Sony HW45ES or BENQ HT3550 (W2700) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-23-2020, 04:12 PM - Thread Starter
Liked: 0
Please help me choosing Sony Hw45es and BENQ HT3550. I am really confused because I found both with similar price and warranty. 1050 USD . Hw45es is 1080p and ht3550 is 4k. But i heard sony at 1080p is better than most 4k.
I have completely dark room and want to for movies only. I dont play games.
Sent from my GM1910 using Tapatalk
sagarsamtani is offline
post #2 of 2 Old 05-23-2020, 05:35 PM
rekbones's Avatar
Quoted: 1332 Post(s)
Liked: 677
The Sony should have a better 1080p image over the BenQ but their are a lot of other considerations to take into account. Just because you can turn out all the lights does not mean your room is fully light controlled. The projector it self is a huge light source and if you have an all white room that light will reflect off the screen and light up the room bouncing off the reflective surfaces back onto the screen washing out the picture. The Sony's big advantage is the LCOS panels as they have better pixel fill and Superior black level over especially DLP. The BenQ's best feature is it will accept a 4K/HDR source and display the full 4K pixels on the screen. If you have no 4K sources and a dark "light controlled" room the Sony is the better projector. With the growing number of 4K sources I would most likely pick the BenQ.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
