread Starter
Liked: 0
It's a 120in elite screen cinewhite
Multi-layer PVC (Polyvinyl Chloride) with texture
and surface coating
• CineWhite® material has a Gain of 1.1
• Active 3D, 4K Ultra HD and HDR ready
• Surface can be cleaned with (water) moist cotton
cloth
• Viewing Angle: 180o
(90o
+/- LR)
post #14 of 25 Old 05-19-2020, 06:57 AM - Thread Starter
Liked: 0
Menu reports bt 709 or bt 2020 depending on source hdr or not. With my setting I posted still seems dark an colors seen a little washed out
post #15 of 25 Old 05-19-2020, 07:09 AM
Liked: 515
Is it possible to take a picture?
post #16 of 25 Old 05-19-2020, 08:56 AM - Thread Starter
Liked: 0
In hdr
ID:	2729120   Click image for larger version
ID:	2729122   Click image for larger version
ID:	2729124   Click image for larger version
ID:	2729126   Click image for larger version
post #17 of 25 Old 05-19-2020, 08:58 AM - Thread Starter
Liked: 0
Not hdr
ID:	2729132   Click image for larger version
ID:	2729134   Click image for larger version
ID:	2729136   Click image for larger version
ID:	2729138   Click image for larger version
post #18 of 25 Old 05-19-2020, 09:50 AM
Liked: 703
does menu-> info report YCBCR (or YUV)?
I would suggest resetting contrast and brightness to zero.
Also make sure that the source device firmware is up todate.
DunMunro is offline
post #19 of 25 Old 05-19-2020, 10:17 AM - Thread Starter
Liked: 0
Both my xboxone and my roku firmware are up to date I will look again at the menu I dont see yuv or YCBCR or rgb in the info menu
post #20 of 25 Old 05-19-2020, 10:35 AM
Liked: 703
My UHD50 will only report RGB if my PC is outputting RGB so it's likely you are getting YCBCR. Still, you'll have to check the colour space output options of your source devices because this can make a considerable difference.
DunMunro is offline
post #21 of 25 Old 05-20-2020, 02:58 PM - Thread Starter
Liked: 0
Di you use a different gamma setting for hdr content
post #22 of 25 Old 05-20-2020, 03:08 PM
Liked: 703
when I get HDR from my UB420 BD player, I normally use HDR dynamic range = film and gamma 2.4 because I can tune the HDR via the UB420 HDR optimizer. For HDR output from my Sony X-700 BD player I will use HDR dynamic range = bright or standard and gamma 2.0.
For non-HDR TV broadcasts I like to use gamma = graphics.
DunMunro is offline
post #23 of 25 Old 05-20-2020, 06:40 PM
dagameballa's Avatar
Quoted: 83 Post(s)
Liked: 29
Turn brilliant color off. Brilliant color washes out the picture. Or keep it at 3 or less. Either that or hdr may not be syncing properly, one of the big clues to an hdr signal that doesn't sync is a washed out picture.
dagameballa is offline
post #24 of 25 Old 05-20-2020, 06:41 PM
Quoted: 83 Post(s)
Liked: 29
Try 4.2.2 10 bit limited.
post #25 of 25 Old 05-20-2020, 10:15 PM - Thread Starter
Liked: 0
Thanks everyone for the help I think I'm giving up on the uhd30 can't get it to look right no matter what. I think I will put my old hd 20 back up and send this 1 back
